Question about Kenmore Dishwashers
630.1390 model has smart wash flashing and won't start
3 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: The 'Smart Wash', 'Heated Dry'
Hi
To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 29, 2011
SOURCE: washing light is flashing and dishwasher won't
The dishwasher is getting water, but it is not cleaning the dishes and it will not even dissolve the dishwashing tab. The machine is less than a year old. We have had the electric go off, is there a reset button or something?
Posted on Jul 22, 2011
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
Whirlpool WFC7500VW1 won't start
My Whirlpool washer model WFC7500VW1 will not start--the green Start button keeps blinking and the red Door Locked button keeps blinking. I do not get any error codes.
Feb 23, 2013 | Whirlpool duet Washing Machines
Washing machine top loader aqua smart the lid cannot lock while washing. I have tried switching the machine on and off, still won't work. This happened a little while ago but then is rectified i
Is the lid lock tang on the lid ok & not broken.
You need to jam the lid lock lever in the lid lock down for it to do a wash.
This is where your lid lock is
Feb 21, 2013 | Fisher and Paykel GWL11 Top Load Washer
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
The green start light is flashing and won't start again when pressed.
Cycle thru the wash settings. Do all the lights work for the different settings?
Nov 25, 2012 | Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
Put in new starter in 2003 ford expodition and it still won't start what can my problem be won't even turn over?
Smart lock? do you have a picture of a red hand on instrument panel? With falcons quite common. Turn & hold key @ start posision, Hit dash upwards on left side of steering colum, If start = faulty smart lock module. I don't know if expodition has smart lock but probably does
Jun 15, 2012 | 2003 Ford Expedition
My smart drive model LW015-K top load washer won't drain the water, I think the draining mechanism is blocked but Im not sure. I forwarded to spin cycle to force drain but it just makes a buzzing sound...
sounds like blocked or the pump is shorting out, do not keep using it otherwise the pump can short your board out, get a repairman unless your a handyman
Sep 02, 2017 | Washing Machines
its easy if you know how hahahah the pump either has something jammed in it or its faulty
Jul 21, 2011 | Fisher and Paykel Washing Machines
Dishwashers Logo
52 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
