Question about Roland VersaCAMM VP-540i
Write port error - Roland VersaCAMM VP-540i
Port 01 error
There could be a problem with port (that is what it looks like).
Try opening the CASE and check for the SATA cable if plugged correctly. Plug SATA cable into other port and check that your Cables and ports are correctly functioning. Check for any garbage in the port or cable(rare).
Feb 21, 2013 | Acer Computers & Internet
Tip
Tipical Computer/Laptop Post & Beep Error Codes
Error Code: Faulty Component:
_____________________________________________________________
1 short beep None (Normal Boot)
2 short beeps ( POST error)
Non-stop beep ( Power supply or system board)
1 long beep and 1 short beep ( System board)
1 long beep and 2 short beeps ( Video card)
1 long beep and 3 short beeps ( Memory)
3 long beeps ( Keyboard)
Non-stop short beeps ( Power supply or system board,a key on the
keyboard might also be stuck)
None ( Power supply,system board,or system
case built-in speaker)
______________________________________________________________
Visual POST Error Codes:
Error # Range: Component with Error:
100-199 System Board
200-299 System Memory (RAM)
300-399 Keyboard
600-699 Floppy Drive or Floppy Controller
700-799 Math Co-processor
900-999 Parallel Port (LPT1)
1000-1099 Parallel Port (LPT2)
1100-1199 Serial Port (COM1)
1200-1299 Serial Port (COM2)
on Oct 01, 2010 | Computers & Internet
This error is caused by an issue with the ports of your router.
To solve this error :
On your router settings, open TCP port 80, port 443, port 5223 and UDP port 3478, port 3479, port 3658.
Disable the media server connection option found under the Network Settings menu option on the Playstation 3.
Feb 19, 2011 | Sony Playstation 3 (PS3) Console
[CS Raw] Connecting to connection server port '5050'... [FAILED] *** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0203' ***
Solve this problem
Checking connection servers...
*** 'COMPONENT_TYPE_YCP_EX' YCP EX Error: ('FND.0210', 0, 0) ***
[CS Raw] Connecting to connection server port '80'... [PASSED]
[CS Raw] Sending port check command... [FAILED]
*** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0000' ***
[CS Raw] Connecting to connection server port '23'... [FAILED]
[CS Raw] FAILED
*** 'COMPONENT_TYPE_YCP' YCPError: 'PortSelector::AllPortsFailed' ***
Dec 08, 2010 | Yahoo Messenger
Error 0701: USB Over Current on HC/Port
Error 0701: USB Over Error 0701: USB Over Current On HC/Port - Bus:00H Dev :1DH Fun:01H / Port:00HCurrent On HC/Port - Bus:00H Dev :1DH Fun:01H / Port:00H
Sep 28, 2010 | Lenovo 3000 C200 Notebook
My ps3 gives me an error code 80710723 what shall i do
Hi sir
80710723 - error code
Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
While accessing mail i am getting message (error code:ssl_error_rx_record_too_long_
Error code: ssl_error_rx_record_too_long Your SSL website may fail to load and display the error
This usually means the implementation of SSL on your server is not correct. The error is usually caused by a server side problem which the server administrator will need to investigate.
Below are some things we recommend trying.
- Ensure that port 443 is open and enabled on your server. This is the standard port for https communications.
- If SSL is using a non-standard port then FireFox 3 can sometimes give this error. Ensure SSL is running on port 443.
- If using Apache2 check that you are using port 443 for SSL. This can be done by setting the ports.conf file as follows
— clip —
Listen 80
Listen 443 https
— clip —
- Make sure you do not have more than one SSL certificate sharing the same IP. Please ensure that all SSL certificates utilise their own dedicated IP.
- If using Apache2 check your vhost config. Some users have reported changing <VirtualHost> to _default_ resolved the error.
Mar 18, 2010 | MPC Computers ClientPro 125D PC Desktop
Printer Froze and Have Download Message
Downld File Now
RFU LOAD ERROR
RESEND RFU OVER
PARALLEL PORT
Aug 13, 2008 | HP LaserJet 5550 Printer
Cisco error on switch
%SYS-4-P2_WARN: 1/Tag 0 The switch generates %SYS-4-P2_WARN: 1/Tag 0… messages.
This example shows the syslog output that you see when this error occurs:
%SYS-4-P2_WARN: 1/Tag [dec] on packet from [ether] port [chars],
but port's native vlan is [dec] This message indicates that an 802.1Q-tagged packet was received on a nontrunk port. The VLAN that is derived from the packet tag is different from the port native VLAN. In the error message:
  • The Tag [dec] is the VLAN identifier from the packet.
  • The [ether] is the host MAC address.
  • The port [chars] is the port identifier.
  • The second [dec] is the native VLAN number.
There is a possibility that the local port is incorrectly configured as an access port instead of a trunk port. Alternately, the remote side can have been configured as a trunk port instead of an access port.
Verify that the local port is not incorrectly configured as an access port instead of a trunk port. Also, verify that the remote side is not configured as a trunk port instead of an access port.
Feb 06, 2008 | Cisco Catalyst 4006 Chassis ( 4006)
Roland VersaCAMM VP-540i Logo
56 people viewed this question
Top Roland Office Equipment & Supplies Experts
Michael Harrier
Ravi
Chas Peters
Level 1 Expert
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
