Question about Canon Office Equipment & Supplies
E020 0060 and yellow missing
Fitted new yellow drum - error changed to E020 1060. Unable to clear.
3 Suggested Answers
  • 134 Answers
SOURCE: change drum soon will not clear after new drum inserted
This machine is reset with a plastic sheet that come in the new drum unit. When the drum is inserted for the first time, the sheet slides out and trip the exit sensor in a certain way. Then the counter is cleared. If you still have this clear plastic sheet, then you can reinsert it into the top of the drum unit and try it again.
Posted on Jun 30, 2008
  • 857 Answers
SOURCE: Oki 7300. yellow toner sensoe
This is a problem with toner lock lever
Check toner lock lever is in position - Seek attention of service person if restarting the printer does not correct the problem.
Look into this ink :
http://www.c5200.co.uk/index.asp?menumode=0&content=sensorerror
Posted on Oct 05, 2010
Reset Drum life MFC 9440CN
Not sure if this Brothers is the same but normally open front were you install drum and toner, machine on depress, menu button or clear button, display will show 1 or 2 to tell
you to reset drum count.. hope this works
Mar 04, 2016 | Brother MFC Office Equipment & Supplies
Error code e000020-1060
Problem with drum/developer,in your case yellow
Oct 11, 2013 | Canon imageRUNNER C3200 Copier
Dear Sir, Our Scanner was showing to change magenda toner and we change with new one, but after end of the process it is showing the error code of E000020-81, even after shutdown 3 times. What else I can...
The error code your gettting E000020 is a drum code (imaging unit). You however do not have the complete digits after the E000020-????. Those digits define which drum needs to be replaced. You don't need to go into service mode to clear the error. You only need to buy the correct drum and put it in with the power off. Once it is replaced and the machine is turned on it will register and clear its internal error code. To help, here is what the ending codes mean. The xx's have further meaning but in most cases all roads lead to the same result (replace drum imaging unit).
-01xx yellow (Y)
-02xx magenta (M)
-03xx cyan (C)
-04xx black (K)
Jun 25, 2011 | Canon imageRUNNER C3200 Copier
Error message print unalbe 23
This message means you have a Drum drive motor failure, for either the black or yellow Drum unit.
Check for a seized opc drum.
Apr 14, 2010 | Brother MFC-9840CDW Laser Printer
I have a new OKI B410d printer which is givng error message "Install Toner 613 Toner Missing" yet toner cartride intalled adn plenty of toner in drum
It is more than likely that you have an incompatible toner fitted to the drum unit. Either a generic cartridge or b430 or b440 cartridge which is not compatible with b410's. Beyond that it may be a faulty drum unit. Hope this helps.
Sep 08, 2009 | Oki Electric Industry B410D Laser 30PPM...
Canon error displayed on LCD E000020-0160
The developer concentration
target value is faulty (set when a
new drum is fitted; the value is
extremely small).
The fault is with the yellow drum unit, normally replacing it solves the fault.
Feb 03, 2009 | Canon imageRUNNER C3200 Copier
Blinking error light CH will not let machine turn on
side door of copier is open just close it properly .if error stills just check by pressing start key what is sub code if 00 developer unit is missing if 01toner catridge is missing .just check all connectors of developer unit and toner unit.code will bi removed
Jan 20, 2009 | Sharp AL 1631 Copier
Error E100
The most common cause for E100 is the drum unit. At the rear of the drum unit should be a small peg pointing into the machine. This gets broken off. It's purpose is to opperate a laser cut off shield when the drum is removed so to prevent laser exposure. If peg is missing laser will not be detected by the system and give E100. Can be repaired or will require a new drum if it has done more than 40 to 60K copies.
Dec 31, 2008 | Canon PC-1060 Black and White Copier
158 people viewed this question
old marine
old marine
