Question about Acer Aspire One PC Notebook
IM HAVING POWER ISSUES WITH THE ACER ASPIRE 5750 AFTER REPLACING THE DC JACK WHICH I THOUGHT WAS THE PROBLEM
SOURCE: Acer Aspire 4520, power jack
You may be able to buy the whole assembly on Ebay. I bought one for my averatec laptop and it just popped into place, no soldering. It was about $20
Posted on Sep 07, 2008
  • 7 Answers
SOURCE: acer not work
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
Posted on May 25, 2009
joecoolvette
  • 5660 Answers
SOURCE: the dc power jack will not accept power.
It's a little more involved than just removing the keyboard. You have to
Completely disassemble the laptop, until just the motherboard is in your
hand.
HOWEVER, for this Acer model it's a different installation, than the
normal one. This DC Power Jack uses a small wire harness. You just
unplug the old one, and install the new one. Let me explain,
I'm a tech who normally works on HP, Compaq, IBM, (Lenova now),
and Acer laptops. Acer's that are older than yours. All the DC Power
Jacks that I have replaced, are directly soldered to the motherboard,
and have no wire harness leading off of them. No plug connector on
the end of a harness, either.
In my search just now for a replacement power jack, my findings show
that the Acer Aspire 5920 series have a small wire harness.
Let me show you,
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=2977
Here the jack is offered minus the harness. You have to unsolder your old
harness from the defunct power jack, and solder it to the new one.
http://www.laptopjacks.com/view_part/Acer-Laptop-DC-Power-Jack-AC231916.html
You'll find the body of the DC jack is made of plastic. There is a metal
pin in the center. (This is the Positive post. + )
Some DC power jacks have a metal cylinder, or metal tube shape that surrounds the Positive metal center pin. This is the Negative connection.
Some just have a flat metal contact prong in the back for Negative.
If you have your AC adapter plugged in, and the plug is bumped, the metal
center pin can break loose from it's mount. Break loose from the plastic
body. Same thing for the metal 'shell' for the Negative connection, but this
doesn't happen as often.
Again, most DC Power Jacks have metal flat prongs that come out of the
power jack's body, go through the motherboard, and are soldered on the
backside. These solder connections can crack, and break, making an
intermittent connection. Doesn't seem to be the case for yours, IF the
jacks shown are the correct ones.
This may help you in your endeavor to disassemble your Acer Aspire.
(AND reassemble!) (TIP from me. DEFINITELY buy an ESD wrist strap
and connect the alligator clip to a good ground. They only cost about
$5 to $7 dollars. They are to relieve static from your body. Electro Static
Discharge wrist strap)
1.http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
2.http://repair4laptop.org/disassembly_acer.html
Posted on Jun 22, 2009
  • 21 Answers
SOURCE: installing Acer Extensa dc power jack on 5520
what do you want to say? you can look buy world of warcraft gold and wow cd key
Posted on Dec 16, 2009
SOURCE: Acer Aspire 5735Z Replacing the Power Jack
http://www.eservicemanual.info/index.aspx?b=Acer&m=ASPIRE-5735&view=1240994504
This is pretty simple, go to this website above and download your service manual, it shows how to disassemble and do what you want.
Posted on Jul 14, 2010
How do you open a port
  1. USB ports stopped working Acer Aspire 5750 - Tom's Guide
    www.tomsguide.com/.../usb-ports-stopped-working-acer-aspire-5750.ht... Apr 23, 2014 - USB ports stopped working Acer Aspire 5750. Tags: Aspire. Laptops... I have an Acer 5750 none of the USB ports work I tried disabling them all ... on Acer Aspire 4935 laptop Forum; Acer Aspire Computer - USB not working ...
Jul 11, 2015 | Acer Aspire Computers & Internet
How to replace the DC Power jack of my acer aspire 7735Z
Replacing a DC Power jack in any computer is no easy task. However, it can be done by any novice. First, get on ebay and see what jack you need. Search for you jack by entering Acer Aspire 7735z jack. Most of the new ones have the cable attached to the jack instead of the old fashion solder.
Next, Google this question and check out the YouTube videos regarding Acer DC Jack replacement. It will give you an idea as to what you need to do. You may want to take a video camera and record what steps you take when you take it apart so you can review how to put it back together. Also, get a sewing box or something so you can put the screws in a separate container for the order you removed them; ie: bottom screws; hard drive screws, DVD mount screw... etc..
You always have to start with the bottom and work your way to the top. You will have to remove the palm rest, keyboard, heat shields and any other piece of hardware to get to it.
YouTube is your friend...
Aug 12, 2014 | Acer Laptop DC Power Jack for Acer...
Acer 5610 charging difficulty
Yes! the DC jack will probably need to be resolded, and I would recommend replacing the power adapter because it may fix your problem, I find the universal supplies don't fit as tight as the original ones. www.ebay.com is a good place to start for power supply replacement.
Mar 30, 2012 | Acer Aspire 5600 Series 5610-2013 Notebook
Does this computer have a dc power jack plug or cable
Acer Aspire One D250 AOD250 has cabled dc jack, do not need to solder, plug in and your laptop will work, view this page for reference: http://www.lapdiy.com/acer-aspire-one-d250-aod250-wire-harness-power-jack-dc-in-cable-p-26502.html
hope this can help you!
Dec 27, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
DC jack for aspire 8943g
Just go to any electronic shop and bring the sample jack, surely they have one for you.
Hope that helps!
Nov 23, 2011 | Acer Aspire Ethos 8943G-5464G50Bnss...
No power at all, tried a new charger still no power and replaced the battery.
Hi
After the battery and AC cord replacement and still not getting power there's only once culprit there and that is the motherboard of the laptop. I recommend you call Acer and have them replace it for you. Thanks
Feb 21, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
Jul 14, 2010 | Acer Aspire 5735 Notebook
Acer Aspire 5920-6864 wont turn on at all
Good questions.
You might want to try another power adapter first before replacing the board though.
If you do decide to replace the board I always use the same exact part number to avoid having to re-install windows, etc. You can do some research though to see if a higher revision will work. That info usually isn't available on the net though :(
If the board is available on the cheap then I'd say go ahead and fix this laptop otherwise lots of them are going for 200-300 this Black Friday ;)
Nov 20, 2009 | Acer Aspire 5920-6727 Notebook
Power Supply problems
hello :
Sir u are facing a probleme with your ac adaptor jack in your laptop maybe yo need to change it .
changing of a ac adaptor jack its not an easy task you will need a soldring kit & a new propre jack for u laptop
dont forget rating this post if this is not helping u tell me so i can help u further .
Aug 20, 2008 | Acer Aspire 3000 Notebook
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
