Question about Bunn NHBX-B Contemporary 10-Cup Home Coffee Brewer, Black
How to take it apart
Leaks need to take aapart
Smoke came from the control aea...near the white light switch.....bad plastic smell.....now nothing works??
It could be as simple as a loose connection... the wire came off and shorted out...
or it could be that the whole control smoked...
You will have to pull it apart or have someone pull it aapart and figure out the full extent of the damage...then repair or replace depending on what you find in there...
heatman101
Jan 16, 2011 | Ovens
My memorex dvd remote is not working what should i do?
try this take the remote aapart clean the carbite contack with a cotton shob and alual
Nov 16, 2010 | Memorex MVD2042 DVD Player
Can't get the pump apart to replace leaking seal.
if seal has been leaking probably ruined motor just replace whole pump and motor
Jun 24, 2010 | Waterway Executive 56 Spa Pump 3hp 2" 2spd...
My faucet is leaking from the pulldown where the hose is conected to the spout ive tried to take it apart is there a special way to take it apart
before you take it apart ,I want you to check,the pullout handle first,because most of the time ,all that is wrong is that little1/2-5/8 in washer between the handle and the hose,It usually runs down the hose ,and might apear to be something else leaking under the sink.If your correct,and it is leaking where you said.Some of the newer faucet have a clip that just pushes together.So you need it fing the clip,and push it in.
Apr 12, 2010 | Price Pfister Ashfield Single Control...
Bunn code date 145000 water leak took apart need
If you will call customer service, a seal repair kit can be sent to you which is successful 90-95 percent of the time in fixing the leak problem.
Mar 25, 2010 | Bunn 10 Cup Home Coffee Brewer
Leaking sinkmaster 850 garbage disposal
I have had these apart. The leak is from a seal around the motor shaft. By the time it is leaking the shaft has pitted to the point a new seal will not repair it. Getting it apart can result in damaged parts as it is sealed together with very tight tolerances and a glue like sealer.
Eric
Jul 02, 2009 | Food Processors
Samsung mobile phone Model: SGH-X620
Did you try removing the battery for a few hours? This might solve the problem but in your case, I think the battery has simply died or malfunctioned and getting a new battery is the solution.
Dec 26, 2007 | Nokia 1100
Water Leaking
The seal between the top and the bottom plate has lost it's integrity. First try tightning the 2 screws on the underside of the iron. If that doesn't fix the problem, then you will need to take the iron apart and fix the seal. That will require you to remove those 2 screws and also a third screw that is up by the toe of the iron underneath the sprayer. You will then need to slowly pull the 2 pieces apart becasue the seal is made of a sticky rubber substance. Once you get it apart, you can then distribute the seal material to cover the bad area. Then just put it back together!
Dec 15, 2007 | Rowenta DZ1700 Iron
How to fix a leak
It will come apart.Sometimes the whole front panelcomes off them with the door attached. every thing is put together in a certain order. You can get a front loader manual from your local libuary.Take your pump cover off and start looking for screws. You must locate your water leak first. If its a tub leak you will need to change a rubber seal. Dont be fighten to ask for advice,go to your local Bosch parts shop and tell them your w/m has a leak in a certain place and you need a part and ask for advice.These people are the experts. PS I like the Bosch, Stick with it and keep it simp-le
Jan 16, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
