Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire Affinity ATF600ES1 Front Load Washer will not spin
Will not spin
5 Suggested Answers
  • 1314 Answers
SOURCE: Frigidaire Affinity front loading washer will not spin
send me an e mail at b4829@yahoo.com for futher info
Posted on Jul 10, 2008
  • 378 Answers
SOURCE: Frigidaire front load washer wont high spin
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Apr 03, 2009
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
rabbitbrains
  • 575 Answers
SOURCE: my frigidaire affinity front load washer stopped spinning
Your door lock switch assembly has gone bad. It is an easy fix.
Posted on Sep 27, 2011
Where is the pressure calibration switch on an affinity front load washer?
Hello garrett_lind, I appreciate your inquiry!
From my understanding you are searching for the pressure calibration switch on your Frigidaire washer due to the fact that it is not spinning on the last cycle. Some possibilities as to why your appliance is not spinning could be your timer or drain pump. I could not locate steps to access the pressure switch but for electrical components I would recommend having a professional come out to properly diagnose and repair the appliance. -Matt
Aug 12, 2014 | Frigidaire Affinity ATF7000ES Front Load...
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire GLT F 2940 ES Front Load washer. Spin is slow. Clothes wet
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 03, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
How to diagnose
Sounds like your motor is blown. That's going to require a repairman.
Mar 31, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
62 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
