Question about D-Link AirPlus DI-524 Wireless Router
DI-524 not working with Vista32 Dell M1330
I have a DI-524 wireless router that has always worked. I'm using it with Shaw cable internet service. For some reason it works fine in every way, except when connecting wirelessly to my Dell M1330 laptop with its Dell Wireless  1505 Draft 802.11n Wireless Mini-Card. When I connect an ethernet cable to the router it works. But when I try to connect my laptop wirelessly, it says either that the connection has limited connectivity, or that there is an IP Address Conflict. Does anybone know what I can do?
  • ecoute Feb 09, 2009
    My d-link router stopped working a couple of weeks ago. I reinstalled using the ethernet on my desktop, but I cannot get my laptops to connect. Yes, I have reset my cable modem et al, but no dice. Can I download drivers to a USB and then install from the USB? I receive an error for the AirPlus dll even though I have uninstalled and reinstalled using the CD. I even bought a d-link booster.
  • 53 Answers
Make sure your wireless card is set to "obtain automatically an IP address"
Posted on Feb 14, 2009
  • Aenim4 Feb 20, 2009
    sure you can download the drivers for you air card and then install them through a USB flash drive, but the problem is not the router itself, it might be a configuration problem or a problem of the laptop.
    Do other wireless devices connect to the router regularly?
Weak signal
Where are you measuring the speed:
* transferring files from one computer on your network
to another computer on your network?
* using a "speed-test" web-site ( that reports the speed?
What level of service are you paying your ISP for? "Lite"? "High-Speed"? "Extreme" ? "Nitro" ?
The "bottleneck" could be between your ISP and your router,
not between your router and your computer.
Dec 13, 2009 | D-Link AirPlus DI-524 Wireless Router
Ethernet connection of DI-524 does not work
You have to make the Ip changes on the laptop not on the modem.
You said you have internet acces on one computer. Then use that computer to find out the exact IP address used by the modem.
On the laptop use the exact same numbers, (IP, Sub mask, Gateway, Primary DNS)
and chek if it works.
If you want to have both computers on the Internet, simply change the last number on the IP address ONLY.
Please don't forget to rate this answer if it helps
Sep 22, 2009 | D-Link AirPlus DI-524 Wireless Router
Switched internet provider, wireless router will not work
The router works the same with either dsl or cable modems. If the router was working with your other computers before, then it should work now, you don't have to change anything.
Aug 19, 2009 | D-Link AirPlus G DI-524 Wireless Router -...
Can't get my di-524 router to work
no a straight are going to need to clone your MAC address on your router so that your ISP can see it.. email me at
Jun 02, 2009 | D-Link AirPlus DI-524 Wireless Router
D-Link DI-524 works with desktop, but laptop can't get signal
Try opening internet explorer and typing in in the address box
If this doesn't work try
For the username and password put admin for username and leave the password blank
Now look for an option for the Wireless Settings and change the channel from usually channel 11 to channel 4 your laptop may now see it. Otherwise try another, channels available in the uk are 1-12, I think it's 1 to 11 in USA
Feb 28, 2009 | D-Link AirPlus DI-524 Wireless Router
DI 524 and airport express
Yes, that is possible for as long the DI524 is already properly setup and can provide already internet connection everything should be working fine there....
Nov 10, 2008 | D-Link AirPlus DI-524 Wireless Router
Connect to wireless
here you get the manual sir: -
or - 256k -
or - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
259 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
