I am trying to set up my wii fit and the board isn't responding when I get to the final step. It asks to turn on the power with your foot and it flashes blue lights, but nothing happens. Any suggestions?
    Problem Solver:
  • 14 Answers
Try replacing the batteries in the board with fresh batteries.
Posted on Jan 25, 2009
The wii fit game is telling me to push the power button on the balance board with my foot. It blinks blue and that's it. The batteries are fine. So what do I do?
You need to sync the balance board with the Wii. It's easy to do and takes 10 seconds.
1) Start Wii Fit.
2) When it asks you to push the power button as you're describing, open the SD card slot on the front of the Wii and observe the red button.
3) Now, flip over the balance board. Remove the battery cover on the bottom of it, and press the red button beside the batteries, and the blue light should start to blink.
4) While the blue light on the balance board is still blinking, quickly press the red button on the Wii. If they are both blinking at the same time, they should be syncing to each other.
5) Your Wii Fit Balance Board should now be synced with your Wii! If it has been synced successfully, you will no longer need to sync it, and should now automatically connect when the button is pressed with your foot.
Apr 09, 2011 | Nintendo Wii Fit for Wii
The board keeps asking me to step off when I'm not on the board. It won't work with any game. It thinks it has someone on it when there isn't.
Hello :
Make sure that the Wii Balance Board is placed properly in front of the TV: The blue power light should be facing away from the TV. If the Wii Balance Board is facing the wrong way, your movements will be reversed.
Check the battery life of the batteries in the Wii Balance Board. If the battery level is low, try a fresh set of batteries.
Check to make sure nothing is pressing against the bottom of the Wii Balance Board. If you do find anything pressing against the bottom
(such as carpet), try using the foot extensions
If you are you using the Wii Balance Board on a plush carpet , try using the foot extensions. After you have installed the extensions, re-weigh yourself and check for proper results (within a few pounds.
good luck .
rate please !
Mar 20, 2010 | Nintendo Wii Fit - Balance Board + Game...
What do you do when your wii balance board keeps saying please step off me and press A
Sorry to tell you but it has gone faulty, you need to take it in for repair. There are no serviceable parts inside.
Mar 18, 2010 | Nintendo Wii Fit - Balance Board + Game...
My wii fit board keeps telling me to step off and press (A) even though i am not stood on it
iv got the same problem too, iv resync it and nothing, wiped the wii clean and started again and nothing (mine went down just b 4 xmas and 'santa' got my boy the wii fit plus and he ant been able 2 play it yep) PLEASE PLEASE PLEASE some1 help
Jan 29, 2010 | Nintendo Wii Fit - Balance Board + Game...
My wii fit board's power LED flashs for seconds then goes off and it keep asking me to switch it on before stepping on
The wii fit board acts the same way as the wii controller. You have to sync the wii fit board to the console.
Dec 14, 2009 | Nintendo Wii Console
Please step off press A - constantly repeated - why???????????
If the Wii Balance Board fails to operate, or operates incorrectly, follow the steps below before seeking
assistance.
A. Check the batteries.
B. Check to be sure there is nothing pressing against the bottom.
C. If you are using it on soft carpet, put the foot extensions on.
1. The Wii Balance Board does not respond.
• Make sure the power is turned on. The blue Power LED should be lit if the Power Button has been
pressed. (The Power Button faces away from the TV.)
• Make sure the board has been placed correctly (see page 6).
• Make sure the batteries have been inserted correctly and are not been depleted.
• Make sure the game you are playing is compatible with the Wii Balance Board.
• Review the synchronization procedure on pages 7-8 and make sure this has been done correctly.
This procedure must be done for each Wii Balance Board compatible game.
• If, after verifying the steps above, the Wii Balance Board does not work, try the following:
1. Turn off the power of the Wii console with the POWER Button on the front of the console.
2. Unplug the power cord from the wall outlet for a few seconds, then plug it back in again.
3. Turn on the power of the Wii console.
4. Repeat the steps in this Operations Manual for setting up the board.
If the Wii Balance Board still does not work, follow the information at the bottom of this page.
2. Control of the Wii Balance Board is inconsistent or seems incorrect.
• Review the Instruction booklet for the game you are playing to make sure you are performing the
correct actions for that game.
• Try using the Wii Balance Board foot extensions if you are using the board on carpet (see page 10).
• Make sure there are no people or other objects between you and the Sensor Bar.
