I need a Replacement spark plug for KP 97302 - Heating & Cooling
What is a replacement spark plug for the Homelite DJ168F-18500A plug provided with this unit?
HOMELITE DJ168F-18500-A - SPARK PLUG - Part Number ...
www.smallenginesprodealer.com/homelite/.../homelite-dj168f-18500-a-spa...
HOMELITE DJ168F-18500-A - SPARK PLUG - Part number DJ168F-18500-A (HOMELITE ... This is an original approved HOMELITE replacement part.
A100643 - SPARK PLUG - Part # A100643 - Small Engines ...
www.smallenginesprodealer.com/homelite/.../a100643-spark-plug-part-a...
This is an original approved HOMELITE replacement part. ... HOMELITE DJ168F-18500-A - SPARK PLUG - Part number DJ168F-18500-A (HOMELITE ...
HOMELITE GM304012 - SPARK PLUG A - Part Number ...
Jan 18, 2016 | Homelite Garden
2003 Saturn Ion spark plug replacement
go to autozone.com and set up a free account. You will then have access to vehicle repair guides and can get all the info and diagrams you need, plus help with troubleshooting! Hope this helps!
Jan 02, 2010 | 2003 Saturn ION
Sony Projection TV KP-46WT500 Convergence Problem and Sparking
You may want to get some help with this install...goto www.tvrepairkits.com and ask for some help
Jan 14, 2009 | Sony KP-46WT500 46" Rear Projection...
I need a blue picture tube re-necked / rebuilt
Go to the following link and leave your model number in a email and list which tube you need, they have access to just about any new replacement tube that you need for Sonys. they dont list them all, but leave a email I am sure they will have what you need.Heres the link.
http://servicemanuals.vstore.ca/
Aug 09, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
KP-51WS510
You only need to buy one assembly. One of the assemblies seem to be original or direct replacement from Sony. Call those guys, to give you more or better info.
In regards to the repair itself, is basically a plug and play but if there are other failures on the TV; the red CRT assembly replacement might not fix them.
Make sure that you pay attention to the 6 and 7 pins connectors orientation when you get the new board as well the ground wires need to be connected.
Good Luck.
Jul 15, 2008 | Sony KP-51WS510 51" Rear Projection...
KP 48V45 TUBE
The only part available is the Red CRT for this model. This Red CRT itself produces the Red Light. Please see below for a link to this item.
Sony KP-48V45 Red CRT Replacement
Apr 10, 2008 | Sony KP-48V45 48" Rear Projection...
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
