Question about Cook's Essentials Kitchen Appliances - Others
I can't get the locking front cover to line up
Front brakes lock up on ice covered roads
dont drive on ice coved roads.. doesnt matter what your driving if you apply brakes on an icy road they will lock up...
Jan 04, 2014 | 2001 Dodge Ram - 2500, Club cab, long bed,...
The Hard Drive on my Sony Vaio VGC-JS1E is fried and I need disassembly instructions
Should list this as a Clarification, instead of a Solution, but there isn't enough room in Clarification.
I also do not perceive this as being a Solution. Just info.
Good luck in finding a Service Manual.
Why?
Because this unit, as All-In-One desktop units are; is essentially a laptop, stood up on end.
http://www.itreviews.com/hardware/desktop-pcs/sony-vaio-vgc-js1e/
All the hardware components, and the Display Assembly, are crammed into one tiny thin 'box'.
This you know.
The point I am making here is that it needs to be worked on, just like a laptop. Once the Back Cover is removed, you have access to almost all of the inner hardware components, at your fingertips.
So does Static electricity.
This is why an ESD wrist strap should be worn, and it's alligator clip connected to a good ground source.
Plus a multi-compartment container should be used for the various screws, you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
Just going to change a Harddrive, may lead to removing other hardware components first, to be able to access the harddrive.
The Power Supply unit is inside, also, on SOME models.
This is why manufacturers of All-In-One's, generally do not post info on how to open it, and replace parts.
A general user can;
1) Static shock out the internal hardware components.
2) Not know to unplug the AC adapter from the All-In-One, before working on it.
3) Not know the general procedures for reinstalling the various hardware components, and metal bracing. Can't get the All-In-One back together properly.
Blame the manufacturer.
Okay, so you know what you are up against.
What basic tools do you need?
No.1 and No.2 Philips screwdriver
ESD wrist strap, (About $3 to $6 bucks)
Plastic spudger tool.
Perhaps a small set of Hex Nut handdrivers.
Patience
See above.
See above.
With the power removed, and the All-In-One laid down on the display screen, (On a soft, static free towel, on a table), start looking at how to remove the back stand.
There are usually visible Philips head screws, and some may be hidden behind a label.
Once the stand is removed, the Back Cover should remove, or there may be a Rear Stand Cover to remove, then the Back Cover.
The Back Cover MAY, or MAY NOT, have screws that actually hold it on. The screws from the Rear Stand, (And maybe the Rear Stand Cover, if there is one), may hold the Back Cover on.
The Back Cover -> WILL have plastic locking tabs on the outside of it's edges. These locking tabs mate with matching locking latches, on the front assembly.
Screws to remove, or not, the Back Cover pops off of the front assembly. Sometimes it's a little stiff to perform. This is why the heavy duty plastic pry tool. The plastic Spudger Tool,
http://www.ifixit.com/Tools/Spudger/IF145-002
Helps to ease into the parting line between the Back Cover, and the front assembly. Ease one edge out a little, then slide the tool down, and work on another small area. (Edge)
Once the Back Cover is removed, use logic as to how to access the Harddrive's caddy. Remove the caddy, and harddrive. Then remove the harddrive from the caddy.
Not very specific, huh?
Hopefully this Service Manual for a Dell Inspiron One 2305 or 2310, All-In-One Desktop PC, will help,
http://support.dell.com/support/edocs/systems/InsOne2310/en/sm/index.htm
It's just a general guide, in relation to the All-In-One you have.
Not stating it is the 'go to guide'.
I would start with: Technical Overview. Gives you an idea of how far the Spudger Tool, should go in-between the parting line of the Back Cover, and front assembly. (NOT FAR!)
Then:
Rear Stand
Rear Stand Cover
Back Cover
Harddrive (Harddrive cage = harddrive caddy)
Like I said, just general info that may help. Should you get this baby open, perhaps you would post information on your procedure.
You would help 1000's of users, if not 100's of thousands, by posting.
Just a thought.
(Make a record. Make notes, and drawings as you disassemble. You may wish to use a digital camera, or video camera, or at least a cell phone camera, to record your steps. Will help when you go to put it back together )
Additionally;
1) http://www.youtube.com/watch?v=woKr204wHRE&feature=related
2) http://www.youtube.com/watch?v=d0oO2DCkbHE
Regards,
joecoolvette
Jul 07, 2012 | Sony Computers & Internet
How to remove the screen from the y510
The thin plastic 'frame' in the front of the LCD screen, is the Display Bezel.
Goes by many names. Display Bezel is used by HP.
Display Mask, LCD Bezel, LCD Panel Bezel, and LCD Front Bezel, are a few other examples.
Lenovo/IBM uses LCD Front Bezel.
