Question about Aiwa NSX-A505 CD Shelf System
CD changer not playing CD's
CD changer will not play CD's. It tries 3 times on CD #1 upon loading the CD's then moves to CD #2 tries 3 times then does the same on CD #3 and then it will stop. I tried cleaning the lens but it did not help. Thanking you in advance...Lenny.
  • Anonymous Nov 27, 2007
    Played cds made from the computer at one time but does not recognize them any more
    President:
  • 3,130 Answers
If this did not help the problem by cleani9ng the lens, the laser is bad or the spindle moteo is bad. if this unit is over 2 years old, buy a new unit. Good Luck
Posted on Jul 15, 2007
Cd cganger struck
its busted,
you have only 2 choices. (or 3 )
1: take it in.
2: take it out and then take it to any ET service tech center.
3: take it out, and open it and unjam it. (look for debris, and broken parts inside, clean it.
me? id do 4 th, id ignore it and use, my USB stick, (no moving parts)
Dec 25, 2013 | 2007 Toyota Camry Hybrid Sedan
Cds will not play in loop. plays one cd and shuts off will not move to the next cd
Troubleshooting Solution
  1. Lift disk changer doesn't work comes message "Disk Error"
  2. Lift disk changer work fine but doesn't load a DVD
  3. Power light is ON but doesn't want to Power UP
  4. From the beginning start DVD movie the picture distorted and freeze
    avsystemparts.com
1. Possible Problem w/ Main Board PCB
2. The dive laser assy replace. or full complete 5 Disk changer ROM
3.More chance problem w/ Main Board
4. Problem w/Main board need replace it.
Dec 24, 2012 | LG LHT874 Theater System
Panasonic 6 disc changer has suddenly stopped playing CD's and now shows E-1, E-2 and so on, messages while trying each disc sequentially, in my Opel Astra. I have tried the reset button to no ava
A CD may have gotten stuck moving from its slot to the play mechanism or while returning to its slot. If repeatedly pushing the reset button does not restore operation or make it possible to pop out the magazine, you may be in for a difficult task of removing the magazine manually but the stuck disc has to get unstuck first
Sep 25, 2012 | Car Audio & Video
A homemade CD got caught in the turntable and now the turntable is stuck even after removing the CD.
Try this:1. Remove the cover (2 screws on each side & 3 in the back).
2. Find a small white arm (more or less cylindrical, about 1" diameter, & about 3/4" long) and a longer (4-5"?) thin black arm in the center of the unit. These parts load/unload CDs to/from the playing area. You should see that a little knob on the white piece has jumped out of its track in the black piece.
3. Carefully put the knob on the white piece back in its track in the black piece. That should do it.
Feb 20, 2011 | Pioneer PD-F1007 301-Disc CD Changer
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
My FTO 6 cd multichanger loads cds, it then goes through each cd but comes E-1, E-2, etc and will not play, any ideas?
home made discs may not work , try one u bought in the store and see from there , alot of times the program used to copy a cd is not compatable with trhe units 3 or 5 beam laser
Oct 22, 2009 | Car Audio & Video
Ford 6006e cd changer with e 3 error keeps happening
The only way to do it is to remove the radio using DIN radio removal tool - then you will have easy acces to remove cd's if you do not have this tools try to use coat hanger (do small catss on the ends)
(you can try to hold eject button and swich off - swich on button - probably it will not work but try few times
Good luck,
Kamil
May 11, 2009 | Car Audio & Video
CD Changer
Common Problem with AIWA 3 disc machines. I have 3 in my service shop right now. For tray not rolling in on it's own, the drive rollers have to be changed, along with the Drive Belt. Also, for CD not reading, try CD lens cleaner.
Sep 10, 2006 | Aiwa NSX-A115 Shelf System
Aiwa NSX-A505 CD Shelf System Logo
370 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
