Question about Whirlpool Games
Preheat timer will not work - Whirlpool Games
My water heater shuts down in cold weather. How do I fix this problem
Add tempering tank.
Tempering tank made from old tank-type water heater, or small tank heater will passively heat incoming water.
http://waterheatertimer.org/Tempering-tank.html
This works because tankless can only raise temperature so many degrees. If water is very cold, tankless cannot keep up, so the sensors shut down the unit.
Passively preheating water... or using a small tank connected to power can preheat water enough so tankless works.
Also delime tankless each year will help remove natural scale that builds up inside tankless heat exchanger.
http://waterheatertimer.org/How-to-delime-tankless-water-heater.html
Gene
Water Heater Timers Save Money
Feb 13, 2015 | Water Water Heaters
Washing cycle does not complete, a tap symbol comes on what could be the problem?
1) the water must be preheated, the heating elements can be faulty 2) timer: see the contact dirty, loose wires, burn, or break wires, repair or replace the timer.
Jun 19, 2012 | Dishwashers
The heating cycle does not work, if the pneumatic switch is made the element does come. However in the cycle it does not work
1) THE WATER must be preheating, by the heating elements and thermostas, if this elements fail the machine will not work. 2) Timer; test for defective, repair wires loose, broken, or burn. God bless you 5_10_2012_10_51_03_am.gif5_10_2012_10_51_19_am.gif5_10_2012_10_51_47_am.gif
May 09, 2012 | Dishwashers
I cleaned the oven yesterday and today the middle light (not on and not preheated is flashing) and the oven won't light
Check the timer, it is possible that, on models with mechanical timers, the timer may be in a state where it is not "off" or "on". Good luck, Rob.
Dec 30, 2010 | Kenmore Ovens
My oven will not heat up at all.
make sure your cooking timer is on manual....
Feb 01, 2009 | Whirlpool RBS305PD Electric Single Oven
Preheat worksoven wont bake
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Nov 06, 2008 | Tappan 30IN ELEC IGNa Oven
Preheat Freezes
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Otherwise, the temperature sensor / thermistor may have failed.
If you don't have the manual, you can download GE owner's manuals and installation instructions here.
Let us know if wee can help further.
Oct 11, 2008 | GE Advantium 120 Convection/Microwave Oven
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Whirlpool gs475lems range oven problems
my oven was converted to LP gas we move overseas.It worked for about a year then all of a sudden the oven stopped working. The burners work perfectly but the oven just keeps clicking after preheat is finished. We replaced the upper electronics board so what could it be now
Dec 02, 2007 | Whirlpool GS475LEKS Gas Kitchen Range
Games Logo
Top Whirlpool Games Experts
Lesley Cameron
Lesley Cameron
Are you a Whirlpool Game Expert? Answer questions, earn points and help others
