Question about Lexmark X7350 All-In-One InkJet Printer
CANT RCV.CALLER ID ON PHONE OR X7350.SINGLE LINE ANSWER MACHINE SET TO 4RINGS,PRINTER SET FOR 5 RINGS,ANY ON DISTINCTIVE RING.PHONE ON ANOTHER PHONE JACK DOES RCV.CID.CAN YOUHELP?
Mar 06, 2014 | Lands Phones
If you have an answering machine connected to the same line as your fax:
To make sure the printer picks up
incoming faxes, set Auto Answer to On, and then set the printer to pick up
after a greater number of rings than the answering machine. For example, if the
answering machine picks up calls after four rings, then set the printer to pick
up after six rings. This way, the answering machine picks up calls first and
your voice calls are received. If the call is a fax, then the printer detects
the fax signal on the line and takes over the call.
If you have a voicemail feature associated to the same line as your fax:
Voice mail and fax can share the
same telephone line if you subscribe to a distinctive ring service offered by
your telephone company. This feature allows you to have multiple telephone
numbers on one telephone line. Each telephone number has a designated ring
pattern (single ring, double ring, triple ring, or double and triple ring). The
different ring patterns let you know which telephone number was dialed, and
which device you should use to answer the call.
If you do not have distinctive ring
service, then set the printer to receive faxes manually (Auto Answer Off). This
setting lets you receive both voice calls and fax calls, but works best if you
use voice mail more often. You need to turn off voice mail whenever you are
expecting a fax.
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Nov 02, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
line as the fax, set the answering machine to answer incoming calls before the
printer does. Increase the number of rings by a factor of 3 over the answering
machine. For example, if the answering machine is set to pick up on 4 rings,
set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Jul 26, 2011 | Lexmark X5650 All-in-One InkJet Printer
Jul 06, 2011 | Lexmark X6150 All-In-One InkJet Printer
Feb 01, 2010 | HP Officejet 6500 Wireless All-in-One...
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Jan 30, 2009 | HP Officejet 5610 All-In-One InkJet...
Aug 28, 2008 | HP Officejet 5610 All-In-One InkJet...
Apr 03, 2008 | Epson Stylus CX9400 Photo Printer
Jun 12, 2014 | Lexmark X7350 All-In-One InkJet Printer
134 people viewed this question
