How do i replace heat element on kenmore model 253.79184 window type room air conditioner
Illeagle
  • 525 Answers
SOURCE: kenmore window air conditioner
Below is a link to the model that you describe. This link shows a parts breakdown and cost feature. From the parts description, I was unable to locate a customer replaceable fuse. I have never heard of a fuse inside of an a/c before but I just wanted to be sure. It appears that this is electronically controlled model, so
make sure you have adequate voltage and grounding to your outlet before you call for service.
http://www.retrevo.com/s/kenmore+air+conditioner+580.74124400?rt=tr&p=http%3A%2F%2Fwww.appliancefactoryparts.com%2Fairconditioners%2Fhelpcenter%2Fbreakdowns%2Fkenmore%2F
Posted on Jun 03, 2008
  • 17 Answers
SOURCE: Dimensions of Kenmore Window air conditioner 75135
Dimensions Width 24 in. Depth 20.09 in. Height 14.41 in.
http://www.dealtime.com/xPF-Kenmore-Kenmore-13-200-12-900-BTU-Multi-Room-Thru-the-Wall-Air-Conditioner
Hope it helps!
Posted on Jun 27, 2008
  • 25 Answers
SOURCE: My CV-13NH portable type room
If its blowing air, but not cold, the compressor isn't engaging. There are many different possibilities on this.
Bad compressor, unit out of gas, bad run capacitor, etc, all could cause this, even a bad control panel.
Hope its something simple.
Greg.
Posted on Aug 18, 2008
  • 15 Answers
SOURCE: Window Air Conditioner
Second try....
Any unit can be recharged, however, its not cost effective to repair most window units unless they are under warranty.
Posted on Sep 18, 2008
  • 1150 Answers
SOURCE: i have samsung split type room air conditioner,
http://aircon.ru/pbc_download/files/f1215245089.pdf
check out this web site as it has your items manual. It may help you trouble shoot what's going on. There is a trouble shooting section.
Hope this helps.
Posted on Feb 03, 2010
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    1200btu kenmore air conditioner with heat no heat
    your heating element could be out. Is this a heat pump type or a heating element?
    Jan 03, 2014 | Heating & Cooling
    Heating element for reiker room conditioner chalet ancient bronze model
    I would look for a bad thermostat on or near the heating element. If your not sure with electrical work, it might be best to replace the whole thing. Most cieling fans cost less to replace than repair.
    Dec 13, 2013 | Reiker Room Conditioner Chalet Ancient...
    My AC 1200BTU work in heating 5min. and than stopped
    Check temp setting and also room sensor. Setting must be minimum 3 degree more than room temp. Check continuity for sensor. If open replace it. Check coil , air filter and heater element are cleaned.
    If high amps, replace heating element. Thanks.
    Feb 07, 2011 | LGLXA1230 Air Conditioner
    The unit dosn't heat
    Check heater element has power. And also setting temp must be minimum 3 degree + than room temp, with heat mode. If RV system, check power to RV. If not PCB problem. If power to heating element, still no heat, replace heating element. Thanks.
    Jan 27, 2011 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
    The Heater is not working! It has been on for about an hour and is still blowing cold air!
    To get proper heat, keep your temp setting at +5 degree than your temp and also mode in "heat "position. If still noheat, check your heating sensor for closed circuit by an OHMs metre.It it'swith RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
    Jan 24, 2011 | GE Built-In Room Air Heat Cool Air...
    Window unit heater blows but dont get hot
    To get proper heat, keep your temp setting at + 5 degreethan your room temp and also mode in "heat "position. If still no heat, check your heating sensorfor closed circuit by an OHMs metre.It it's with RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
    Jan 13, 2011 | Kenwood Heating & Cooling
    Kenmore model 58072187300 a/c and heat window unit. When I Set on heat , i barely feel the air get warm.
    Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heating element check power toelement. If power is there but still no heat means element defective. Replacenew heating element. Thanks
    Jan 10, 2011 | Maytag M7Y15F2A Air Conditioner
    Blows warm air but after a few mins turns to cold air...
    Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
    Jan 02, 2011 | Kenmore 75124 Wall/Window Air Conditioner
    My a/c will not heat up. I have a Samsung model: AW12ECB7
    I think it's window 1 TR. Window a/c having heating element behind cooling coil. Please check your thermostat setting +5 degree from your room temp. and also model should be in heat mode. If still not heat works, check power to heating coil with volt meter. If not may be heating sensor problem. Replace it.
    Dec 25, 2010 | Samsung Heating & Cooling
    Heating & Cooling Logo
    101 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Donni Steen
