Question about Whirlpool GT4185SK Microwave Oven
Need stirrer cover for microwave
I have a Whirlpool Microwave Model: GT4185SKB-2 that was arching from the inside top. I took it to be repaired and the technician said I need a new stirrer and stirrer cover, but the cover is no longer made! The insides of this microwave was kept clean with no more than the usual spills that occur. This microwave was manufactured in February 2003. Any ideas where to purchase this part? The repairman is waiting for me to call him back on Monday before he just trashes my microwave. (side note: I have a Kenmore microwave that was purchased in December 1980 that still works!!!!!!) Thank you.
  • Johnann Allen Jul 14, 2007
    The reason I would like to fix this microwave is that it fits inside a shelf with the kit around it. It is a pain to find another microwave that same size to fit etc...
I LOOKED ON THE NET AND FOUND THAT ALL ITEMS FOR
THIS MICROWAVE ARE STILL AVAILABLE.
STIRRER COVER PART # W10144311
STIRRERT DISK PART # 8172022
Posted on Mar 31, 2008
SOURCE:
When i use the microwave it makes a very loud coughing and spluttering noise and there is a flashing of lights inside. It also smells of smoke. Any help greatly appreciated. I live Bristol, England if they...
proceed according. God bless youIf you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
If your microwave has a shelf in it, and you do not use it, keep it out. If one of the shelf supports breaks or comes out, the microwave will arc where the support was. You will have to sand the spot down, paint with appliance paint and re-install support. If the shelf shifts on the support and touches the side it will arc.
Your magnetron waveguide will either come out of the top, or side of the oven cavity. Some will have a stirrer in it(mostly top waveguides) with a panel over, or just a cardboard type cover over it. Over time, the stirrer cover can become warped from the heat which will expose the stirrer's metal shaft which will then cause sparking. These covers and stirrers come in a kit and can be replaced from inside the oven cavity.
Your cover over a side waveguide is coated with a substance on it, and overtime this coating can come off from the heat and moisture in the microwave. These waveguide covers are very easy to replace from inside the oven cavity. Touch up any paint that may have chipped or come off because of the arcing.
If your waveguide cover and/or stirrer are all OK, then the spark is coming from your magnetron. The antenna on your magnetrom has overheated and burned, sending the microwaves out at the wrong angle. If you catch this microwave oven repair early enough, you can usually get by with just replacing the magnetron. If the arcing has caused servere damage inside the waveguide, you will need a new microwave. Waveguides are not replaceable and most you can barely see into them, let alone sand and re-paint. In this case of microwave oven repair, when you remove the magnetron, you will see the burned antenna, or your magnetron will fail the test below.
Apr 04, 2013 | Samsung CE1031B Microwave Oven
Kenmore microwave is sparking when you it start and then goes to pause
see this steps and fix it. God bless you
see the guide for test the magenetron and another component.
Oct 03, 2012 | Kenmore Microwave Ovens
Sparks when starting then goes to pause mode
see this next steps. God bless you
My LG/Dometic MICROWAVE sparks inside the cooking area when turned on
see the next steps and follow with common sense: God bless you
Microwave is arcing If you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
Jul 26, 2012 | Microwave Ovens
Stirrer Motor Part Number PS237771 GE Microwave
Quite possibly the Stirrer/ antenna motor. To Replace that, the outer cover of the machine must be removed. Unplug unit and take off the screws on the back of the unit and pull the cover back toward you and it will come off. The antenna motor is on the top of the unit and is only held on with 2 screws. You take off the two screws and lift it off of the unit. when replacing it you have to make sure the antenna is properly positioned on the shaft of the new motor to make sure it will turn properly. Not a difficult repair.
Oct 30, 2017 | GE Microwave Ovens
Hello, my microwave is not heatting up the food, I am also missing the stirrer cover, could this b the reazon?
it sure is, with the stirrer cover missing it will arch and take out the mag tube, sorry but time for a new unit its cheaper than fixin it
Jun 07, 2010 | Panasonic NN-T655SF Microwave Oven
Getting sparks when in use Whirlpool GT4185SKB. This was made in 2003. What is the problem? If not possible to repair, is it still available new? Thanks.
If your microwave has a turntable its probably just burnt food inside or above the oven chamber that has carbonized. If it doesn't have a turntable its possible the stirrer above the oven chamber is stuck and not moving the microwaves around, therefore causing over heating and arcing. It also could be that the stirrer blades are hitting inside. Hope this helps
Feb 21, 2010 | Whirlpool GT4185SK Microwave Oven
Lubricant leak from round disk on the inside top of the microwave (piece has open and close written on it).
That would be the stirrer cover, and the leak is probably grease that has gotten into the area above the cover.
The cover, stirrer and exposed area under the cover needs to be cleaned thoroughly to prevent arcing and to allow for proper stirrer of the weaves for even cooking.
You can find handy exploded views and order any needed parts by model number here.
Sep 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
What is a stirrer cover, the plastic part over the fan inside the top of my Sanyo microwave is burning.
That burning part is referred to as the stirrer cove, unless you have one similar on the bottom.It's like plastic pie plate. The fan stirs the microwaves and heat in simple terms.
Unless food is burning off it , I would be replacing the unit or have a qualified, trained microwave tech service it. You need a microwave leak detector to work on them safely. Given the cost most are disposable these days. Be Safe on this one
Sep 13, 2009 | Whirlpool GT4185SK Microwave Oven
Microwave pops and sparks when running. Nothing
in the top of unit is a round cover and damage is coming from here. This is serious and needs to be checked out. the cover contains a stirrer that moves waves around<<circulates them>> in this cavity probably paint is thin and allowing waves to penetrate metal of cabinet. Call manufacturer and see if there is anything they will do for you before taking it upon yourself to either get repairman or get rid of unit.stirrer is probably damaged and cabinet burned from waves.
Apr 26, 2009 | Whirlpool GH8155XJ Microwave Oven
Whirlpool GT4185SK Microwave Oven Logo
564 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Gerry Harvey
Gerry Harvey
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
