Question about Lexmark Z1420 Printer
No cord for installation
I sthier anyway to install the printer through wireless or through you withour a printer cord
You will need to buy the printer cable you can get one from pc world they are about £10
Posted on Jan 25, 2009
Tip
HP Printer on Network ( Wired or Wireless )
If you are not able to setup HP Printer on Wireless Network..
1. Connect the printer thru Ethernet Cord.
2. Complete the Software Installation ( choose Wired Network )
3. Once you have Completed the Installation, Disconnect the Ethernet ( network ) cord from Printer Port
It will print and Scan Wireless assuming the Wired IP is WIRELESS IP.
on Jun 17, 2010 | Office Equipment & Supplies
Why does my Dell V515W - wireless printer won't printer but one page and I have to restart the computer continuously?
Firstly Check if u are installing the [Dell V515w] wireless driver of the printer or just installing the dell v515 driver , i would recommand u go to www.support.dell.com and look for the printer and download from tthe site and then download and install it , elsz try to add a printer from devices and printers and use the OS drivers to install it, also the printer needs to be with in 30 feet to be able to detect by the router to be print from the system
Oct 23, 2014 | Dell Office Equipment & Supplies
Vista driver
The print driver solution for this product is included with the Microsoft Windows Vista operating system and is already on the computer. No special driver download is necessary for this product.
Please follow the simple instructions below to easily get the product working with Microsoft Windows Vista Operating system.
Installation Instructions
Direct Connection (Parallel & USB connector)
  1. Verify that the printer is turned ON.
  2. Connect the Universal Serial Bus (USB)/ Parallel (IEEE 1284) cable to the printer and to the computer
  3. Click on the Close button when the message "Your devices are ready to use" is displayed in the screen.
  4. The printer is now ready to accept the print job.
Wired Network & Bluetooth Connection
NOTE:For Bluetooth connected printer, please ensure that the printer's access mode is set to public mode for detection.
  1. Verify that the printer is turned on.
  2. Click Start > Control Panel and then select Printers .
  3. Click on Add a printer .
  4. Click Add a network, wireless or Bluetooth printer . A list of detected wired network or Bluetooth printers will be displayed.
  5. Select the printer you want to install and click Next . Follow the on screen installation instruction to complete the printer driver installation.
Wireless Connection
  2. Ensure the printer's wireless network setting is set to the correct wireless profile matching the local wireless network/computer's wireless card setting.
    If you have previously configured the printer's wireless network setting, matching local wireless/computer's wireless card setting, please proceed to step 3.
    if you have NOT previously configured the printer's wireless network setting to match local wireless network/computer's wireless card setting, please follow the steps below.
    To set wireless network settings in an infrastructure network
    Connect the printer to the computer with the cross cable (included with the printer) or connect the printer to the network with a network cable.
    Press the configuration button once to print a configuration page.
    Open web browser, and type in the IP address that has been assigned to the printer.
    Configure the printer's wireless setting to match local wireless network/computer's wireless card setting.
    Unplug the cross cable/network cable.
    Activate the printer wireless network, activate the computer's wireless network profile.
    Proceed to step 3.
    To set wireless network settings in an ad hoc network
    Do the following to reset the printer's network settings:
    1. While pressing the Configuration Page button, press (Resume button) three times.
    2. Wait about 20 seconds, and then press (Power button) to turn off the printer.
    3. Disconnect the power cord from the printer.
    4. Wait about 20 seconds, and then reconnect the power cord.
    5. Press (Power button) to turn on the printer.
    6. Open the configuration utility for the computer's wireless network card, then create a new wireless profile with the following values.
      • Communication mode: ad hoc
      • Network name (SSID): hpsetup
      • Security (encryption): disabled
    7. Activate the wireless profile.
    8. Wait two minutes for the printer to obtain an IP address, then print a wireless configuration page to verify the following for the printer's network settings.
      • The IP address is NOT 0.0.0.0
    9. If one of the above conditions is not true then repeat the preceding steps. Proceed to steps 3 below.
  3. Click Start > Control Panel and then select Printers .
  4. Click on Add a printer .
  5. Click Add a network, wireless or Bluetooth printer , a list of detected printers will be displayed.
  6. Select the printer you want to install and click Next . Follow the on screen installation instruction to complete the print driver installation.
Dec 15, 2013 | HP DeskJet 450wbt InkJet Printer
How to connect printer to computer
I found this on the Dell support page for you:
  1. Insert the installation CD into the optical drive of the computer.
  2. The Autoplay window may appear, if so click Run Setup.exe.
  3. The User Account Control window may appear, if so click Continue.
  4. On the Welcome screen, click Install.
  5. On the License agreement screen, click I agree, if you agree with the license.
  6. On the Select your included software screen, click Continue.
  7. On the Check for updates screen, select No (this can be done later), then click Continue.
    • Anytime the Software or Hardware Installation window appears, click Continue Anyway
    • Anytime the Windows Security window appears, click
      Install this driver software anyway.
Choose below if this is the first time setting up the printer or if it is already set up and you are installing it on a computer.
(Set up means the printer has been taken out of the box, powered on, the ink cartridges have been installed and is connected to the wireless network.)
Mar 24, 2013 | Dell V313w AllInOne InkJet Printer
Installed new modem now printer will not work in wireless function
If you mean you installed a new wireless card. You will need to run the CD-rom that came with the printer and go through the connection wizard again
Most likely your best bet is to re-run the install cd-rom anyway, and go through the wizard again. see if that fixes the problem.
If not, post back to this site with what happened.
Sep 30, 2010 | HP Officejet 6500 Wireless All-in-One...
Says my operating system wont allow insalation running windows 7
Windows Vista and 7 sometimes won't allow installation of devices with unsigned or unvalidated drivers. Can you bypass that message and install anyway?
May 30, 2010 | HP Officejet 6500 Wireless All-in-One...
Canon MP 640 not recognized by MP Navigator EX 3.0
Your anti virus software is blocking the Canon software. Restore AV default settings.
Jan 31, 2010 | Canon Office Equipment & Supplies
Wireless upgrade
Resetting the All-in-One
  • Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Jun 08, 2008 | HP Officejet Pro L7680 All-In-One Printer
Lexmark Z1420 Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
