Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp aquos a box with mono and stereo and channel 3
During commercials and on local channels a box will appear in the upper right hand corner and it says mono and stereo also ch 3 analog
  • 1 more comment
  • Anonymous Feb 01, 2009
    The mono / stereo selections flicker as well in the same box. How do you get rid of it?
  • Anonymous Feb 14, 2009
    the same exact thing happens with my new tv. its reallyyyy annoying!
  • Anonymous Feb 28, 2009
    box in upper right hand corner with mono and stero and channel 3, flashesnon about every 3 minutes, drives me crazy
    Problem Solver:
  • 17 Answers
Commercials are broadcast in lower quality than the programs, and it is normal for the signal to change when going to commercials. If you are watching ATSC you will notice also the video changes from HD (widescreen) to SD (normal) as well.
Posted on Feb 19, 2009
Audio keeps switching from mono to stereo
on every channel ? then av board is failing
on a single channel then it is their signal not you set
Nov 24, 2009 | Sharp LC-32SB21U 32 in. LCD TV
My Sharp Flat Panel Television LC19SB25U has Picture but No Audio
Sharp has had a few problems with their audio boards, not finding any bulletins on this model, but a few complaining about low audio on amazon reviews section. If using an antenna you will experience some channels with low audio. If using cable you should get good sound on all channels..
the 9.1 and 9.2 are digital channels and sharp does display them for at least a few seconds when you switch to that channel. Check all your setting in the audio to Stereo never SAP. To options for you are get a cable box, first check in the back and see if there is another coax in, if there are two try both rescanning after connecting.
GD lk
Eric
Aug 16, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Feb 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp Aquos LC-37D62U Audio Warning
Usually the settings can't be turned off and the audio settings are searching for whatever is being outputted from the program itself whether mono or stereo. It is nuisance I know.
Jun 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SHARP Aquos LCD-37in
switch from 75 ohm coax to the rca jacks (red and white) even better would be coaxial digital sound (orange rca jack)or optical for the best raw 5.1 channel sound there should also be a way to use the menu to turn off notifications like that
Apr 16, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I just bought a Sharp Aquos LC-32D64U and a Box in the upper right hand corner keeps popping up "Air Analog Ch. 3 Audio Mono/Stereo." The audio keeps flashes either mono or stereo and it does...
The following pretains to most TV models:
Check to see if there is a key on the remote that is called "Display". This is normaly used to display the TV's operation status. Press it and see if you can work your way through different modes of the display content for the screen.
If you cannot make the statis dissapear, it is possible that there is a fault in the incoming signal and the TV is indicating this error, or it is possible that there is an actual defect in the set. At this point, I would contact the dealer. If you don't get a satisfactory answer, then you should contact Sharp service directly.
With retail dealers in many states and countries if you are dissatisfied with the set, you should be able to exchange the TV set in a specific period of time depending on the local laws that deal with consumer sales.
Jerry G.
Apr 13, 2008 | Televison & Video
42" Sharp Aquous audio; Mono vs. Stereo
no. that is not true. the person you spoke to obviously didn't know what they were talking about. you mean to tell me that everyone that has a cable or satellite box with a stereo or hd tv is not going to receive stereo sound? really,think about it. you only need a cable box( for now ) if you have premium channels (hbo,showtime etc). you can connect the cable line right into the tv if you only have basic cable. look at the back of your cable box. if you have a red, white, & yellow audio/video output, then the box is stereo.connect these outputs to your tv. this connection however is not hd.you will need a hd box with a hdmi cable for hd .To put the tv on stereo mode, there should be a way via the menu and/or the audio button on the remote to get it off mono and put it on stereo. your manual should at least show you around the settings of your tv.
wg
Apr 06, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Aquos Channel Bar/audio bar
There is no factory option to stop the box from poping up every time the signal changes, which is what is happening. It has something to do with signal strength or the fact that your cable box is not set up for HD. Call your cable company to get a tech out to check your signal and set up your cable box because they do not come pre-set with HD defaults.
Jan 12, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
226 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
