Question about Sterling Home
Seal between tank and base leaks - Sterling Home
  • 979 Answers
Get a new seal and apply some Vaseline to help seal it . When putting tank on, nestle it in place and then tighten the tanks bolts to the bowl evenly and securely . The rubber washers should compress some to make it snug.
Posted on Jan 29, 2013
Sunbeam sul2512 humidifier leaking.
The Sunbeam SUL2512 Humidifier has three parts. From the top down:
Water tank
mist collar
Base unit
If the cap of the water tank (which contains a float valve) does not seal you may get excessive flow into the base unit which provides a working reservoir.
The base unit contains all the electronics including the cool mist transducer. This is a silver disk with a black silicone seal surrounding it. This is the only other place a leak can develop.
Mar 12, 2018 | Sunbeam Humidifiers
Have air innovations humidifier model #WS30U-09A. It is leaking from the base of unit where water tank seats. Any hint as to why
The water source (tank or bottle) sits tight on the platform and there is a plastic form known as a seal to prevent leakage. You need to replace the seal.
Feb 04, 2018 | Humidifiers
Leaking & no suddenly no steam available
the steam tank is leaking. Buy a new iron.
Jul 18, 2016 | Rowenta Irons
What how hat hoses do I check for code po455
Evaporative emission control system leak Gross leak. You have a gas leak take car to dealer
Apr 16, 2016 | 2005 Chevrolet Chevrolet Classic Base
Water leaking from tank cap HM495
is the rubber seal in place on the cap or did you lose it could be a small crack where the threads are look for both , good luck
Mar 07, 2015 | Humidifiers
Container leaking water
Ther is tank seal that is at the base of the machine where the tank goes on . it will dry up , waer out and leak overtime.
Apr 20, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
I have a massive leak where the tank joins the bowl assembly. so i guess i need a new gasket,,,,yes?
Yes you will need to replace the old gasket to prevent leakage, and when you put the new seal between the tank and base be sure to level the tank using a level and do not over tighten the bolts that hold the tank to the base.
I would also use a little silicone on the bolt heads that are inside of the tank to help prevent leaks from there also.
Free answer...Please rate me
Dec 22, 2010 | Kohler Bath Wellworth K-11471-0 White The...
My two part gas tank leaks what do i use to seal it with
If the tanks are plastic, the best fix is to replace them. Most epoxies, silicon, and other glue bases don't bond well with plastic and the vibration of the running saw doesn't help the repair either. Hope this helps!
May 12, 2010 | Garden
Iron leaks water from the back end of the base
This problem is the way that rowenta seals the water tank. If the iron is disassembled and the seal is properly put on it will not leak,, however this seal is a silicone based product and not just an off the shelf gasket. I have sealed and repaired some using a high temp silicone
Sep 26, 2008 | Rowenta Power Duo Iron
Home Logo
43 people viewed this question
Top Sterling Home Experts
jmartin50
Level 1 Expert
Tim Whalen
Are you a Sterling Home Expert? Answer questions, earn points and help others
