Question about Dryers
I have a Whirlpool Duet Dryer. I keep getting an E2 code. What does that mean?
  • 979 Answers
Not sure but you can go to Google and type in "E2 whirlpool duet dryer" and it should tell you what the code means
Posted on Jan 25, 2009
What does the error code E04 mean on Whirlpool AWU610 Washer-Dryer
Any error code starting with "E" followed by numbers indicates a code meant for a service technician. Call your Duet dryer retailer or Whirlpool directly to set up a servicing appointment.
Read more : http://www.ehow.com/list_7528706_whirlpool-duet-dryer-error-codes.html
Mar 16, 2015 | Whirlpool Washing Machines
Dryer not working. failure code E2
The electronic control board detected that the thermistor located on the blower housing is shorted (zero resistance). Either the wire harness connecting the thermistor and the electronic control board has a short circuit or the thermistor is indeed shorted. Click on the link below for the detailed troubleshooting instructions of this problem.
Troubleshooting Error Code E2 on Whirlpool Duet Dryers
Mar 01, 2011 | Whirlpool Dryers
My whirlpool duet dryer is giving me an E2 code. What does this mean?
The exhaust thermostat is Faulty and needs to be replaced
Feb 21, 2011 | Whirlpool Dryers
My dryer stops after 15 seconds and the code is E2, what does this mean?
E2 and fast shutdown is a shorted thermistor. The thermistor is mounted on the blower housing right next to the duct fusethemobilian_1226.jpg
Video:
Service manual and more info is HERE
Feb 01, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
E2 is flashing on my whirlpool duet dryer whats this mean
you have a shorted thermistor in the exhaust vent housing and it needs replacing
Jul 28, 2010 | Dryers
Code E1
E1 or E2 Thermistor Failure
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
First I had an E1 code, replaced the Thermistor then E2
check the ribbon cable to and from the control board for small breaks and make sure to clean the contacts gently by removing and replacing the cable too,try this
Aug 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
173 people viewed this question
Top Dryers Experts
