Dell poweredge 650 and front light that is usually blue is flashing orange. And on the back the bottom light to the left of the PS/2 ports is flashing orange.
  • 9 Answers
SOURCE: Flashing orange light
Listen, if you have a orange light on the server,
you need to check ESM Embeded system management logs
You need to install Open manage server administrator from the dell website and you can see what is wrong with the server.
It can be anything causing this problem
Orange light means, your server needs your attention!
Posted on Aug 18, 2008
SOURCE: Blue light flashing
Someone has pushed the system identification button on the front of the server. If you push it again the light will be solid blue.
Posted on Jan 30, 2009
SOURCE: Flshing Red Light on Dell Poweredge 1800 Server
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
Posted on Jun 11, 2009
JaxPlanet
  • 922 Answers
SOURCE: Hi i have a dell poweredge 2850. Orange LED blinking
It sounds like a hard disk has failed or fallen out of sync.
This can be a serious problem if not addressed ASAP.
Call Dell, they have lifetime phone support for their servers.
Write down the Express Service Code and Service Tag number that is on the server chassis before you call.
This is the last number I used for server support: (800) 945-3355
If it doesn't work you should be able to find a valid number at support.dell.com
I hope this helps.
Posted on Jul 23, 2009
  • 60 Answers
SOURCE: Dell poweredge 1650 is beeping with blue flashing ...
Flashing blue light is harmless - it simply means the Identify button has been pushed. There is a small button with a white, cursive 'i' on the front and back of the server - pressing this will make the light flash blue (or make it stop).
Go to Dell's support site and view the manual for the 1650 for an explanation of the beep code - identify the pattern of the beep.
If you are still able to get to Windows, use OpenManage Server Administrator to check the Hardware logs and RAID array.
Posted on Aug 16, 2010
Luz naranja parpadeante?
That depends on what is flashing orange. Please be more specific, and please post in English. In general, flashing orange lights on Dell servers mean something is wrong. Installing and running Dell OpenManage System Manager will usually tell you exactly what is wrong.
Jul 28, 2014 | Dell PowerEdge T110 II
Want to replace a power edge sc1420 power supply with a regular atx power supply has anybody done that. Think the ATX connector is the same but on the other connectors there are many blue wires and I don't...
1) Dell power supply is unique , you can never replace with another regular ATX power supply
2) Please get 2nd handed Dell power supply from the same model. try ebay
Mar 22, 2011 | Dell PowerEdge SC1420 (SC1420MIN) Server
I have a blue vertical flashing light showing just above the Dell emblem. In the past there has been a solid light. I have checked on OpenManager which indicates all is well but I do not like unexplained...
Great thanks,
That's just a system indicator flash. Solid blue means on and normal, blinking means someone either turned on the system indicator in the management software or bumped the indicator switch on the back of the server. This was designed to make easier transitions from back to front when working with multiple servers in a rack. To turn the indicator off, just go to the back of the server and find the Ethernet and usb ports that are together. If the usb is the bottom and Ethernet port is the top then just to the right you should see a small blue blinking light and a button, pushing the button wil turn the blinking off.
Again, no worries this is just a "locator beacon" not an error message, if the light ever blinks yellow then you have an issue.
Hope this helps FixYa,
Chris
Jan 10, 2011 | Dell PowerEdge 1800 Server
Dell poweredge 830 server orange flashing light instead of solid blue. No fault on screen. any ideas?
its the cover switch. there is a small push switch on the front panel that detects if the front cover has been removed, either the switch is defective, or the cover is not seating properly to close the switch.
Jun 09, 2010 | Dell PowerEdge 830 Server
Dell poweredge 1650 is beeping with blue flashing light
May 20, 2010 | Dell PowerEdge 1650 Server
Need wiring diagram for a 2002 mustang Mach 1 radio. radio is hooked up and working but not the bottom door speakers . need to know what color the bottom door speakers are left and right and + & -
2002 Ford Mustang Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Purple/Light Blue
Radio Switched 12V+ Wire: Black/Pink
Radio Ground Wire: Black/Light Green, Black
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Light Blue
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Nov 25, 2009 | 2002 Ford Mustang
System will power on for about 3 seconds and then shut down and the blue indicator light on front is flashing
your poweredge has detected a hardware fault. If it is under warranty contact Dell. If it is out of warranty, you might carefully open the unit, and locate the fault diagnostic leds. They should be lit indicating the code for the fault condition/part.
Oct 13, 2009 | Dell PowerEdge 1650 Server
Blue light flashing
Dec 24, 2008 | Dell PowerEdge 1800 Server
Help with server boot problems flashing orange lights etc
Seems the RAID is broken. You may see which drive (hot swappable?) it showing an error code with its lights in front. If not, I would suggest re-seated all drives.
If you see one that is not right, remove it all the way, while it is on, then push it back in, it should try to rebuild the raid on the drive, if it still fails, you will need to replace the drive.
Not sure what RAID you are using or how many drives, so feel free to explain more.
G'luck
Oct 24, 2008 | Dell PowerEdge 4600 Server
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
