Manual for a scan coin sc22 - Washing Machines
Where can I find a free pdf manual for a 1996 Geo Metro?
which manual, operators or FSM. (my guess FSM)
the OEM factory service manual. (toss coin)
free , now that is a tall order!
you do know, that in 1996, there was no such thing, right>?
and that someone would have to take a week to scan it right?
you have these options, on all Geo's. made (or swift)
  1. buy one on ebay,
  2. log in to alldata.com DIY for 15 bucks.
  3. google all week finding the All week scan man books, LOL
  4. join a real geo form and beg there , but they will scan maybe 1 page for you, on topic, see links below.
  5. '
http://www.fixkick.com/swift.html
Mar 11, 2015 | 1996 Geo Metro
C100 Coin Sorter & Counter C-100
Coin sorters have to be able to handle a variety of coins in a variety of conditions. The one intended for home use are not very accurate even when new and sorting accuracy declines with age. The only practical "fix" is to take a technological step backward and sort coins manually.
Nov 12, 2013 | Cassida C100 Coin Sorter & Counter C-100
We have a Maytag MAH21PDDWW Washer when you put coins in it will not show you put a coin in but is you remove the maintenance cover you will see a * each time he put a coin in, is there a reset for this...
Hi and welcome to FixYa, I am Kelly. It is possible that the coin drop acceptor is dirty. See page 22 of this manual:
http://www.fowlercompanies.com/SM/Maytag%20Service%20Manuals/MAH21SERVICE.pdf.
On page 23 there is also a guide rail adjustment.
The processor will pretty much go into a tamper proof mode that will not accept any coins you input if there is a problem with the sensor bar or guide rail. I suspect you have a guide rail that needs adjustment. The manual explains the adjustment procedure on page 23.
Thanks for choosing FixYa,
Kelly
Sep 01, 2011 | Maytag Neptune Washer
How can I adjust the run time per $1 on my maytag coin operated dryer. I would like it to run about 15 minutes per $1. Now is runs about 45 minutes on one $1.
Download this manual:
http://www.fowlercompanies.com/servicemanuals%5CMDG16SERVICE.PDF
The mechanism adjustments start on page 20. Note that the maximum number of slider cycles is 3. If you have a PD coin drop model the Max you can get is $0.75 per load I would have to assume that a different coin op mechanism may have to be used or one that will accept 2 coins per cycle for 2 cycles. On non PD models you can adjust the slots for as many as 4 coins per glide / slider cycle.
Thanks for choosing FixYa.
Kelly
Oct 20, 2010 | Dryers
I have a Maytag Neptune TL washer that won't drain. I took the front panel off and detached the hose from the pump and there were several coins in there. I removed the coins, reattached everything and...
For the FAV6800A or FAV9800A tumbler removal.
The Service manual has the procedure starting on page 37 for the tumbler removal.
It’s not difficult to remove the manual doesn’t call out the Torx driver size required for tumbler removal. You will need a number 20 Torx driver to remove the Torx screw for tumbler removal. I would get a long Number 20 Torx driver for this. See page 37 of the Service Manual for tumbler removal. Looks worse than it is.
The Service Manual for reference. Sears Parts Direct for reference.
When I did a recent Outer Tub Bearing replacement I found $1.78 in coins after removing the wash basket. Gotta check those pockets....:)
I have a post around somewhere of my diy Sump Screen I put in my FAV6800AW to protect the drain pump impeller from coins and other stuff from breaking the impeller or causing clogs. I'll look for the post or repost the pic's.........D*ick
Sep 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Juke box (seeburg 480 serieswill take coins but won't play record
YOU ARE SAYING THE MOTOR DOES NOT SPIN. TRY TO SPIN THE DRIVE SHAFT ON TOP OF MOTOR . DOES THE SHAFT TURN EASY. IF NO THEN YOU HAVE A MOTOR OR LUBRICATION.
PROBLEM.
DOES THE SCAN SWITCH, WHEN PUSHED TO SCAN DOES IT SCAN. IF IT SCANS BACK, AND FORTH 2 TIMES, YOU THEN HAVE A COIN CREDIT PROBLEM (MOST LIKELY )
ANSWER THE TWO QUESTION, OR STATEMENT. TO GET A MORE INTELLIGENT REPLY.
YOU HAVE OVER 2000 PARTS IN THAT MACHINE. YOU HAVE GIVEN A (WHY DONT IT WORK
QUESTION.)( there is no answer to the question. because of limited problem info)
DOCTOR FIX
IN-HOME JUKEBOX REPAIR
6362273300
May 09, 2009 | Audio Players & Recorders
Open coin trap
use side of spanner to open the circular water drain plug on coin trap, remove all water.
use flat screwdriver to lift yellow tab at top of coin trap whiloe turning coin trap anticlockwise.
Mar 05, 2009 | Dyson Memory CRO1 Front Load Washer
Washing Machines Logo
375 people viewed this question
Top Washing Machines Experts
