Question about Haier HDP18PA Stainless Steel Free-Standing Dishwasher
Haier HDP18PA My washer doesnt start, it just beeps. Nothing happens no water draining or filling
  • luke_read Feb 01, 2009
    the light comes on but nothing happens, then it beeps, the light goes off and.....nothing....
Not sure of the background on your fault, but this may help:
I have an HDW202. I accidentally opened the door while it was running - a no-no, but there is no lock preventing opening the door while it is running - not idiot-proof at all, disappointing, really. Anyway, closed the door, the washer kept running, then water started to leak out the front door. I quickly turned it off, mopped up the water, and turned it back on. It pumped out the remaining water visible in the bottom, then started flashing lights and doing 10 beeps in a row, pausing for a minute, 10 beeps in a row again, etc. - it was stuck in this cycle. I tilted the unit forward, backwards, and side to side, while turning it on and off periodically to check for results. More water came out of the unit, and it started to behave normally while tilted, but not level. Eventually, after more tilting, it returned to normal behaviour when level. It seems it did not pump all of the water out initially, and this was causing it to malfunction until all of the residual water inside had drained onto the floor from tilting the unit.
Posted on Mar 10, 2009
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
I have a haier dishwasher and it has stopped working,it's not filling water or doing anything
Check the small sensor along the rim of the door/door jam. It may be stuck. Free the machnism an start washing. Another common problem that cuase those symtoms is a bad door gasket.
Apr 09, 2011 | Haier HDP18PA Stainless Steel...
I have a haier dishwasher but the water wont drain out of it. the power light remains on but turning the settings dial has no effect - looks like the pump may be blocked. how can i carry out a factory...
you maybe right but before doing machine reset button, you need to clean the machine be sure there's no jam in mechanical parts. also not all machine have reset button outside, some are hide and inside the power supply module so look for it and be careful.
Feb 04, 2011 | Haier HDP18PA Stainless Steel...
Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Jul 27, 2009 | Haier HDP18PA Stainless Steel...
Help
Tilt the machine 45-0 degrees and let it drain any excess water.. It also beeps when the leds flash also right? Drain the water and it will start right back up.
Aug 25, 2008 | Haier HDP18PA Stainless Steel...
Spin cycles doesn't work, tub full of water
HLP21E Haier Portable washing machine will not spin and drain water
Jul 08, 2008 | Haier HLP21E Top Load Washer
The washer keeps beeping and trying to drain as soon as it is turned on
I have a Haier HDP18PA with the same problem... I tried tilting mine backwards while running...this made a mess BUT the beeping stopped BUT the lights were still flashing. Turned it off and started it again and the lights still were flashing BUT no beeping. Decided to try tilting it forward while running ... made another mess BUT the lights stopped flashing. Turned it off again and restarted it and it is now running fine. Good luck!
May 05, 2008 | Haier HDP18PA Stainless Steel...
Haier HDP18PA
On another site, someone posted this: "I called (website), where it was purchased from, and they gave me the number for the manufacturer. Some standard troubleshooting did the trick and my dishwasher is working perfectly again. The troubleshooting involved tilting the dishwasher backwards at a 45-degree angle and letting any excess water drain out. They said ocassionally the water intake will be blocked and this process helps move anything that may have gotten in the way"
I was having the beeping problem too, and decided to give it a try, tipped it for a few, and found it to work!!! Hope this maybe helps!
Jun 09, 2007 | Haier HDP18PA Stainless Steel...
Haier HDP18PA Stainless Steel Free-Standing Dishwasher Logo
1,003 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Melissa Martin
Melissa Martin
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
