Reset fax pegaso memo - Office Equipment & Supplies
How do I reset the cluster code and insert a new code ?
Hi, Gert for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Aprilia, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.apriliaforum.com/forums/showthread.php?206302-Pegaso-strada-dashboard-code
https://groups.google.com/forum/#!topic/uk.rec.motorcycles/reIAFzZ1yJM
failure codes Aprilia pegaso 650
http://www.carlsalter.com/pdfs/Aprilia_Pegaso%20650%20-%20%2797%20-%20Service%20Manual.pdf
APRILIA PEGASO 650 STRADA TRAIL Manual alarm codes
Aug 11, 2016 | Aprilia Pegaso 650 Motorcycles
How do i derestrict aprilia pegaso strada
Contact an Aprilia dealer or Aprilia pegaso strada forum on line.
May 19, 2014 | 2006 Aprilia Pegaso 650 Strada
How can I reset my service warning light on my aprillia pegaso
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix/test or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day. http://www.apriliaforum.com/techtips/1000/faultcodes.htm
DOWNLOAD 2007 Aprilia Pegaso 650
Jun 19, 2012 | 2007 Aprilia Pegaso 650
HOW TO RESET SHARP MEMO MASTER EL-6051
There is a RESET button to the left side of the "A" key. Press the reset button twice using any item that does not have a breakable tip. This will reset the item and clear all memory back to factory settings. Then you will be able to go back in and set it to the parameters that you need. Hope this helps.
Dec 11, 2010 | Office Equipment & Supplies
How to reset sony ericsson k750i security code
Please find steps to reset sony ericsson k750i.
To Reset Code Memo:
1. From the standby screen Press Menu to enter into main menu and scroll to Organizer.
2. > More > Reset.
3. Reset Code Memo? Appears. > Yes.
4. The Code Memo gets reset. The earlier entries are cleaned.
5. Begin by opening the Code Memo for the first time when you enter the Code Memo again.
Thanks,
S
Nov 21, 2009 | Sony Ericsson K750i Cellular Phone
How can I reset the service light on my aprilia pegaso strada.
DIAGNOSIS
This menu interfaces with the systems fitted to the
motorcycle to carry out diagnosis. To enable the menu, a
password is needed that is available only to aprilia service
centres.
• Insert the service code
It is a 5 digit code, for Pegaso the code is: 25973
If code is wrong, appears the message:
• Incorrect code
The instrument panel goes back to main menu; if not, the
menu appears:
• EXIT
• ECU ACTUATIONS
• ECU PARAMETERS
• ECU ERRORS
• DASHBOARD ERRORS
• DELETE ERRORS
• SERVICE RESET
• DISCONNECT
• UPDATE
• UPDATE KEYS
• KM / MILES
Once the operation is over, the instrument panel goes back
to main menu.
Jul 12, 2009 | 2007 Aprilia Pegaso 650
Memos Lost
Download an app called DBscan and run the scans. Then let it fix any problems it finds. This should help. Also, if you have synced before, you can try a hard reset, then re-sync. Another thing to try is the hard reset and sync if the Database on the PC is not corrupted...
Jan 09, 2009 | Palm Treo 680 Smartphone
Memos soft resets device
Sounds like you may need to clean out your memos. Are you talking about the memo icon on the screen or do you have a memo button on the button panel. If you have a memo button, there may be something wrong with it, and you may have to use the icon.
Apr 01, 2008 | Palm TX Handheld
63 people viewed this question
k24674
jasbo
jasbo
