Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
No viedo from dvd on tv screen, only audio
I have a TH-42PD25. It's almost three yrs old. The dvd player that's connected to the tv is in working condition but there is no viedo on the tv, just audio. At first, the movie was not centered on the tv screen and now there is no movie at all.
    Problem Solver:
  • 10 Answers
What type of connection are you using when connecting the DVD to the TV? (Component, Svideo, etc) You might want to first try a different connection from the DVD to the TV. Let me know if that works. Could be a bad cable also or a bad connection.
Posted on Jul 25, 2007
How do I connect my DVD player to my Apex flat screen TV?
Well, I don't know what kind of connections do you have, for my old DVD player I used an audio video cable. Connected audio video out from DVD to audio video in of TV. My current Blu-Ray player use the HDMI connection
May 11, 2015 | Televison & Video
Rca j25420 (Older device)
Basic DVD player connections consist of three wires: Right audio (red), left audio (white), and video (yellow). These plug into corresponding connections on the rear of the TV. Your RCA TV may be so old it does not have these input connectors on the rear. Tne "game channel" you are attempting to find does not exist.
Dec 18, 2013 | Televison & Video
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
I have an old panasonic plasma tv model number TH-42PD25 and I can get audio but no video for my cable and I dont know if the kids played with it and its a programming problem or if it is just messed up. I...
Could be a number of causes: Someone may have changed the input setting or maybe the TV tuner went bad.. the good news is you can use the cable box tuner instead. If you need the user manual you can find it here: http://service.us.panasonic.com/opermanpdf/TH37PD25.pdf. Just set it all back up and make sure everything is powered up.. the cable box , the TV , the audio system if seperate.
Dec 14, 2010 | Panasonic Televison & Video
Does TV have to be on certian channal for it to work . old TV audio and viedo are pluged into back sylvania tv?
There are two different methods for attaching the DVD to a TV.<br>If the TV has the red and white audio jacks and the yellow video jack, then you just plug them in and then set your TV to use the alternate video input.&nbsp; There should be a button to cycle through the video choices on the remote or menu.<br><br>If you do not have any alternate audio and video jacks on the TV, only then do you need to buy an RF modulator and plug that into the antenna in of the TV, and select channel 3 or 4.<br><br>Here is a better description, with diagrams:<br><br>http://trutech.supportsync.com/article.aspx?id=1005<br><br>
Aug 27, 2010 | TruTech DV288B3 DVD Player
Why can't we get the sound to work by hooking the DVD player directly to the tv?
The JVC system is designed to output audio only via the speaker terminals at the rear of the system. There is NO provision to send audio directly to the TV from the system.
Page 14 of the manual (link provided below - free to download) details the connections available to a TV. These connections are limited to three types of connections: 1) "Video" for standard TVs which is "good" 2) "S-Video" for TVs that have an S-Video input jack which is "better" (both #1 and #2 are considered "composite" types).
The third type is called "Component" which is used for TV's that are capable of "progressive scan" video input which is "best" for the system. Notice that the jacks on the DVD player are labeled "Y", "Pb" and "Pr", not "Video", "Left" and "Right". This type video signal requires the use of three cables - they do not send audio as you may be used to see on all but the newer TVs. TVs capable of displaying "progressive scan" video have a better looking picture when using these jacks. Incorrectly connecting the video from the DVD to the TV audio inputs (Left & Right) will likely result in noise or hiss from the TV speaker.
To recap - audio can only be played through the JVC system's speakers. Use the highest quality video jacks that BOTH your TV and the DVD player supports.
I hope this was Very Helpful and enjoy your DVD and TV!
http://www.retrevo.com/support/JVC-TH-M505C-Home-Theater-Systems-manual/id/318bh527/t/2/
Dec 21, 2009 | JVC TH-M505 System
Panasonic TH-42PD25 The picture is black with
Make sure if your using the video input jacks, that the yellow is plugged into Video 1 and the same with the audio.Red & White. If your using Component, they are color coded- Red Blue & Green along with the Audio In -Red & White. It sounds like you have the video in the wrong jack.
Oct 28, 2009 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
I need help connecting sony dvp ns 300 to a jvc tv. I can't watch dvd at all, confused about the wiring where does it go?
The CD/DVD player has three output ports:
(i) Line out Video used to connect the yellow pin of composite cable.
(ii) S-video out use d to connect an S-video cable.
(iii) Component video out (red, blue, green) used to connect a component video cable.
So, in order to connect the CD/DVD player to the TV, the TV should have either of the corresponding input port on it.
However, the video quality transmitted by component video cable will be the best among the three.
So, you may connect the TV and the CD/DVD player using an appropriate cable.
All the above connections require an additional audio cable to transmit audio from the CD/DVD player to the TV.
In this case, you may use an RCA (red and white) audio cable to connect the "R and L" audio out port on the CD/DVD player to the corresponding "R and L" audio in port on the TV.
Performing all the above steps will help you get the DVD player work with the TV.
wish u good luck!!!!!!!!!!
Sep 17, 2009 | Sony DVP-NS300 DVD Player
I purchased a new Zenith Tv and have hooked up my dvd player which is about four years old (Toshiba). The connections are all right but when I put in any disk (I have tried many) it registers no disk so...
try to use player on old tv again does it still work 4 yrs old dvd player is to old for new days dvs on new tv u def wann upgrade to 108p upscaling player samsung makes with hdmi cable to new tv flat screen or reg coneection will look 10 times better also older toshibia cant play read new dvds its terrible
Oct 07, 2008 | Televison & Video
Panasonic plasma will not display signal
Ous worked a little odd like that also. Even the part about the pip. Try to hook the ps2 through the cable box which then connects to the tv. This worked for our dvd and wii. Hope it works.
Jun 07, 2007 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
115 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
