Question about Honeywell HE260A1010 Whole House Humidifier Humidifier
Honeywell HE260A wiring.
I have my humidifer hooked up, but can not get it to operate, I think it may be my wiring. here is how i have it hooked up, from the sail switch to the power supply:
Sail Switch:
white wire hooked to the common
red wire hooked to the norm open
the red and white are then routed to the back of the h-stat.
H-stat
one of the red wires from the sail switch is connected to one of the black wires. a second set of red/white is introduced(coming from he humidifer). the red is hooked to the other black wire. the whites from this wire and from the wire from the sail switch are connected.
Humidifier-
the red wire from the h-stat is connected to one of the black wires on the solenoid. a second wire is introduced from the power supply, its red wire is connected to the other black wire from the solenoid. the 2 white wires are connected together.
power supply-
i have a transformer from Honeywell that plugs into an outlet, red and white wires are connected to the back. i tested the outlet, power is being supplied.
where is my problem? water is being supplied.
  • 5 more comments
  • juliehummel Feb 04, 2009
    is the sail switch necessary?
    i'm using the wire (red,white) the humidifier came with. i do have the white wire that goes directly from the H-stat to the transformer. the red wire from the H-stat wire goes to the solenoid.i have another wire from the transformer-the red wire from the transformer goes to the other solenoid. the white wire from the transformer connects to the white H-stat wire that i mentioned above.
  • juliehummel Feb 28, 2009
    how do I check the fuse? the transformer is closed? i'm sorry, i can not follow the diagrams that were recommended, is there anyother solutions that can be provided?
    the transformer i am using plugs directly into the wall. do you have pics of the connection to the solenoid on the humidifier itself? it appears as though my connections match the pics that are provided.
    thanks
    There are no mineral deposits in the water line, water flows through when i disconnect it from the solenoid. power is being supplied directly through a wall outlet, through Honeywell plug.
    any other suggestions?
    also, how do i see other possible solutions that others have posted to answer my question?
  • juliehummel Mar 01, 2009
    i appreciate everybody's suggestions, but the humidifier is still not turning on.
    thanks
    thanks
    Scholar:
  • 144 Answers
Think of it this way. One side of the transformer can go straight to the solenoid valve on the humidifier. Then the wire from the other side of the trans. goes to the sail switch or humidistat either one. Then coming off of the other side of the sail switch or humidistat go to the sail humid that you didn't go to first. Coming off of the other side of that control go to the solenoid. The humidistat and sail switch both should be on the same line you are just splitting that side of the circuit. Then the other side goes straight to the solenoid. If that doesn't work then try wiring straight from the trans. to the solenoid just to see if the solenoid works.
Posted on Mar 01, 2009
  • 564 Answers
See the following picture to see the proper connection
You can see the complete hook up from the picture below
You can see the connection between sail switch and humid stat from the picture below
You can see transformer hook up from the picture below
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
    Scholar:
  • 85 Answers
    Sniper:
  • 113 Answers
24v ac cyliniod on the water line, probably mineral deposits or just went bad, it gets its power from the terminal board on newer units have a humidifier output on them.
Good Luck!!!
neo
Posted on Feb 28, 2009
    Genius:
  • 1,550 Answers
Honeywell HE260A wiring. - complete.jpghumidifier.jpgsailswitch_and_humidstat.jpg
  • 2 more comments
  • SAM ANDERSON Feb 28, 2009
    Source :vesperworks.com
  • 19,396 Answers
Check if the unit is fused, you may have blown the fuse when connecting the wirings, the wirings seem connected in the right way.
  • Ginko
    Ginko Feb 28, 2009
    You find the wiring diagram here :
    Honeywell He260a Wiring
  • Ginko
    Ginko Feb 28, 2009
    You need to connect the humistat to the control and to the humidifier on the way below, connect the humistat to solenoid doing a t connection to the humidifier on the wirings to humidstat.
Service light on Honeywell humidifier
Sounds like a Water Level Sensor problem. Read the service manual, pages 51 and 53.
http://www.forwardthinking.honeywell.com/related_links/humidification/69_2285.pdf
Unplug the power cord. Turn OFF water. Remove the Water Level Sensor - One screw holds down the spring clip. Remove water scale in the compartment and on the Sensor. Test Sensor with an ohm meter. If OK, reassemble and try again. If bad, replace the sensor.
If you have heavy scale buildup in the sensor compartment, you need better water filtration. Your problems are just starting. This system can be very difficult to clean thoroughly.
Nov 15, 2012 | Honeywell Truesteam HM512W1005...
I just installed a Honeywell HE 360 Humidifier I purchased at Home depot. I replaced a Aprilaire model 110 . I have a 120v power duplex that is hot with the furnace blower motor, on so I assumed the sail...
Hello, in order to turn your humidifier on with the furnace the 120 volts coming from your humidifer you must hook it up to a step down transformer, then the transformer will provide 24 volts to you humidistat and solenoid valve. So you need a wire from the HUM on your control board to transformer primary side and a wire from neutral on the board to primary side of transformer. Then you need low voltage wire from secondary side of transformer to humidistat from humidistat to humidifier.
Feb 20, 2011 | Honeywell HE360A1027 Whole House...
I hooked the humidifer up and water keeps running it dose not stop when furnace stops. What might be wrong?
Hello, this could be tw o different things. when you install a humidifier you need a means of turning it on and off with the furnaces blower motor, this is done by either a sail switch, current sensing relay, or by the transformer being hooked up directly to the furnaces control board. if you do not have one of those three than the humidifier will run continuously untill u manually turn it off at the humidistat. If you have one of those three installed already than the solenoid valve is stuck and must be replaced.
Feb 08, 2011 | Honeywell HE220A1019 Whole House...
Mold is developing in drainage tubing - how do I prevent?
Keeping the humidity level in your home below 50% will greatly decrease mold growth. You can pour some bleach in the drainage tubing to clean it out and do it every three months to keep it clean
http://www.ehow.com/how_4798220_clean-honeywell-humidifier.html
http://www.forwardthinking.honeywell.com/related_links/humidification/truesteam/sell/50_9718.pdf
Feb 28, 2010 | Honeywell HE260A1010 Whole House...
I just finished hooking up my new he 220a HUMIDIFIER
I have a HE220, HE 260 humidifier..by pass, flow thru. There is no water flow between the hot water tank and the humidifer. The water valve is on. Is there an inexpensive part I can replace myself first before calling a plumbing contractor?
Dec 30, 2009 | Honeywell HE220A1019 Whole House...
My HE260A is discharging too much water
these are flow thru models and a lot of water passes thru them. The instructions say to not limit the water by closing valve at all!
Feb 22, 2009 | Honeywell HE220A1019 Whole House...
Vicks 5100 humidifer need help filling and operating
You can down load the manual in pdf format from this site:
http://www.amazon.com/Honeywell-V5100N-Ultrasonic-Humidifier/dp/B000056HL5
Scroll down to Product Manual [205kb PDF] & download.
If you do not have Adobe Reader which is used to read the pdf file you can download that from this link for free:
http://www.download.com/Adobe-Acrobat-Reader/3000-2378_4-10000062.html
I believe the manual will answer all of your questions..
Good Luck & Best Regards.
please vote...
Mar 06, 2008 | Vicks Ultrasonic V5100 Humidifier
HE120 By-pass humidifer - Sponge Drum not rotating!!
Model HE908A drum is turning but we get no condensation
Dec 25, 2007 | Honeywell HE120 Humidifier
Honeywell HE260A1010 Whole House Humidifier Humidifier Logo
984 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
