Question about Garden
McCulloch Chain Saw model # 600016H
I need to know, how to check the condensor, to see if it is good or not.
I have a multimeter with a capacitor tester, need to know the what the output/reading of the capacitor.
Every time I start the chainsaw, I have to add some fuel, directlory to the carburator to start the saw. It will run until the tank is dry, therefore I know the fuel pump works, but am unsure of an alternative starting method.
It is not running at this time, I think because of an electrical issue.
Please email me the answers at abachand@shaw.ca
Thank you,
Albert
    Scholar:
  • 149 Answers
The cap is usualy around 0.47 MFD....if the spark is blue its ok check the piont for clean surface and correct gap .015" is a good start.
Posted on Jan 31, 2009
I have an older model Mac 4600 18" chain
Go to Mcculloch.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 27, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What oil does it take
You provide no model number so my answer is limited. Use "Bar and Chain" oil available at most home centers and hardware stores.
You can likely find an OM for your saw here: If the entire model does not work try just the numbers then choose from the list provided.
McCulloch International
http://www.mcculloch.biz/int/
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 15, 2010 | McCulloch 14" Electric Chain Saw Mcc1514
I just got a 14 inch McCulloch electric chain saw and it did not have a manual, I do not know what type of oil it takes.
Lou
May 15, 2010 | McCulloch Garden
I need to tighten the chain. Is there a way to do
there should be a screw at the back end of the bar.Screw it in to push the bar out ,or forward, thus makeing the chain tighter
Apr 04, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Where can I get a free online service manuel for this chain saw Model CS38EM. The chain got jammed and I've stripped it but now problem to reassembled it in original order.
I thought it was electric. Now I think it is a MTD McCulloch. A McCulloch example of model number "21-600038-76" follows (may not be your saw):
http://www.ordertree.com/modelinfo/MCC/21-600038-76-Mac-3816-IPL-211318-01/139.21-600038-76-Mac-3816-IPL-211318-01.1.59.1.html
A less detailed IPL that includes other 600038 models follows: Page 1 is illustrated, does it look like your saw?
McCulloch MTD
Chainsaws 32cc-35cc-38cc Anti-Vibe
This explains construction of an IPL number, MTD and Husqvarna models often deviate from the explanation.
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
All McCulloch IPL may be found here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
Download and open the link below for bar installation:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_1150046-95.pdf
See page 16.
This (bottom) explains chain installation.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 20, 2010 | McCulloch Garden
No spark on a I-72 mcCulloch chain saw.
Since this saw is at least 40 years old, you either have a bad coil or bad points and condensor. I would look at the points and see if they can be salvaged but more than likely they will be burned and pitted beyond salvage. Replace them if you can find them. If you can not find them locally contact southern supply company at 205-833-2525 or email them at southern.supply@mindspring.com and I feel sure Jason or someone there can help you.
They have more obsolete parts for McCulloch products than anyone I know.
Aug 09, 2009 | Garden
Need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Jun 30, 2009 | Garden
Need to know spacing requirments for magneto on mcculloch model # 600016h. is it possible to test coil and how would you do so?
Spacing is probably .010. You can test it by getting a flashlight battery and light. Connect the base of the light to the spark plug cable. Connect the ground wire of the coil to the bottom of the battery, and hold the other end of the battery on the light. If the light lights, the coil is good. If not, the coil is bad.
Do not use anything over a 1.5 volt flashlight bulb and battery. The bulb does not have to glow, just light, to prove the coil.
Jan 23, 2009 | McCulloch Garden
Garden Logo
102 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
