Question about Kenwood KAC-9152D Car Audio Amplifier
Car audio, power wire problem...
I hook my system up.. car off power wire says 12 volts... turn the car on and power goes down to 4 volts.... help grately appreciated
  • howdoiuhhhh Jan 29, 2009
    im running a 1800 watt kenwood amp, with power from the battery.. ground is for sure good (i even hooked up two grounds).....thanks for help
  • Larry Tezekjian
    Larry Tezekjian May 11, 2010
    Need more info to better troubleshoot. What size amp (look at the outside fuses and give me a total) Where is the power wire ran to, the battery? How about the ground wire. Ran to where? Did you get a GOOD ground? Metal to metal? Hit me back. Thanks.
    Larr T
    Winona Lake, IN
    http://www.cybersoundsaudio.com/cybersou...
    Scholar:
  • 116 Answers
A 2nd ground isn't good unless it's the same guage as the 1st and it's grounded AT THE SAME POINT as the 1st one. Did you check the voltage at the amp? I wouldn't trust your dash gauge as I've seen them report a unreliable display under a load. I hope you're in good shape now. Booming season is fast approaching lol!
Posted on Jan 30, 2009
  • 26 Answers
75% of the time all you need to do is reground the ground wire. If you don't have a sturdy ground it can't complete the circuit. Make sure to grind off the paint so you're grounding to bare metal. Also, make sure your ground wire is the same gauge as the power wire or larger than. That should do it.
Posted on Jan 29, 2009
How to connect wires to amp
Most amps have 3 places where you need to hook up wires to power them. the 1st is a ground wire that at best is 1 foot long and it goes on the ground or negative 12 volt connection then a bolt on the car you may need to sand off the paint for it to work, 2 a RMT or remote wire that is normally in the middle of the power and the ground connections the remote turns the amp on and off so it needs to go to the remote wire on the radio or a ignition spot on the fuse box - turns on with key on and off when you turn the key off , 3 the power wire is hopefully large 4 gauge wire and goes to the + 12 volt plug on the amp this wire has a in line fuse and goes to the battery and to the amp only. RCA wires go from the radio to the amp and are round and just plug in with no screws some factory radios need a conversion kit you can get at walmart for RCA wires. the speaker wires have some sort of mark or line to tell you what to put were like if you put the line on a negative on the amp you need to put the line on the negative on the speaker box to or it will not bass and could hurt your amp. ask me if you need anything else :) and please rate :/
Sep 04, 2012 | Blitz 1600 Watt 4 Gauge Amplifier...
My memory wire is yellow & my power wir is red. I have them all hooked together so that the stereo will turn on. My kenwood cd player will not hold memory. Can you help??
The red wire goes to the ignition 12 volt source, and the yellow to the battery 12 volt source. The yellow wire must remain hot with the key out to retain memory.
Nov 19, 2010 | Kenwood Car Audio & Video
Stereo wiring on mk4 golf r32? Fitted new stereo bit radio isn't working I Need to know what colour wire to connect to the power supply for the amplified ariel?
12 volt accessory or same wire that goes to red wire on stereo or cigarette lighter.
OR
What is the current draw on amplified aerial ? or are you talking bout electric aerial(up and down automatically ?) If current draw is really low like 500 milliamp or so then hook her up to blue wire (remote output) on back of stereo but REMEMBER this is LOW current and only meant to switch on amps and raise electric aerials etc.If you think amp on aerial is too much for it then run the rem wire to a 12 volt relay and wire it so that when rem triggers and closes the gate will be connecting an accessory wire OR perm 12v wire to aerial power . That way aerial ONLY turns on(POWERS UP) when stereo is on as opposed to other way where aerial will be powered up every time car ign or acc is turned on regardless of whether the stereo is on or not.
Jun 18, 2010 | Car Audio & Video
I have two amps one for my speakers and the other for my subs it was working fine but recently one of them turned off. I thought was a short circuit and bought a new one but still doesn't work. Its looped...
When running multiple amps you need a relay most of the time for the remote wire off the radio this is because the radio was built to power one not multiples. one 12 volt relay may help .check local car audio store. also when hooking up relay it has to have a 12 volt power wire connected to it usually the center pin on the relay is your connection for the power wire the you connect your remote wire from the radio to the relay then connect each amp independently to the relay. Hope this helps write back if not . and if so leave feedback
May 09, 2010 | Stingpro ST444 1850 Watts Complete...
Im trying hook up a subwoofer to my reciever and its getting power to the amp, however the amp is not powering on.. do you have any idea?
did you hook up the power antenna or amp. turn On wire? make sure you should ha a wire that is to power an antenna and this is the wire that has 12 volts as soon you turn On your stereo and send 12 volts to your amp. but if you don't connect this wire, the amp will never turns On
Jan 04, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
Power wire reads 12 volts,turn car on and it goes to 3.5
WHAT IS HAPPENING IS UR SYSTEM IS PULLING TO MUCH POWER FROM UR BATTERY, I WOULD RECCOMEND GETTING A CAPACITOR.
Mar 20, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Power wire volts go down when turn the car on
Is the power wire going to the battery? Is the ground wire short (3-4 ft) and connected securely to a GOOD metal groun source? Are you using an AGU fuse holder at the battery? Reason I ask these questions is you migh have a weak connection somewhere or a bad fuse that looks like a good fuse. When the amp is turned on, it requires more amperage that at a standby mode. Hit me back.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 25, 2009 | Kenwood KAC-9152D Car Audio Amplifier
When i hook up the remote wire it makes my power wire go to 4 volts
If the battery is strong enough to start the engine, you probably have a bad connection or a defective fuse in the power wiring. If you solve the voltage problem and the amp blows fuses, it likely has shorted output transistors.
Oct 12, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Installing a car stereo
you must connect the wire to turn on the amp
Apr 03, 2008 | Durabrand WD268 Cassette Player
Kenwood KAC-9152D Car Audio Amplifier Logo
48 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
