Question about Samsung HT-DS610 System
Unable to read/play DVDs
My HT-DS610 has become selective in the movies that it will load and playback. At first I could watch all my movies and then over the corse of a couple of weeks, it started to not load them. I know it's not the DVDs because I can still watch them through my PS2. I've searched Samsungs website, but they don't have a thing about this model other than the user manual. Is anyone else having or had this problem and is there a way to correct it other than using a sledge hammer to vent my frustration and purchasing a different brand of home theater??
  • 2 more comments
  • james612 Jan 08, 2008
    Yes, my friend has had this same problem from day one. not just with DVD's but CD's as well. It will start to play then just stop or start to skip, -or- it will not track at all. -Along with that for some reason the system just shuts down for no reason at all. It just turns it'self off.
    Since this has happend from day one it can't be the laser going bad, and he has been using a lens cleaner with it so there should not be any dust on the lens eaither.
  • Anonymous Jan 09, 2008
    HT-DS610B - Same problem w/selective DVD's for about year. Latest ones Pirates of Carribean & 3:10 to Yuma. Sometimes only gives blue screen w/ Disc Error, after playing w/remote buttons have gotten as far as the first 4 minutes but has several short freezes, screen skips and shows the english subtitles at the bottom of the screen. All these DVDs played fine in my Pioneer DMR-ES40V and my old Pioneer DV-434 (although I have to grab the tray & hold it open to drop in the DVD). Done the cleaner bit but no luck and it has only had little use until this winter.
  • Anonymous Nov 13, 2008
    Same symptoms: difficulty reading DVDs eventually progressed to no DVD operability, even though audio CDs work on most occasions.
    The stated solution of lens cleaning besg a question:
    if optics are effectively cleaned but symptoms persist, is it really acceptable that a laser diode in such a device be so near MBTF in regular use? I don't think so.
  • Anonymous Apr 14, 2009
    What type of discs are playable on this DVD player? DVD-R, DVD+R, DVD-RW or DVD+RW?
    The instruction book doesn't say and sometimes I get "No Disc."
    President:
  • 3,130 Answers
You may have a dirty laser lens on the slider assembly. If you clean this little lens, and the problem still happens, it is an indication that the laser is getting weak and it may be time to start looking around for a new player/recorder. Good Luck
Posted on Jul 15, 2007
SOURCE:
I lost may xbox playback kit remote control what can i use as an alternative
Hey,
You can use your Xbox controller as a remote control to watch media.
Here are the actions for each button:
To... Press... Play or pause Note If the DVD is bookmarked, it will start playing automatically where it was stopped the last time you viewed it. START Skip back one chapter LB
or
A, then select skip back Skip forward one chapter RB
or
A, then select skip forward Fast forward RT Rewind LT Page up through a list of items. RT Page down through a list of items. LT Open the on-screen display for more advanced playback controls. X, Y
Source: http://support.xbox.com/en-us/pages/xbox-360/how-to/watch-dvds-movies.aspx
May 02, 2011 | Microsoft Xbox Console
I have a PS2 Slim and it won't read discs. Every time I put a disc in it won't spin it will just go to the screen that says browser and system configuration. Please help me!!
Causes:
1. DVD has lots of scratches
2. Regional Settings
3. Incorrect DVD settings for PS2
4. No/Incorrect Disc
Remedy:
1. Clean your discs well and avoid incurring scratches. Place it in
its box after use.
2. DVDs have encoding. They are encoded by regions. Thus, you cannot
play region 2 DVDs on a US Playstation mainly because the US
Playstation 2 can only read DVD that are encoded in Region 1 or
those DVDs that are encoded for all regions. Again, US PS2 are
region 1 capable. Japanese PS2s are Region 2 Capable.
3. There are a number of settings for the DVD playback of your
PS2. First is the rating of the DVD. If you want to watch a
rated R movie, make sure your PS2 allows viewing of R movies.
