Question about JVC FS-G5 CD Shelf System
Unit turns on, then clicks off with a "protect" message
I have tried turning off and on, unplugging. The unit comes on, makes some noise, then shuts off after 3 seconds.
    President:
  • 3,130 Answers
You have a bad speaker on this unit or the audio output circuit is in need of repair. Try to disconnect all of the speakers and then turn on the unit. If it still stays in protect, you will need to have this unit serviced, unless you understand how these solid state circuits work. If the unit does come on without the speakers, turn off the unit and add one speaker at a time until the unit will not turn on. Disconnect that speaker and have it checked out or have the wiring checked out. Good Luck
Posted on Jul 15, 2007
Problem turning unit on
it may have an internal shout somewhere causing the speaker protection relays to kick out..
Jan 18, 2014 | Sony STR-DE935
Unit on but then iys shutting down
Can you please more setails in to what your unit is doing. Does the main start up screen come on then the tv turns off? Does it make a clicking noise? Does this happen every time you try to turn your unit on?
Jul 24, 2013 | Televison & Video
I have sharp cd pc3500 stereo system when i turn the power on the message on the screen shows PROTECT. I cant do anything nor any function work
Make sure the speaker wires aren't shorted together and that they are not freyed or cracked...the unit is in protect due to it's internal circuitry sensing a shorted output condition...this is in place to protect the unit should the speaker wires become shorted together. You can remove the speaker wires entirely and then turn on the unit to see if it comes on...if so then I would look at each wire carefully to make sure they look good..of course if the unit comes on and the wires look good then you may have a bad speaker component...Now, if the unit stays in protect after you unplug the speakers, then the unit probably has a blown audio output stage inside the circuitry and will need to be serviced.
Jan 05, 2011 | Sharp CD-PC3500 CD Shelf System
The lamp indicator turns on
The clicking noise is the protection switch that keep shutting down the unit. This happens when an internal fault had been detected.
Do the following:
Unplug the unit from power for some time.
Remove the bulp and refit it in place.
Restart the unit.
If still in protect mode (clicking , lamp light and no start), then there is a fault.
When the problem is the lamp, the lamp light will come on, but usually protection does not click.
Before buying a new lamp that is expensive, have the projector checked, testing with particular attention the high voltage board that will supply power to the lamp. That may be the fault.
If you have a replacement lamp in storage replace the lamp first.
Jul 20, 2009 | Dell 2200MP Multimedia Projector
Audio
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 21, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
When i turn on my samsung HT-Z110, the word "Protect" appears...
Bad speaker wiring.
Internal fault.
Regards.
Mar 19, 2009 | Samsung HT-Z310T Theater System
Power turns off
Bad speaker wiring.
Internal fault.
Regards.
Jan 31, 2009 | Samsung HT-X50 System
Unit shuts itself off after 10 -15 minutes
Bad speaker wiring.
Internal fault.
Regards.
Jan 08, 2009 | Samsung HT-WX70 Theater System
Protect mode shuts down the receiver
If this happens only when connecting the receiver, chech the receiver cable. If the cable is fine, receiver connector at the back of receiver is faulty.
Bad speaker wiring.
Internal fault.
Regards.
Dec 23, 2008 | Samsung HTZ-510 Theater System
Magnavox MRD-510- when I plug it in, it just makes a clicking noise and the power button keeps flashing. When I unplug this unit it continues to click for 5 seconds. Only owned for about 5 months and now...
Bad speaker wiring.
Internal fault.
Regards.
Nov 30, 2008 | Philips Magnavox MRD510/17 Theater System
JVC FS-G5 CD Shelf System Logo
316 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
