Question about Brother MFC 210C All-In-One InkJet Printer
"Refer to Maintenance Manual"
I don't have one and I don't know what this refers to however, I did have several paper jams. Clear them from front. They continued. Then cleared from back. It cleaned itself.
I then used it for several jobs. Now I get the above quote, "Refer to Mainenance Manual". I don't have one and don't know what this refers to.
Please help!!!
  • 34 Answers
Try looking here for a solution and manuals to download.
Hope this helps
Posted on Feb 01, 2009
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
On Oki 330 have error 380 still showing after paper jam was cleared
Make sure everything is clean. Please refer to your manual for cleaning instructions; or download a new manual at .
Below are how to clear a jam instructions:
How to remove jammed paper 28/07/2013
Paper handling is key to Ensure trouble-free printing. However, paper jams sometime Occur.
You can improve feeding and Avoid paper jams in your OKI printer, by following these simple steps:
Loading the Paper: When loading paper, fan the stack of paper before placing it in the tray. This will shake out any paper dust and reduce any static in the paper, two major causes of paper mis-feeds.
- Place the paper in the tray under the tabs.
- Do not fill above the "PAPER FULL" mark.
- Guides Adjust the tray for the correct paper size.
Recommended Media: Use paper specified for the printer
When printing on heavy / thick types of paper, it is best to use the manual feed tray at the front of the printer.This will Provide a straighter paper path to Prevent potential paper jams.
Cleaning: Periodically wipe the rubber rollers inside the area That holds the paper tray with a soft cloth.
dust Paper and simple wear may cause these rubber rollers to slip and not feed the paper properly.
Nov 29, 2013 | OKI C3400n Laser Printer
My HP4100 keeps jamming under the toner cartridge. I have a repairman look at it 2 times and he cannot figure it out. Does anyone know what would be causing the jam. It seems to happen mostly on short...
1) Check all the paper jam locations (see "Clearing paper jams" in your printer manual). A piece of paper might be stuck somewhere in the printer. Even a small torn piece of paper in the printer path can cause repeated jams.
2) If you are using a duplexer, check all the areas (including under the duplexer).
3) Check that the paper is correctly loaded in the tray - that all paper tray adjustments have been made, and that the trays are not overfilled. Make sure the paper is under the front and back tabs. (See the section on "loading paper" from your printer manual.)
4) Check that all trays and paper handling accessories are completely
inserted into the printer. (If a tray is opened during a print job, this might cause a paper jam.)
5) Check that all covers and doors are closed. (If a cover or door is opened during a print job, this might cause a paper jam.)
6) Try printing to a different output bin or tray
7) The sheets might be sticking together. Try bending the stack to separate each sheet.
8) If you are printing from tray 1, try reducing the size of the stack.
If printing from the envelope feeder, make sure it is loaded correctly,
9) If you are printing small sizes, feed paper short edge first (see
the "Guidelines for printing custom-size paper" in your printer manual).
10) Turn over the stack of paper in the tray. Also try rotating the paper 180 degrees.
11) Check the characteristics of the media you are using. Use only paper that meets HP specifications (see the "Paper Specifications" in your user manual).
12) Try using different paper to see if the problem goes away. Do not use curled, deformed, damaged, or irregular paper.
13) Check that the environmental conditions for the printer are met (see the "Environmental Specifications" in your printer's user guide).
14) Avoid using paper that has already been used in a printer or copier.
15) Check that the power supplied to the printer is steady and meets printer specifications (refer to the "Electrical Specifications" in your printer's users guide).
16) Clean the printer and rollers (refer to the "Cleaning the Printer" section of your printer's user's guide).
17) Perform preventative printer maintenance if maintenance is due (refer to the "Performing Preventative Maintenance" section of your printer's user's guide).
Nov 21, 2013 | Office Equipment & Supplies
How do I clear paper jam
The flashing error code that indicates a jammed printer is the digital-age equivalent of a flat tire. Sooner or later it happens to everyone, so you'd better know how to get things moving again if you want to finish your print job.
1.Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2.Turn off the printer.
3.Remove any paper trays. Inspect them for wrinkled or damaged paper.
4.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5.If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6.If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
7.If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
8.Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9.If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Sep 21, 2011 | HP Photosmart C5180 All-In-One InkJet...
Error 50 of Brother printer DCP-130C
Details of this error code are.
5D,5E The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us".
May 01, 2011 | Brother DCP 130C All-In-One InkJet Printer
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
I amusing a Brother HL-2140. Recently, the paper curls up and gets stuck in the tray, and will not move forward. I have cleared the pat several times, but the paper is stuck in the rollers, and it tears...
Turn off the machine, > Open the front cover > remove the drum, cartridges, > and check if you can see the jammed paper or not, if so pull it out slowly. If you can't see the paper, close the front cover > Pull out the Tray completely > and once again check if you can see it or not, if so pull it out. Still it's not there? then install the tray and open the back door > pull the tab to open the fuser unit and pull out the paper, you can also pull out the fuser unit.
You can also refer to this tutorial from Brother Solution to clear paper jam
Good luck.
Aug 13, 2010 | Brother HL 2140 Laser Printer
What do we do if my printer says "refer to printer documentation
Go to HP support page for this printer, download the manual and refer to the manual to fix the problem. If that is not enough, refer to HP online troubleshooting or ask a new question to Fixya,
Here the printer support page: HP Photosmart C5280 All-in-One Printer - HP technical support
All the best.
Aug 11, 2010 | HP Photosmart C5280 Printer
My Brother HL-2040 paper led light won't stop flashing, the paper's not jammed or anything, I just put in a new toner, too. I tried doing what someone else said about opening the cover and holding Go until...
Hi. The reasons listed in the manual that cause the LED to flash normally are:
Front cover is open
Close the front cover of the printer.
Back cover is open
Close the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 6-5.
If the printer does not start printing, press the Go button.
No paper fed manual feed slot
Put the paper in the manual feed slot. See Printing on plain paper, bond paper
or transparencies from the manual feed slot on page 1-10 or Printing on thick
paper, labels and envelopes from the manual feed slot on page 1-13.
Memory full
The printer memory is full and the printer cannot print full pages of a
document. See Solving print problems on page 6-15.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Drum Error
The corona wire needs to be cleaned. See Cleaning the corona wire on page 5-14.
If you check out page 6-5 it tells how to clear the paper jam from the rear of the machine! A point often missed.
Check out the website below if you don’t have a copy of the instruction manual =
If all else fails, try a reset of the printer Drum & Page counter:
  1. With printer tuned on.
  2. Press and hold the “internal button” behind front cover, until all LEDs illuminate.
  3. Make sure Drum light is off, then release and close front cover.
Hope some of this helps………..Please post a response back here and let us all know if it works?............Regards, Cornwellnet (UK)
Jul 12, 2009 | Brother HL-2040 Laser Printer
Brother MFC 210C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Jim Keysor
