Question about Sharp MX-2300N Color Copier
Sharp mx m305n print driver
Need drivers
3 Suggested Answers
SOURCE: Hi, New to Mac and trying to find sharp driver
Thanks for posting the obvious weatlandsvc. If i were to just point people to the vendors driver page, and pass that off as the answer, I would be fired. Thanks for the obvious.
I'm working on solving the real problem!!!!!
Posted on Dec 01, 2009
SOURCE: network printing from a mac computer to sharp mx 2300n printer
Here's a new solution that works. When adding the printer, choose "Generic PCL Printer". This will allow you to print from your Mac to the Sharp Printer without buying the PostScript chip/kit for the printer.
Posted on Nov 17, 2011
Sharp mx-350n will not print in color from the network
Which model is it? The MX-350N is black and white, the MX-3501N is a color model. I'll assume it's the MX-3501N.
Either it's defaulted to print B&W in which case you just go to your printing preferences of the print driver in the printers menu in the control panel, and uncheck the "black and white print" box, or you have account/user codes that you need to enter in your print driver in order for it to print color. Instructions for adding a user code to the printer driver are found here.
Setup and Manage User Codes Account Control on Sharp Copier
Feb 03, 2014 | Sharp Mx-3501n Color Copier Printer...
Sharp mx 3110n, all settings are at "Plain Paper", when print a worksheet from excel, does not print because settings say "Heavy Paper"
Excel treats each worksheet as a different print job. Make sure each page is set to the type of paper that you want to print on.
Under the Page Setup make sure the type is set for the correct type, as well as in the print driver.
How To Configure Sharp Print Drivers with Installed Options to print...
Oct 21, 2013 | Sharp "MX-3110N Color Copier, Printer,...
Sharp MX4100n driver software freedownload
You can download Sharp print drivers directly from this link. Both 32-bit and 64-bit drivers are available for download here on this page along with instructions for getting them installed.
Sharp Print Driver Download 64bit and 32bit Free Printer Driver Download
Sep 23, 2013 | Sharp "MX-4100N Copier, Printer, Scanner...
How to install hole punch setting on pc
You need to configure your print driver with the options that the machine has. Check out my How-To configure the sharp print driver.
Aug 23, 2013 | Sharp MX-5111N Copier w/ 36 Month Warranty
Sharp mx2300n tray 3
Sounds like you need to configure your print driver with the options that your machine has on it.
Check out my instructions on how to do this!
Apr 30, 2013 | Sharp Mx-2300n Copier Color Mx2300n...
I installed the Driver for my Sharp MX-2700G on my new Macbook Pro (OS 10.8). I see the printer but cannot print. Anyone can help please?
usually after installing the correct driver and it finds the printer and ip address and loads in and then a test print is done and nothing comes out then look for the model again and find sharp sap driver that is associated with your model and windows version not forgetting 32bit or 64bit. The driver will look the same but will have sap in the title. once tested and working remove the original printer you installed as it will never work.
Nov 06, 2012 | Sharp MX-2700N Color Copier
Hello i have copier machine sharp mx-450u,with mx-nbx3.some times when i print document.suddenley stop printing,so i turn it off then it start printing,allways same ****.so i dont know the proplem cause of...
As a general rule, U machines are not designed to be turned into network printers, that's what the MX-M450N is for. You can put an MX-NBX3 on it, it might work properly and it might not.
The NBX3 can only function properly with a hard drive in the copier, otherwise you're outta luck!!
Your driver type may be wrong. If you are currently using PCL6, try PCL5e.
Other than that, try getting a new driver from the Business Copiers section of sharpusa.com. You may have to see which model will work for you. Look for the PCL driver for MX-NBX3, then look for MX-M450U, then MX-M450N.
Jun 17, 2009 | Sharp Office Equipment & Supplies
Network printing from a mac computer to sharp mx 2300n printer
HI,
Sounds like driver problem..
go to this site: Driver Update and make required updates.
wish you best of luck
cheers
Dec 17, 2008 | Sharp MX-2300N Color Copier
Sharp MX-4501N Mac drivers 1.1 will not hold black and white colour setting in printing profile (save as)
You are using Bonjour to print to the MX-4501N which uses a generic post script driver. To fix this, you must install the printer using the proper driver from Sharp. For a first time install, download the drivers, install the drivers, restart, and install the printer as an IP printer, specify the IP address, it should be using the LDP (Line Direct Printing) protocol, and specify any additional optonal accessories you have on your MX-4501N. Hope this helps :)
Oct 09, 2008 | Sharp Office Equipment & Supplies
Sharp MX-2300N Color Copier Logo
50 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
