Question about Kenwood KAC-9152D Car Audio Amplifier
Power wire volts go down when turn the car on
With the car off the power reads at the amplifer over 12 volts....then when i turn my car on the power goes down to 4 volts.......need help baddddddddddd
  • howdoiuhhhh Jan 29, 2009
    yes my power wire is hooked straight to the battery with a 100 amp fuse block a foot away.... i replaced that but no luck
    Scholar:
  • 116 Answers
Is the power wire going to the battery? Is the ground wire short (3-4 ft) and connected securely to a GOOD metal groun source? Are you using an AGU fuse holder at the battery? Reason I ask these questions is you migh have a weak connection somewhere or a bad fuse that looks like a good fuse. When the amp is turned on, it requires more amperage that at a standby mode. Hit me back.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
  • Larry Tezekjian
    Larry Tezekjian Jan 30, 2009
    OK, That's a much bette fuse link. Now,did you read the voltage at THE AMP? If you DON'T get 12V AT THE AMP, I want you to take another reading from the AMP's power to a DIFFERENT ground. If you get 12V then, you have a bad ground. Hope you find something.
    Larry T
    Winona Lake, IN
    http://www.cybersoundsaudio.com/cybersou...
My car is a grand voyager
From memory these are an amplifed system, you will need to identify the turn on wire and pass a 12 volt trigger down it.
Dec 16, 2013 | Car Audio & Video
2003 eclipse driver window frozen up good power to switch moter dead
Hello! Set your meter to read 12 volts...Pry the up/down switch out...Turn on key...Test for +12 volts on the Yellow wire on the switch...Send a comment...
Guru..............Saailer
Oct 25, 2011 | 2003 Mitsubishi Eclipse Spyder
12 volts to amp, when connected no volts, it turns on in my friends car.
The ampliflier require an amount to power volts to perfrom. You friends car may have a power stabilier installed to produce appropiaet supply to stereo systesm. usually, a direct wire from the engine to the amplifer may least function as manufacturers default specifcation. If the amplifer performs at all, a fuse is blown to protect the devices in wiring cuircuits. if the device functioned in another car, it is not damaged. Consult with an auto electrician to attain appropiate wirign or acqurire the component parts to wire the vehicle. Important notes. Each device usually will have an instruction on installing. However, the power source from engine depending on type of vehicle may require regulators to share the current to stereos amplifiers and speakers.
Jan 29, 2011 | Clarion APA450 Car Audio Amplifier
Installing remote starter what does run start posisition mean
When testing the polarity of the vehicle's main power wires for remote starter installation; the run position is the vehicle running. The ignition, accessory and battery wires should read 12 volts in the RUN position. This same group of wires should read 12 volts in the ON position. The ignition, starter and battery wires should read 12 volts in the START position. The accessory and battery wires should read 12 volts in the ACC position. The battery wire should read 12 volts with the key OFF.
Oct 18, 2010 | 2000RS-M Remote Starters Manual...
Can kicker 1000x1 amp detect if my speaker is bad and turn itself off?
The Kicker 1000x1 Amplifier does not turn off if their is an Open Line (blown sub) on the Speaker Terminals.
  1. Remove all Speaker Wiring from the Amplifier, leaving the Power, Ground, Remote, and RCA wires plugged in.
  2. If the Amplifier fails to turn on, check your Remote wire for power.
  3. If the Remote wire is powering up with the Head Unit (should be anywhere from 5-12 Volts), check your Power wire for +12 Volts, and check your Ground wire.
  4. If you are getting +12 Volts Power and your Remote wire is putting out 5-12 Volts but your Amplifier still won't turn on, it will need to be serviced.
Jul 24, 2010 | Kicker ZX10001 Car Audio Amplifier
No blue power light and doesnt turn all the way on no starting beep gateway gt5220
I would suspect a bad power supply. Before doing anything make sure power is actually getting to the computer. Check the power cord with a volt meter. You should have around 115 volts. If all is well you need to see if the power supply is putting out the correct voltage. Open the PC up and set the multimeter to DC voltage.
