Question about Panasonic DMR-EZ47V DVD Recorder/VCR
I have Panasonic DMR--Z48v, every button I press on the remote and the unit does nothing when RC2 shows up flashing on the unit display..
5 Suggested Answers
SOURCE: RC2 problems
Got this from Panasonic. Press the enter key and the number 2 for 2 seconds. This should return it back to default mode. It may take a couple of tries but it works!
Posted on Jul 07, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
SOURCE: Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Posted on Sep 20, 2009
SOURCE: Panasonic DMR-EZ485V. Remote stopped working when
Panasonic website under FAQs. Using code shown on dvd readout,
such as RC2, press 2 & enter or ok, hold for 2 seconds, and machine
will reset connection between remote & dvd recorder. So stupidly simple it works.
Posted on Feb 16, 2010
Can't get into the setup on Panasonic dmr ez48v remote says rc2 I tried to switch to rc2 on the remote it does nothing
See if you can access the factory reset on the VCR, that should send everything back to normal.
Oct 23, 2016 | Panasonic DMR-EZ48V DVD Recorder
Panasonic DMR-EZ28 has RC2 display /l cant see an enter button to try pressing 1 then enter
the unit has been changed to remote control 2 mode. Look in the owner's manual and change the remote to mode 2 and you should be fine.
Feb 20, 2015 | Panasonic Televison & Video
The remote is not responding. it displays RC2 whatever button you push.
  • Go ahead and press and hold the #2 button and the "Enter" button on your remote for 20 seconds and this will return control to your unit.
Regards, Tony
May 27, 2011 | Panasonic DMR-EZ37VS
Feb 15, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Jun 04, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Mar 14, 2009 | Panasonic DMR-EZ27K
Jan 26, 2009 | Panasonic DMR-ES25 DVD Recorder
The remote doesn't work
press "enter/OK" and hold number "2" for about 3-5 seconds - this should re-sync remote
Jan 04, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
RC2 problems
That solution works great! Thank you so much...just hold the Enter and 2 down for a couple seconds! Thank You!
Jul 04, 2008 | Panasonic DMR-ES20EG DVD Recorder
DMR--EZ48V
Your DMR is telling you that it is set to listen for RC2 but your remote is transmitting RC1.
Two choices for a fix:
1. Put the remote back into RC2 mode by simply holding both the ENTER and 2 button for at least 5 seconds.
OR
2. Reconfigure the DMR to listen for RC1 by going into the function menus and selecting SETUP. Look for the remote control option. Change it to 1, it will currently display the value 2.
Enjoy.
Mar 19, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
63 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