• Avoid interference from other devices. If communication seems to be affected by other devices
(wireless LAN, microwave ovens, cordless devices, computers) move to another location if possible,
or turn off the interfering device.
If the Wii Balance Board still does not work, follow the information below.
If the Wii Balance Board still does not work, an operational check procedure is available
in the Options Menu of the game you are playing. See the Instruction booklet included
with the Game Disc for more information. If your Wii Balance Board does not operate
correctly after all of the above steps, visit support.nintendo.com for assistance and
additional troubleshooting and repair options or call 1-800-255-3700.
Jul 19, 2009 | Nintendo Wii Fit for Wii
Wii Balance Board thinks I'm on it all the time!
Make sure of a couple of things and try again -
If you are on semi-shag carpet, try using the little foot extenders. They may not seem like much but they can help.
If you are on moderate to thick carpet, you may need a board to set the Wii Fit Balance Board on.
If you are on a wood floor, you can (but don't have to) remove the little foot extenders.
Another little gremlin can be in those silicone covers. If you have one, I'll bet that's the culprit. As nice as they are to keep the board clean, they can actually attach to the non-moving part of the scale (the bottom) to the moving (surface) part. Be sure that your silicone cover is not interfering with the normal movement of the board.
Finally, be sure that you are always using YOUR setting while exercising or it will not be calibrated correctly. Also be sure that when you start, you are not on the board when it calibrates for the first time after turning it on. If the weight on the board differs by about 5 lbs or more than what it thinks you weigh, it will pitch a little wii fit.
I hope you find this advise helpful. If not, though, please don't label this advise as "inappropriate". A "Thanks for Trying" would be just fine.
Thanks for using Fixya.
Mar 23, 2009 | Nintendo Wii Fit for Wii
Wii Fit instructions for movements are all in reverse
No it is not how Wii Fit is supposed to be. First, let me suggest that you ensure that the power button on the Wii Fit Balance Board is facing AWAY from the TV set. This may seem silly, but it's the most common error. As for the Hula Hoop game, make sure that your weight is all on the side of the Wii Fit Balance Board in the direction that you need to lean to catch the hoop.
There have been instances of the sensors in the Wii Fit Balance Board going out. If you have tried the above steps and you are still getting errors, please go to www.nintendo.com, register your product, and open a problem ticket with them.
Jan 28, 2009 | Nintendo Video Game Consoles & Games
I'm trying to go through the setup to WII fit. My child did the body test with no problems a couple of days ago. I keep getting an error (fidgeting) when I try to take the body test. Tried to do fit test...
If your Wii Fit Balance Board is on carpet, be sure to use the extra foot pads that came with your board. If your carpet is really thick, you may need to use a flat woodend board to set the balance board on.
Finally, make sure that you are NOT using your child's Miii to do your own balance test. Each user of Wii Fit must use their own Mii character.
If you don't like my suggestion, please don't rate this suggestion a '1'. If my suggestion doesn't help, the problem may exceed the scope of what can be answered here. You will need to contact Nintendo directly through their website and open a problem ticket.
Good Luck!
Jan 17, 2009 | Nintendo Wii Fit for Wii
Please be a bit more detailed in the problem. The Wii Fit Balance Board is very sensitive to weight shifts. Ensure that you allow the board to calibrate properly. To do this, I would suggest the following steps:
1) Place balance board on a sturdy, flat, smooth surface. If you have average-shag carpet, be sure to use the little adapters that fit over the feet. If the carpet is too thick, then it will NOT work properly. You may want to consider a small piece of plywood or something similar to set between the carpet and Balance Board.
2) Don't step onto the board until it has calibrated (this is when the board establishes its zero point). It will clearly say "Starting Up" followed by "Ok, Step On." After this, you can generally stay on the board unless a particular routine asks you to get off or for some reason it needs to recalibrate.
3) Finally, you must ALWAYS back out all the way to the Wii Fit Plaza (where you pick your Mii) if you change players. Once the board is configured for one player, it will only be suitable for that individual. Its sensitivity is based on an individuals weight. For instance, if the board is calibrated for a 3-year old's Mii, and an adult decides to play any of the routines on that Mii, the board will be over sensitive (calibrated for the lighter weight). Conversely, if an sdult's Mii is selected and a child plays a routine, the board may not detect the movement.
I hope these steps will help. If not, please offer a step by step explanation on what you are doing and I will try to reassess your situation.
Thanks!
Dec 29, 2008 | Nintendo Wii Fit for Wii
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