  1. Turn off the PC, but do not unplug it. Open the system unit. Set the multimeter to read DC volts in the next range higher than 12 volts. Locate a power connector similar to the hard drive (or CD-ROM drive connector that is unused) and turn on the PC.
  2. You can also unplug a drive connector and use it. Turn on the PC and insert the BLACK probe into the power connector on one of the BLACK wires. Touch the RED probe to the YELLOW wire on the power connector.
  3. The multimeter reading should be +12 volts. Now touch the RED probe to the RED wire and the reading should be +5 volts. If no readings or different readings occurred, you’ll have to replace the power supply. If the readings were correct, you should check the P8 or P9 connectors at the motherboard. These connectors may also be named P4 and P5. To check these connectors, perform the following:
    • Insert the BLACK probe into P8 at one of the BLACK wires. Insert the RED probe into the P8 connector at the RED wire. The reading on the multimeter should be +5 volts.
    • Check the power going to the motherboard connections by inserting the RED probe into P8 at the YELLOW wire and you should get +12 volts. Leave the BLACK wire touching the BLACK wire at the P8 connector. Check the BLUE wire and the reading should be a -12 volts.
    • Now move the BLACK probe to the BLACK wire on the P9 connector. Test the WHITE wire by inserting the RED probe and the reading should be -5 volts. Check the RED wires on the P9 connector and you should get +5 volts on each red wire. You won’t get exactly 5 or 12 volts, but the readings will be very close, such as 5.02 volts.
    • If the Power Supply is a couple of volts off in either direction, such as when the RED wire should be reading -5 volts but it reads -8 volts, or if there are no readings, replace the power supply. Curtorsey: IT Professionals
Mar 09, 2010 | Gateway GT5220 PC Desktop
Clarion stereo in1997 mercury marquis wiring hook up to amplifer
make sure the speaker wires in the car do not have one side grounded.the output on the clarion is a floating output and cannot be grounded.the best solution is to look at the wiring on each of the speakers,and match them out to the ones on the clarion.the most common colr code is white front left,gray front right green rear left and purple rear right.each speaker has a plus and minus.mixing them up will result in the speakers being out of phase and result in poor bass performance.i would wire the wires directly to the clarion using crimp connectors.the first thing i would do is power up the stereo out of the car to 12 volts,and using a speaker make sure you have sound coming out.the yellow wire which is the clock/memory is a must to be connected to constant 12 volts or no sound can result
May 26, 2009 | 1997 Mercury Grand Marquis
Power supply suddenly 'dead'
You check the power supply using multimeter. but before everything make sure the you are getting power from the power outlet.
Here is how you can check the power supply with multimeter
If the wall outlet and the power cord are good, make sure the connection at the motherboard is secure. Then you may have to face the fact that the power supply itself is bad. If you have a multimeter, you can test the power supply output before purchasing a new one. Simply follow these steps:
Mar 22, 2009 | Computers & Internet
I have my amp hooked up but it isnt getting any power can you tell me if i have a bad amp or if i need the speakers and sound for it to come on?
With all amplifiers for a car, you must have the main power connections B+ and ground connected, and then you must also have the remote turn on connected as well. This is the way the amp turns on. It comes from the radio and is usually the blue wire from the harness off the back of the radio. When the radio is turned on, the blue wire gets 12 volts sent to it so it can turn on an external device like an amplifier or the power antenna. Make sure you have this connected to the amp and that the radio is turned on. Then check the voltages at the power terminal of the amplifer. You will have the ground, the main B+ of 12 volts, and then the turn on voltage of 12 volts. If you have all of these, then you need to troubleshoot it more. It will turn on without the speakers connected, but I am not sure why you would want to connect it without the speakers. It will also turn on without the RCA cables connected for the audio input as well. But just to turn on the amplifier, all you need is those three things i mentioned. Let me know if you require any further help.
Jan 23, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
