Question about Canon CanoScan Office Equipment & Supplies
Canon 8400f error code 2.178.0
This error occurs after saying "Adjusting lamp. Please keep the document cover closed". Lamp can be heard for a few seconds.
SOURCE: Error message
Scanner sensor is defective,,,you need a new scanner.
Posted on Dec 07, 2007
SOURCE: Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
Posted on Oct 15, 2009
  • 3 Answers
SOURCE: My Canon 8400F worked yesterday and today it is
First, make certain that the flatbed scanner lid is securely shut.
Second, unplug the power and USB cables from the rear of the scanner.
Third, deposit the Canon 8400F scanner in the nearest garbage receptacle where it belongs.
Hope this helps.
Posted on Oct 21, 2009
SOURCE: My canoscan 8400F suddenly stopped
You have to remove the white protective sheet from the the lid. Once you remove it you will be able to scan film. Also make sure the lock button is not in the lock position.
Open the Canoscan Toolbox.
Click the Save option.
Put a check in the box that states "Display the Scanner Driver".
Click Scan.
Click the Advanced Mode tab.
Make sure Select Source is set to "Platen".
Click the Preview button at the top left
Another thing is this can be caused by a faulty FAU cable. One or more of the eight wires within this cable has fractured
Posted on Oct 18, 2010
SOURCE: ERROR MESSAGE lamp was over Canon DR-1210C driver
lamp was over Canon DR-1210C driver verion 1.01.10601.23003(-4430)
Posted on Feb 25, 2011
I have tried replacing all ink cartridges with brand new ones but it keeps saying Error U052 ? I am not really sure why it won't recognize the ink cartridges especially because they are from Canon
The error code indicated, the print head is defective, so it will not get solve by replacing any number of cartridges. Just follow the steps below to reseat the print head, if that does not help, then replace the print head.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
    *MP800R shown
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
  5. Raise the print head lock lever.
  6. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  7. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  8. Insert ink tanks into the print head.
  9. Press the mark <PUSH> on the ink tank firmly until you hear a click.
  10. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  11. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Aug 28, 2012 | Canon PIXMA MP530 All-In-One InkJet...
My canoscan 8400F suddenly stopped working last week. I had been scanning slides thru Photoshop when on my next scan attempt, I got this message: Cannon scan for these reasons: -The original may not...
Click Scan.
Oct 16, 2010 | Canon CanoScan 8400F Film Scanner
When trying to scan a document on my CanoScan 8000F, I got an error code that read: "Cannot scan for these reasons: ? The original may not be set correctly. ? The Film Adaptor Unit Protective Sheet may...
Check that the lamp is not burning out, or replace with new lamp. Check the glass area to make sure there isn't a thin plastic sheet on the glass. This should be removed. Let lamp warm up for about 5 minutes before using.
If your problem still persists, it's not your computer, but likely the scanner software inside the scanner itself.
Apr 17, 2010 | Computers & Internet
My Canon 8400F worked yesterday and today it is not responding. I am getting an error message after the scanner determines what type of photo is to be scanned. It says: 1)Original may not be set...
Hope this helps.
Jul 04, 2009 | Canon CanoScan 8400F Flatbed Scanner
Won't scan today
I got no help from you. Called Canon USA and got immediate assistance, which resolved the problem. Please don't contact me anyomre. Thank you.
May 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
CanoScan 8400F
Try this:
Open the CanoScan Toolbox.
Click Scan.
Click the Preview button at the top left.
If the error still occurs, then most likely it will be a service issue.
One thing to check...see if the inside lamp illuminates when you turn the scanner on using the power button at the back left side of the scanner.
May 13, 2008 | Canon CanoScan 8400F Flatbed Scanner
Error code 510
If the error code is actually 5100, this is how you fix it:
Open the paper output tray.
CAUTION:
a. Do not try to manually move or stop the Print Head Holder.
b. Do not touch any metal parts.
Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
Note:
Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
Note:
Ink Tank Lamp
Note:
When closing the scanning unit (printer cover), be careful not to jam your finger.
When starting printing next time, the print head cleaning launches automatically.
If you haven't installed ink recently -- then you are out of ink and that is why you ink out light is flickering.
Hope this helps.
Good Luck.
Apr 08, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Canon PIXMA MP160 problem
i need help getting this going
the error button keeps blinking htis is an new scanner printer
the alram button is blinking on and off
Jan 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer and scanner not working
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
588
Error message
Dec 02, 2007 | Canon CanoScan 8400F Flatbed Scanner
469 people viewed this question
old marine
old marine
