Question about Samsung Washing Machines
My Wf7600nas door won't open. There is laundry inside but I've ran the spin cycle several times so there is no water left inside. Also, the little "lock" sign is flashing
Yozzer6821
  • 116 Answers
SOURCE: Door lock light flashing
More likely the PCB needs replacing - common fault, you could try a new door switch first cost £5 new PCB £65+ but is easy to replace.
Posted on Nov 09, 2008
Macmarkus
  • 2605 Answers
SOURCE: My washer is flashing E:13; locked with wet clothes inside
Hello and welcome to fixya.
The E13 error code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
What you may have is either a clogged pump, improper detergent being used, ( must use "HE"/lo-sudsing detergent ) hence suds not allowing a proper drain cycle, or wires loose at the pump...the later being the least likely.
You haven`t mentioned if you`ve checked the pump...just hoses as you did mention.
Anyway, here`s the most likely way to remedy a E13 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say, hopefully you won't get wet. ( maybe you`re lucky enough to be close to a floor drain )
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
  3. Find a drill bit or small screwdriver that fits in the hole in the round door.
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves).
  5. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan ) There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out.
  6. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.
  7. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
  8. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "fixya" and good luck.
macmarkus :)
Posted on Jun 13, 2010
Testimonial: "Thank you! Ten p.m. on a Sat. night...no help in sight...you helped us fix the problem on our own. Thank you so much!"
dcramer531
  • 1654 Answers
SOURCE: My GE Adora front load
Did you get any error codes on the control panel? this sounds funny but have you cleaned the trap out? You have to clean the trap of the washer every so often (it is not mentioned in the manual. You take off the front bottom panel and you will see a round trap door to the right turn it and pull out and you can clean the trap make sure you put a pan under because water will come out as well. When the trap is full the cycles won't run. Usually this happens when there is water in the machine but lets try this anyway. Before you try this, unplug the machine, let it sit several minutes and plug back in, see if this helps before removing the filter trap.dcramer531_4.jpgdcramer531_5.jpg
Posted on Dec 07, 2010
  • 251 Answers
SOURCE: washing machine won't go thru spin cycle. Lid
Hi there the lid lock switch is faulty and needs to be replaced - cannot be bypassed unfortunately.
Posted on Jul 15, 2011
  • 6277 Answers
SOURCE: hi, i have an indesit
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 06, 2011
Washer won't drain or enter spin cycle
SHOULD BE THE LID SWITCH... THERE IS TWO SWITCHS INSIDE, ONE THAT STOP THE MACHINE, AND ONE TO LOCK THE DOOR. YOU SHOULD SEE THERE IS TWO PAIRS OF WIRES THAT CONECT WITH THE LID SWITCH, ONE PAIR IN THE FRONT, AND ANOTHER PAIR IN THE RIGHT SIDE, THAT RIGHT SIDE IS THE PROBLEM, INSIDE THE LID SWITCH MUST BE BROKEN. TRY TO MOVE THE PLATED LOCKING PIN IN THE DIRECTION THAT LOCKS THE DOOR, AND IT MIGHT DRAIN AND SPIN. IF THAT THE PROBLEM, YOU SHOULD GET A NEW SWITCH (MODEL 134101800), AND YOURE DONE.
GOOD LUCK
MARIO
May 07, 2013 | GE Spacemaker Washer and Dryer Electric...
My LG washing machine door won't open
UE is unbalanced load. Unplug machine for 5 minutes then plug back in. That may cause it to unlock.
Oct 14, 2017 | LG Washing Machines
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
Door will not open after cycle finishes
I had similar problem, but never found the cause, ended up spinning washing again and again until I could open door. Control system replacements are expensive , almost as much as a new machine.
Mar 11, 2017 | Zanussi ZWF14070 Front Load Washer
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Why is it that my washer is not completing the spin cycle,it is still very wet when it stop??
Hello there and welcome to fixya
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Sep 12, 2011 | GE Washing Machines
Clothes wet after spin
Hi, if clothes are wet after spinning, check.......
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Apr 13, 2011 | Whirlpool LSR8433K Top Load Washer
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
