Question about Toys
Jcb 3cx hydraulic schematic
Hydraulics slowing down after warmup
4 Suggested Answers
  • 68 Answers
SOURCE: I have a ford tractor and hydraulics are slow
not so fast,, yes thick hydraulic oil can cause slow hydraulics and if the hydraulics speed up when warm then this may be your problem. if they dont then you need to look at possible problems with the pump, the spool, or linkage to spool. remember that speed is flow, a pump can have good pressure but lousy flow. also there should be some kind of pressure relief valve in system if this stuck open then it will let oil go back to tank causing your problem. there is no quick answer to your problem but there are a lot of possibilities. need to do some diagnosing!
Posted on Mar 11, 2010
ranimaria79
  • 39 Answers
SOURCE: Have wiring fault on a JCB Backhoe 1987 3CX and
Hi
you can get wiring diagram from here.
Hope this helps, thanks!
Posted on Oct 29, 2011
  • 3 Answers
SOURCE: where i can order jcb 3cx part?
try paul martin servicess @ aberdare s/wales
Posted on Nov 22, 2011
JCB js 130 one side track tracking faster than other side?? Why??
Is this the same going both forward and reverse?
This is usually an indicator that there is a problem with the track drive motor on the slow side. Check your hydraulic fluid return screen for metal debris.
Mar 14, 2015 | Cars & Trucks
NEED ALL DIMENSIONS FOR JCB 3CX4TJ MAIN PUMP
Is there any hydraulic oil that is compatible with a case 1390 tractor?
Jul 19, 2013 | Jcb Motorart 13136 3cx Backhoe 187
Hydraulic oil running out
hydraulic oil for? a JCB a dozer? ?
Apr 14, 2013 | Cars & Trucks
I need to know where the bleeding screw for brakes on jcb214e backhoe
most of those type of equipment have inboard brakes in the axle tubes of the rear gear assembly i.e. follow your brake lines from the master cylinder to the rear axle assembly,the lines usually go in and to a caliper and another line comes out to a bleeder tip nipple ,some models are actually inside the axle tubes them selves requiring disassembly of the wheels ,axle tubes etc. until you get to the inboard rotors and calipers ,major work for such a minute ordeal this is done to keep the system protected believe it or not,i would obtain yourself a model repair manual if i were you or you could also go to jcb and ask them for a photo copy of the entire brake hydraulic system
Feb 28, 2012 | Jcb Bruder JCB Loader Backhoe
Have wiring fault on a JCB Backhoe 1987 3CX and need schematic
Hi
Oct 29, 2011 | Toys
Where i can order jcb 3cx part?
Nov 29, 2010 | Jcb Bruder JCB Loader Backhoe
I need some parts manuals for a jcb 3cx and a tractor ford 6640
i need a schematic for the back hoe of a JBC 3cx sm turbo 1989 can any one help
Sep 23, 2010 | Kitchen Ranges
JCB 3CX Back Hoe Overrun
Depending on the year (what cab colour  or dash modeal?) its the slew ram seals or cross line relief valves for the same .
Oct 25, 2009 | Garden
Toys Logo
99 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
