Question about Microsoft Windows XP Professional
Re:continue oh mannn,, Can you give me advice on wht i should do in order for me to get everything back like before?( Like Xp, not vista) Or like tell me how i can get rid of all the Vista stuff.. Thank you so much
  • 258 Answers
Not sure what you have done but you could try a restore
Start --> All Programs --> Accessories --> System Tools --> System Restore --> Restore My Computer to an Earlier Time
Pick a bold date from the left --> and select a restore point on the right click restore
Please do not keep posting a new question use tha same one,
but if you do please remember to go back and give it a rating, Fixya if I have answered your question, or helpful etc. if it's only partially answered it,
Thanks HPC
Posted on Jan 26, 2009
Hard drive crashed. Got another hard drive and rescue disks from laptop mfr. Reloaded my 5D Professional and everything was fine. Then MS said Windows 7(64bit) had to download a bunch of updates.
Suggest you TURN automatic updates OFF. Use the manual method, and download the ones you want.
Reload your Windows 7 64-bit with auto updates turned off.
Now try it.
Regards,
joecoolvette
[ Windows XP Service Pack 3 s-ucked too. Problem, after problem, after problem. What to do? Oh, we'll just make another Operating System, (Vista), and sweep that under the rug.
Vista? Give me a break.
Oh, we'll just make another Operating System, and sweep that under the rug.
Now, look at how new Windows 7 is. Guess what?
Windows 8 is just around the corner.
You can see your problem started with the auto updates)
Jun 10, 2012 | Computers & Internet
Hello! I have an Acer M7720 desktop computer, with 2 flatscreens running along. Since the day I bought it, the computer has problems with starting up. Brought it to repair during warranty but they didn't...
It sounds like you have a corrupt registry... :(
Vista handles their registry fixes a bit differently than xp.
However, I found a nice Microsoft article to help me out.
I'm pretty sure it is easier to repair the registry with Vista and 7, make sure to back it up!
Oh, one last note --- In my case with XP, it was a lot easier to manuver registry files if the Hard Drive is hooked up to another computer.
Dec 08, 2010 | Computers & Internet
How to default computer system? It's like a new one.
You did not specify what brand of computer or operating system.
general advice:
To do a factory restore and set the computer software back to like when you first purchased it:
Windows XP:
You will need to visit the manufacturer's website and order the restore cd.
Windows Vista and 7:
Start the computer and tap F11 button. This will bring you to the factory restore wizard and allow you to erase everything on hard drive and install like the day you brought it home from the store.
Sep 25, 2010 | Computers & Internet
My PC doesn´t recognize my Canon Pixma MX300
1. keep connect your printer and switch on,
2. re-install vista
3. it will detect all ports automatically and fix it
4. thru this u can find solution for your problem..
5. if vista ask for the driver, then install your printer driver from cd
all the best... try it
Jun 21, 2009 | Canon PIXMA MX300 All-in-One Printer
Brake line under master cylinder rusted and spraying fluid
Replacing rusty brake lines is a nasty job, but u can do it yourself and save a ton of money. A while back, someone else asked this question and decided to have a garage do it, and it cost $1200. U can purchase different lengths of brake line at any auto parts store, along with connectors to join the lines together. The dealer won't have pre-bent lines for a car that old, but u can buy the different lengths necessary to replace the rotted line. You'll have to follow the line to see where it ends, which may be quite a distance away. The problem is, by the time u have to replace a line, they all need to be changed. The labor cost is high, but u can purchase the lines at a low cost. Get the car uo on jack stands, soak the line connections w/ wd-40 or some penetrating oil for a day (or more if possible) to help in removal. Replace a section at a time w/ lines u bend to fit as u go.Good Luck
Dec 28, 2008 | 1993 Oldsmobile Cutlass Ciera
Word documents not opening with Vista
THIS IS THE PITS! I HAVE FOUGHT THE SAME THING ON MY HP LAPTOP WITH VISTA HOME PREM, AND MY DESKTOP HAS WIN XP PRO,SP2. MT VISTA HAS CRASHED ABOUT A THOUSAND TIMES AND MY XP PRO IS AS STABLE AS A ROCK! THERE IS NO SOLUTION TO THE XP DOCUMENTS. VISTA IS NOT BACKWARD COMPATIBLE AS XP IS WITH OLDER VERSIONS AND IT IS A PAIN WITH EMAIL ATTACHMENTS! IF IT IS CAUSING PROBLEMS WITH YOUR WORK I WOULD DO THE FOLLOWING. VISTA CAN BE REMOVED EXCEPT FOR THE FILE ITSELF AND XP CAN BE PUT ON YOUR NOTEBOOK. YOU THEN WOULD BE ABLE TO FUNCTION AS BEFORE. ANY GOOD COMPUTER SHOP CAN DO THIS SWAP QUICKLY AND HAVE YOU RUNNING AGAIN. I LOOKED INTO IT AND YOU JUST HAVE TO MAINTAIN THE VISTA FILE FOR THE SYSTEM TO FUNCTION BUT THEN THE XP OS CAN BE ADDED AS THE OPERATING OS. THIS DOES NOT CAUSE ANY DAMAGE AND LATER IF YOU WANT TO GO BACK TO VISTA YOU CAN JUST DELETE XP AND REINSTALL THE VISTA FILE AND EVERYTHING IS BACK THE WAY IT WAS. IT CAN BE DONE. AND YOU DON'T HAVE TO GIVE UP YOUR NOTEBOOK OR THE DUO-CORE AND HEAVY MEMORY ETC! CHOICE IS YOURS! HOPE THIS HAS GIVING YOU SOME HOPE AND AN IDEA ON HOW TO PROCEED. IF I CAN HELP MORE, JUST REPLY TO:
ARCLIGHT1217
Nov 05, 2008 | Microsoft Office Professional 2007 Full...
I have HP dv6517tx. i want to format vista and wants to install XP
my advice is not to as your bios would have been upgraded for vista and cause problems with drivers for your XP system
If you wish to install XP, install it on a seperate hard drive or partition to give you a dual boot choice as to whether you want to run XP or Vista.
Sep 08, 2008 | Computers & Internet
Audio problem regarding win xp with D101 GGC
i see all driver less vista.
i enclosed the link.
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2229
Feb 29, 2008 | Intel D101GGC Motherboard
USB port malfunction?
Oh God i have the same exact problem. I run XP Pro and USB ports all malfunctioned, after tyring EVERYTHING I reloaded windows and it worked.......for about 8 months, now I'm back to I can't use my printer, storage devices ANYTHING that plugs into the USB ports. I'm at my wits end. I'm thinking of throwing the compter out the window
Jan 12, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
42 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
