Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Broken water actuator
How do you replace a water actuator on a Kenmore side by side?
  • 72 Answers
Hi this is tech crazy
the solution to the problem is
You should be able to replace this part yourself. Follow these steps to replace the water actuator:
  1. Unplug the refrigerator to completely disconnect electrical power. Turn off the water supply to the refrigerator.
  2. Remove the drip tray (Key 23 in the image below) from the bottom of the dispenser.
  3. Remove the screws (Key 43) from the bottom of the dispenser module cover (Key 4). NOTE: You model may not have screws at the bottom of the dispenser cover. If not, push down on the top of the dispenser cover and pry out on the bottom of the cover with a flat tip screw driver to remove it.
  4. Pull to dispenser module cover up to release the top clips and remove this cover and set it aside.
  5. Remove the screws (Key 17) that are on each side of the dispenser module (Key 8).
  6. Carefully pull the dispenser module out slightly from the door. It will have wires attached. Pay attention to how the water tube and the ice door assembly are positioned. Pull this module out far enough to remove and replace your water actuator (Key 24).
Reverse the above process for reassembly.
Posted on Feb 02, 2009
SOURCE:
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
I have a kenmore coldspot side by side water comes out dispenser but there is no water flow up to ice maker,also just replaced dual water celanoid
Hello, so you just replaced the water inlet valve correct? Here is a video on how to test the icemaker by removing the cover of the icemaker and connecting the L to the V water should immediatley come from the water inlet valve to the ice tray. If it did not and you heard the water valve actuate then there would be an issue with the icemaker in the unit. click this link http://www.youtube.com/watch?v=AlYCJr9dc3E if you have any further questions message me back Thanks
Rick
Sep 11, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Washer fills up with water. and does nothing else. what can be wrong.
Welcome to FixYa.
Based on your description "washer fills up with water. and does nothing else" it sounds like you`ll need to replace the lid switch, but first...
Here`s how you can check it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...especially those built in the past 1-2yrs. the complete model number would distinguish if it applies to your particular model )
Lift the lid, if you observe the underside of the lid there will be a plastic "strike" or "actuator" that goes into a hole when the lid is closed.
Check the hole where the actuator goes into the cabinet and insure you can see a gray oval shaped piece. If so take a small screw-driver, pen/pencil or something small enough to fit thru the small hole and try activating the switch by pushing it down ( machine must be in the agitate or spin cycle ). If you don't see it, the switch has likely broken loose and needs to be replaced.
If it start's to function than the switch is not being contacted properly by the actuator on the lid and likely is due to the switch being worn...unless the actuator on the lid is broke, if so there`s the problem.
Make sure the switch is being held in place via the two screws along the side, if they are loose tighten them, if it is broken, it will need to be replaced.
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know what you find and if I can assist you further.
Good luck.
Regards,
Macmarkus :)
Nov 14, 2010 | Kenmore 22422 Top Load Washer
How do i replace a water actuator on a kenmore refrigerator
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0501084-00007.png
its about $70 for the part,....what a jokers
Jan 07, 2010 | Kenmore Refrigerators
Side by side kenmore 253.51692103
take it out and put the new one in the same way you took the other one out just backwords
Aug 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
Jul 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 253.51399101
Maybe this will help .. should be diagram of dispenser http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0165000&brandID=0582&modelDesc=SIDE-BY-SIDE%20REFRIGERATOR&modelNumber=25351399101&documentID=P0104005&documentTypeID=PLDM&documentClassCode=PM&titleType=DISPENSER&titleID=00007&
Sep 24, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore side by side ,model no 253.51399101
To access the front of despenser.. most times there is a molding around it the will pop of my Gently prying around it .. screws are behind molding
Sep 20, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Replacing actator-water on kenmore side by side .
the water tray probably just pulls out and there's screws near the base that comes out. up underneath there should be some screws to take out. thhen the unit comes down and out the front. wires and a hose will be coming out with it.
Sep 19, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
601 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Archie Ferrarini
Archie Ferrarini
Elie Balas
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
