Question about Yamaha RX-V730 Receiver
How to hookup yamaha rx-v730 receiver to projector & cable unit.
How to hookup yamaha rx-v730 receiver to sony cineza projector & comcast motorola cable box
    Problem Solver:
  • 4 Answers
Hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
Posted on Oct 01, 2009
tech48
  • 624 Answers
SOURCE: Yamaha RX-V663 Not Providing 1080 Signal
First let me say that you have stated your problem very well. I completely understand the issue you are having.
I have been repairing a/v systems since they started selling them.
By your description of your problem, it is obvious that you have isolated the problem to the Yamaha.
Despite what Yamaha tech support say's, it is their problem.
I have been dealing with tech support for a lot of different manufacters for many, many years. I repair under warranty over 20 different brands, but not Yamaha. I have repaired plenty of Yamaha receivers but none with this particular problem.
It is not uncommon to find tech support people who don't know as much as they should about their own product.
Since I don't have the instruction manual or a service manual forthis model I can only be of minimal help.
What you can do, if you have your instruction manual, check it over closely for this subject on how to change the settings for the HDMI. If you can not find this particular issue, it is possible that the Yamaha doesn't support 1080i. I would be surprised if it did not, but stranger things have happened.
Another thing you can do if you can still not find an answer to this problem is to take it in to an authorized Yamaha service center.
If you have recently purchased this Yamaha, it will be under warranty. They get at least 1 year. Tell them the problem you are having and if they do not know how to solve it right there on the spot, or give you an answer that satisfies you, leave it with them
to have it fixed. If they are an authorized service center they will have to fix it or get it replaced for you if it is under warranty. It may need a firmware upgrade to the digital board. If that is the problem, then they can do it for you.
Let me know if you need any more help.
Sorry I wasn't more help, but an authorized service center may be your best bet.
Posted on Jun 26, 2008
robotek
  • 1512 Answers
SOURCE: comcast remote
Hi robches
Odd, what model Comcast do you have. Yamaha remote codes have been pretty much the same for 20 years. Even the oldest receiver remote will still work the vol on a newer unit. Get back to me with the model of the remote and I will see what I can work out for you.
cheers
robotek
Posted on Jul 06, 2008
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
SOURCE: zune and yamaha RX-V663 Receiver
Buy the Zune A/V kit and hook it up to a non used rca port on the back. Look for the older ones for the 30 gb units, they are much cheaper than the new ones and it takes 10 seconds to modify them to use on the newer units. The A/V kit has 3 rca plugs, one for sound and 2 for video. If you pick a source that can play video and sound on your receiver, then the screen on the zune will display on your television. The A/V kit has a remote with it also so you can control the zune from the room. I have not tried it, but since the Zune remote is IR then if you have a good all in one remote, such as a harmony, you may be able to program the codes from the Zune remote into it and even be able to control your stereo and Zune from one remote. Hope this helps.
Posted on Feb 28, 2009
axebro112
  • 56 Answers
SOURCE: Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
Posted on Mar 19, 2009
How do I reset my Yamaha Rx-a730
How do I reset my Yamaha RX-V730 A/V Receiver? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 31, 2013 - I'm stumped on how to reset this receiver. I have no remote and just purchased a Powered sub woofer and it doesn't work that loud through the ...
RX-A730 - Yamaha Downloads United States
download.yamaha.com > Support > Downloads
13 items - ... About Yamaha. My Account ... Downloads for RX-A730. Find Your Model .... RX-A730 Owner's Manual, 14.07 MB, 4/17/2013. French, Manual, pdf ...
How do I reset my RX-V1800 parameters to the factory ...
faq.yamaha.com > Support > FAQs > Search Result: RX-V
Nov 13, 2010 - YAMAHA ... Power the RX-V1800 back on using the [Master On/Off] button and the receiver is now set back to the original factory settings.
Resetting/Initializing the receiver to factory settings - RX ...
Feb 08, 2016 | Yamaha Audio Players & Recorders
Can I download the speaker wiring instructions for surround sound, lost mine
try here : https://www.manualowl.com/p/Yamaha/RX-V730/Manual/87206
Dec 20, 2015 | Yamaha RX-V730 Receiver
What output jack should a wireless headphone system be connected to for use by a hearing impaired person, while still allowing sound fron the external speakers for others in the room to listen to? The...
The REC OUT jacks on the back are usually the best as they are not affected by the system volume. You'll need an RCA L and R Male to Headphone (1/4" female) adapter (available at Radio Shack and online sellers).
Jan 03, 2011 | Yamaha RX-V730 Receiver
Need an drawing showing hou to connect yamaha rx-
Hell Fixya customer,
Here are two links for the Yamaha receiver, and the Sony user manuals.
Please look through them concerning your specific hookup. If you still have questions or need help, please let me know.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V430e.pdf
http://www.sony.com.au/support/product/kdl-52z5500
Thank you for using Fixya
May 01, 2010 | Yamaha RX-V463 Receiver
Yamaha RX-V730 OSD problem
I assume you have a component connected source coming into the Yamaha to give it sync and you are component connected out to the monitor. If you have no input you won't have osd on component only without a signal to sync lock.
It is always possible that the 730 doesn't actually have component overlay for osd, just its a 2in 1 out switched affair. Hence the manual says you also need the composite/ Svid as well...They certainly don't use both at the same time. Newer units have full up + down video conversion but at this age it won't have.
Oct 31, 2009 | Yamaha RX-V730 Receiver
How can I reset all settings on my yamaha rx-v730 to factory default?
Use Advanced Setup mode - see the manual. From standby press both STANDBY + STRAIGHT buttons, then choose INIT / ALL.
Oct 05, 2009 | Yamaha RX-V730 Receiver
Yamaha Rx-v730 - only hear "click" when try to turn it on
That may due to a bad power transistor, huge current flows when it's powered up, protection circuit kicks in and switch off the unit. Get to repair shop for check up and replacement.
Mar 07, 2009 | Yamaha RX-V730 Receiver
No output on left main speaker on Yamaha RX-V730
To the shop.Do a web search and check around carefully for someone with a good reputation.
I have a shop but I'm in Vermont.
Feb 23, 2008 | Yamaha RX-V730 Receiver
Yamaha av receiver rx-359
go to best buy and buy a new recever
Jan 12, 2008 | Yamaha HTR-5560 Receiver
Yamaha RX-V850 receiver
how can i hook a subwoofer into yamaha RX-V850
Dec 25, 2007 | Yamaha Audio Players & Recorders
Yamaha RX-V730 Receiver Logo
648 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