Lenovo doesn't show an HMM for the IdeaPad's, other than for the S9e series, and S10e series, (Notebook), plus the A1-07 series. (Tablet)
(Hardware Maintenance Manual)
http://support.lenovo.com/en_US/SupportSearchResults.page?searchText=ideapad+hmm
(An HMM is a Service Manual)
I also see there are no guides posted by users.
Therefore we'll have to 'wing it', using my years of experience with repairing laptops, and you as the tech.
1) Do you see any screw covers on the LCD Front Bezel?
May not be the usual synthetic rubber covers. May be plastic, and the same plastic, and color as the LCD Front Bezel.
Example,
http://www.insidemylaptop.com/replace-broken-lcd-screen-lenovo-x60s-laptop/
Scroll down to the photos in Steps 1 and 2.
Also note the 'seals' on the side of the Display Assembly, shown in Step 2 photo.
We'll start with this.
2) Haven't worked on a Y510, and perusing the internet; it seems no one has found a solution, for removing the LCD Front Bezel off of an IdeaPad Y510.
{ ALL power removed before beginning. Remove the AC adapter
(Charger), and Battery }
3)
A) There is no sticky double-sided tape holding it on.
B) Can't simply 'pop' it off, as with other Display Bezels, that do not use Philips head screws to hold it on.
[ For all Display Bezels, (Other than this baby, perhaps), there are locking tabs on the outside edges of the Display Bezel.
These match up to snap locks, on the inside edge of the Display Cover. (Top cover of laptop)
When the Display Bezel is removed, the locks snap loose ]
C) I suggest remove the screws which hold the Display Assembly to the laptop, and see if at the bottom of the Display Assembly, there are screw covers, or just screws, to remove.
If there are, and no other screw covers/screws to remove, the LCD Front Bezel should pop off.
This is what I mean by pop off,
http://www.insidemylaptop.com/replace-screen-on-lenovo-g560-laptop/
Step 2 and 3.
{ The laptop is made by Wistron. (Philippines) One of the three major laptop manufacturers, that makes laptops for ALL laptop brand manufacturers.
Such as Acer, Compaq, HP, Lenovo, Toshiba, Asus, you name it }
Post back in a Comment.
Regards,
joecoolvette
May 06, 2012 | Lenovo IdeaPad Y510 Notebook
Front end wont engage even though it will go from high range ito low range
Does the front drive shaft turn? Maybe the hubs aren't locking in. If the hubs don't lock, then even if the transfercase is functioning you still won't turn the front tires. Hope this helps, Shaun
Dec 15, 2011 | 2001 Ford Explorer
How to replace the upper cutter on the baby lock? which screws to release the old blade?
I also have a babylock eclipse BLE1DX serger & here's how my book says to do it
to replace the upper cutting blade
1.open the front panel
2.remove the screw holding the upper blade
remove the upper blade
3.position the new blade in the blade slot, replace the screw.as you tighten the screw, hold the blade up in it's highest position
4.close blade cover. close front cover
hope this helps you
good luck
Sep 12, 2011 | Baby Lock Eclipse Serger
How do i remove the front cover from my nokia c3
Sir please open the back side cover of your phone and there you will see four small lock of front cover press backward the lock front cover will be removed automatically go do it..'
bye
Aug 19, 2011 | Nokia Cell Phones
I can't get the washer to unlock. The cycle is stuck and I think the load is unbalanced but I can't get the washer door electronic lock to open even after I turn the washer off and unplug it
Manual Door Unlocking Procedure for Maytag Neptune Top Load Washers
  1. Safety first. Unplug the machine.
  2. Insert a plastic putty knife blade in the front edge of the machine between the top cover and the cabinet and in line with the lid seam on the left and on the right.
  3. Push in to release the latches holding the top cover to the cabinet.
  4. Lift the front of the top cover and release the lid from the lid locks.
  5. Disconnect the wiring harness from the lid locks. Clean the terminals to ensure good connection.
  6. Reconnect the lid locks wiring harness and push the top cover back into the cabinet until the latches lock up.
Please let me know if the problem comes back for further troubleshooting and repair guide.
Jan 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Front end will not lock in in 4x4 transfer case is in & dash lite shows 4x4 but front wheels don;t lock in.
Hi
It could just be low fluid in the gearbox/transfer box have you checked these?
Is the car new to you?
Jan 22, 2010 | 1999 Kia Sportage
Kitchen Appliances - Others Logo
Top Cook's Essentials Kitchen Appliances - Others Experts
Tom Chichester
Laura P.
Laura P.
Level 1 Expert
Jason
Are you a Cook's Essentials Kitchen Appliances - Other Expert? Answer questions, earn points and help others
