Question about LG Goldstar DM510 Cellular Phone
Need manual for goldstar VM681M dvd/vhs player
Am trying to record episodes of tv show recorded on dvr to vhs tape & don't have a manual to get directions
  • 979 Answers
SOURCE: lg v181 combo problem with vcr keeps ejecting tapes when I want to record.
The tape load carriage is defective or there is something in the way inside the machine....accordianman
Posted on Mar 21, 2008
  • 226 Answers
SOURCE: After recording a one hour episode, won't recognize the dvd.
Try inserting your DVD media into the PC and doing a 'quick format'. The LG is not seeing what it considers to be media that it can use. It is not seeing that you have inserted recordable media. Sometimes you can reformat the DVD or do a quick media erase, and the LG can then put on its blank "squares" that is uses for its menu selection. I think that it what it does when it 'initializes' a new media.
tom
Posted on Jan 10, 2009
SOURCE: Need code for Viore TV to program LG RC897T DVD/VHS Recorder
I believe Viore is the same as Samsung. I only noticed this by accident as I bought a Viore TV and my friend bought a Samsung and I noticed both remotes were identical. I tried the Samsung codes and the remote worked. Good luck! Kevin
Posted on Jan 16, 2009
SOURCE: dubbing VHS to DVD
You have to go into the Home menu and select setup. At the bottom left there should be an icon that looks like a dvd disc. Select that and then go to finalize and select that to finalize the disc. After that is complete it should play on any dvd player. I had this problem and I got through to LG's customer service line and had them talk me through it. After I finalized the disc, it worked.
Posted on Feb 05, 2009
  • 458 Answers
SOURCE: LG RC195 dvd/vhs combo
Do you just get a snowy screen when you playback? I think the first thing to try is to clean the video heads. Either try a head cleaning tape, but these are not always the best thing, better still is to remove the lid & carefully using a head cleaning fluid (isopropal alcohol) & a thin piece of card or head cleaning stick (NOT a cloth), carefully & gently wipe the heads which are on the round silver drum. Do not use too much pressure or you will damage the heads, give it time to dry (couple of minutes) & then try playback.
Posted on Jul 30, 2009
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
Can I record DVDs from a Sharp 13VT-N100? The only connection source is the coaxial antennae port. There are "In" sources so I can watch DVDs from a DVD player but how can I reverse that so I...
Recorded from tv shows to DVD Disc have to hookup AV RCA component cables to both to Tv and DVD recordable player model connections together.Yes,u will able to recordable VHS tapes to DVD Discs.But ur DVD player model u have it is must be a recorderable DVD player model?Not just a DVD Discs and VHS tapes player only model.Check ur owner manual all are in there.
Aug 20, 2011 | Sharp 13VT-N100 Combo
When recording from vhs tape, and the signal is poor at times, the machine automaticaly stops recording temporarily and resumes when the signal is more stable. how can this feature be disabled?
If you are recording VHS tapes that contain macrovision, and most commercial tapes do, you can't record them with this DVR because it is compliant with the law that says you can't do it. So don't try. Download nearly every movie/tv show from the internet instead.
If you are recording from VHS tapes that you have created yourself from TV sources, or from camera, you must stabilize the picture. There are several devices like that. Do a google search on "vhs stabilizer".
Apr 21, 2009 | Protron PD-DVR100 DVD Recorder
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Ilo DVDR 05
http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/e Someone said these were similar. Try the red/yellow/white cables. select that SOURCE. first select your recording length. I usually put mine on 3-4 hours and try to keep it from running to the end or you have problems. I use Rewriteable dvds, if you use reg discs be sure to finalize the disc so it will work in other players. I read if you are copying macrovision vhs to use the antenna input and it will copy it with that input. Just tune it to channel 4 or whatever. Forget trying to set the timer to record from tv. I never have success with that.
Jun 19, 2008 | iLO DVDR05 DVD Recorder
CONNECTING A VCR RECORDER/PLAYER TO A HD FLAT SCREEN TV
Now one question - Do you want to record the TV program on the VCR or Movies from a DVD plater hooked to your HD TV?
Jan 10, 2008 | Goldstar GVR-E435 VHS VCR
Pioneer dvr 225 recorder
the dvd recorder has to be set to monitor the program your watching! you can not copy vhs tapes to dvd this way because the tapes that are prerecorded have a copy protect feature and will nut copy right!
Dec 15, 2007 | Pioneer DVR-225 DVD Recorder
Gold Star VC681M - recording from VHS to DVD
This device can not record from VCR to DVD locally not a DVD recorder. However you can record from this device to your computer save the file as a wma and then burn that file to a DVD and then watch the DVD on the DVD player. This player can decode wma files: Here is a site to get the owners manual from: http://www.lge.com/support/manual.jsp Here is how the page looks:
Oct 09, 2007 | Goldstar DV7411N DVD Player
LG Goldstar DM510 Cellular Phone Logo
284 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