You'll be setting this during the first time that you'll be
watching a DVD. It's just the same as real theaters. It is also
protected with password so you need the person who set it up
the first time in order to bypass the rating settings.
4. Put in a DVD first and make sure that it is a Movie. And,
check #2.
Nov 22, 2010 | Sony PlayStation 2 Slimline Console
Password reset
The Rating menu allows you to block playback
of DVDs based on their ratings.
Setting the Password & Rating Level
The DVD player allows you to block playback
of inappropriate content with a passwordprotected
Rating system (not all discs are rated).
A. From Stop mode, press SETUP.
B. Select Rating and press ENTER.
C. Select Rating and press ENTER repeatedly to set the rating from 1 (most restrictive)
to 8( least restrictive ).
If a password has already been set, the lock icon will be closed. You will not be
able to select Rating until you SELECT the correct password using the 0-9 keys.
D. Select Password.
E. Use the 0-9 keys to SELECT a 4-digit password and press ENTER. The lock icon will
close to indicate that the rating and password are set.
F. Press SETUP to save and exit.
Not all DVDs are rated.
DVDs that are rated higher than the level you select will not play without SELECTING
the correct password.
If you forget your Rating password, select 8888 to clear the memory. Keep this password
out of reach of children as if will always unlock the Parental Control setting.
If you need more help you can get the full manual from
http://www.retrevo.com
Thanks for using fixya
Aug 01, 2009 | Astar DVD-3800
Samsung HT-X50 DVD Audio Problem
I had this same problem and checked all of my cables and wires. Come to find out one of the wires that connected to the central audio speaker (the one that the audio track comes from) was unplugged. I plugged it in and that fixed it! My audio track is back! So make sure that all of the speaker cables are properly connected! That might be the source of your troubles!
Apr 19, 2009 | Samsung HT-X50 System
Want to play my old DVDs from overseas, but I get a region code error.
Try the following:
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
4. Reconnect to mains
5. Turn on player with remote.
6. Press ENTER on remote.
7. Press 8, 4, 2, 6, 9. Using keys on remote. If your player is already set to region 2
8. Press ENTER on remote. (The tray will open and player will power off and close tray.)
9. Switch on power from remote.
Player is now Region Free.
Apr 16, 2009 | Samsung HT-DS610 System
Samsung ht-ds610 wont work at all
Loading mechanism is stuck some where in loading or unloading process.
Unplug unit form AC outlet for couple of minutes and replug back in, power up and check.
Feb 11, 2009 | Samsung HT-DS610 System
Will Not Play DVD Movies
What program are you trying to use to play these movies? Windows Media Player will play some, but not others - I highly recommend Nero, WinDVD, PowerDVD or similar programs.
Question - are you able to browse the contents of the DVD drive in My Computer? Even if the movie doesn't play, you can still see the files (there will be an AUDIO_TS and a VIDEO_TS folder, which a bunch of VOB files under the latter).
If you can see the files, but movies won't play, you just need the appropriate DVD playback software.
Hope this helps - remember to rate :)
Oct 06, 2008 | Computers & Internet
Samsung DVD-R130 will not load dvds, but will play CDs
Hey,
have you tried a lens cleaner? the lens may have gone bad and would need to be replaced. Do you have warranty on the player?
Sep 02, 2008 | Samsung DVD-R130 DVD Recorder
Samsung HT-DS610 System Problem
I found this online. Don't know if it helps you guys or not?
Samsung HT-DS610
1. Remove any discs from the tray
2. Flash the RAM (disconnect from the mains for 30 seconds)
3. Plug it back in, switch on from the remote
4. Wait for "No disc" message
5. Press Enter.
6. Press 8,4,2,6,9 slowly.
7. Press Enter.
You may need to repeat steps 4 through 6 before the try is open.
Nov 25, 2007 | Samsung HT-DS610 System
Samsung HT-DS610 System Logo
198 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
