The machine leaks underneath, seemingly on the left side with almost every wash, with or without washing powder. It could possibly be at the end of 'rinse' when changing to 'spin/.
SOURCE: leaking washing machine
you need to clean above where the drawer goes in, the water jet holes get blocked and spray sidewards. also you can reduce the water pressure at the supply tap to a fast trickle this will avoid jets of water flowing over and forward of the tray.
SOURCE: washing machine leaks from underneath after rinse cycle
i would 1st look to make sure the drain hose is not loose or broken. be sure it is staying in the drain pipe in the wall.it could be a cracked housing on your pump. hope this helps
SOURCE: LG Fuzzy Logic
Place a piece of magnetic material at the edge of the lid, for the wf-s6697tc model.
Standing in front of the washer, it is slightly off centre to the right (at the edge where the lid covers, space between the wording speedy soak & fuzzy). If you pay attention to the lid, you might notice some brownish rust stain.
This is where they place the magnet.
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
