Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Ti-84 plus silver edition will not graph
Everytime i press graph the messege ERR:MEMORY pops up
  • 11 Answers
Try going into the memory men (2ND - +), and selecting option 2.  Delete some stuff you know you don't need.  If the problem persists, 2ND - +, this time option 7.  Reset the defaults.  You won't lose anything, it will just reset the settings that may be causing this issue.
Posted on Jan 28, 2009
Ti-84 plus err: invalid dim
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
May 27, 2014 | Texas Instruments TI-84 Plus Silver...
I'm using the t and z test on my TI-84 Plus graphing calculator. When I go to enter data it will only let me enter in the standard deviation and mean but then it gives me an error message that states ERR:...
You do not have enough memory free. You will need to clear RAM and possibly delete programs to free up space.
Pressing [2nd][+] will take you to the memory management functions. From this menus you can delete from Programs, Applications and can also reset your RAM. Doing any of these should help free up enough memory.
Feb 21, 2011 | Texas Instruments TI-84 Plus Silver...
TI-84: trying to graph an equation and ERR: INVALID DIM shows up only PLOT 1 is highlighted Window XMax XMin Ymax and Ymin are correct Any ideas? Test tomorrow
Jan 05, 2011 | Texas Instruments TI-84 Plus Silver...
My TI-84 Plus Silver Edition Graphing Calculator continues to read "ERR: INVALID DIM" whenever I attempt to graph equations.
Dec 04, 2010 | Texas Instruments TI-83 Plus Calculator
When I graph, it shows "ERR: INVALID DIM 1:QUIT"
Oct 28, 2010 | Texas Instruments TI-84 Plus Silver...
When trying to graph anything, ERR: INVALID DIM appears..
The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-84 Plus Silver...
When i press most buttons it gives me the message ERR:MEMORY i cant access memory so i cant reset ram or delete . also i can not connect to my cpu it says TI-84 plus Silver Edition detected, but couldn't...
From the TI knowledge base and FAQ
How do I correct ERR: MEMORY on a TI-83 family or TI-84 Plus family graphing calculator?
An ERR: MEMORY is given when there is not enough memory to perform the instruction or function. To increase available memory by deleting the contents of any variable (real or complex number, list, matrix, Y= variable, program, Apps, AppVars, picture, graph database, or string), follow these steps. • Press [2nd] [MEM] to display the MEMORY menu.
• Press 2: Mem Mgmt/Del.
• Select a variable or data that needs to be deleted and press [ENTER].
• Use the arrow keys to move the cursor next to the item, and then press [DEL]. The variable or data should now be deleted from the memory.
When deleting programs or Apps, a message asking for confirmation will appear. Select 2:Yes to continue. To leave any variable screen without deleting anything, press [2nd] [MODE].
Notes:
With the exemption of programs and Apps, no warning will be given to verify the deletion.Some system variables, such as the last-answer variable Ans and the statistical variable RegEQ, cannot be deleted.
Hope it helps.
Oct 06, 2009 | Texas Instruments TI-84 Plus Silver...
"Err: Data Type" - Not Allowing Me to Graph
First, turn it on. Once the calculator is on, press the "2ND" key (I believe it is a blue key in the ti-84 plus silver edition). Now press the plus key (+). A little above that key, you should see the word "mem." When you see the screen titled MEMORY, move the cursor all the way down to the option that says "Reset." From here, you can choose to reset either the RAM memory, or the factory settings. The factory settings are the "Defaults" option. I hope this helps.
Jul 25, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
200 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
