Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Inside light bulb quit working the bulb is good but doesn't turn on when door opens
Not much more I can add other than, I plugged bulb in another appliance and it works but it quit working in the freezer..
  • Official Brand Answer
  • 4,342 Answers
Hello Rick Cieri - From what you have described it seems like the unit could possibly be experiencing a wiring failure or communication problem coming from the main control board. Connect with a certified technician to accurately pinpoint any potentially more serious issues.
Posted on Jan 23, 2013
4 Suggested Answers
erwinroyo
  • 189 Answers
SOURCE: frigidaire cf-5f-lx2 1989 modle
Greetings!
Since the overload was good when tested, check also the electric current if the current is in the right voltage.
If the problem still a raise, it is now the motor compressor that have problem. The motor it self cannot start or hard starting.
Thanks.
Posted on Nov 06, 2008
baraquielnar
  • 247 Answers
SOURCE: hi ... freezer door was
unplug the unit after 5 minutes plug and start then observe unit.
Posted on Mar 09, 2011
  • 5370 Answers
SOURCE: inside light on freezer works-freezer doesnot.
Give exact brand and model number of the refrigerator. Is it top freezer and bottom fridge model or is it bottom freezer or top fridge model or its side by side refrigerator .Are the temperature settings getting set to proper settings. Is the door getting properly closed? Is the fan in freezer section running properly? Is there any kind of water leakage or is there any kind of over frost build up in fridge or freezer section. -------- Please keep updated with proper details. Thanks. Helpmech.
Posted on May 07, 2011
How do I replace the lights in my freezer
Turn off the power to the refrigerator/freezer by flipping the appropriate switch in your breaker panel. Alternatively, unplug the refrigerator from the wall outlet.
Open the freezer door. Remove any items from the shelf directly under the light shield, then remove the shelf.
Press down on the top, front edge of the light shield until the locking tabs slip out of the slots. Swivel the light shield downward slightly to release it. Pull the shield out of the freezer compartment and set it aside.
Turn the light bulb counterclockwise to remove it. Insert the GE replacement bulb into the light socket and twist it clockwise.
5
Reattach the light shield by sliding it into place. Gently push the tabs into the original slots.
6
Insert the shelf into the freezer and reload it with the frozen food removed earlier.
7
Close the freezer door. Restore power to the refrigerator by flipping on the breaker or plugging it into the wall outlet.
Jul 25, 2017 | Freezers
How do I replace the door light switch?
I appreciate your post, Deborah!
From what you have described you need to replace the door light switch on your Frigidaire freezer. In order to assist you further I would need your model number. You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I look forward to assisting you. -Matt
Apr 27, 2015 | Frigidaire Freezers
How do you remove the light on the door of a true tdm-26f? I'm just trying to change the bulb. Any other reasons the light wouldn't be working?
The light should have a cover over it. If not, then just try to loosen it if you can by pressing in on the bulb while turning it. This will help keep it secure to the base of the bulb. If you get it replaced it should work. If it doesn't, then check the button or 1/4 shape tab and see if it is loose or jammed. It stays in a somewhat wet environment all the time.
Jan 26, 2013 | True Freezers
Freezer light doesn't work and door ajar alarm going off
The door switch is faulty. It switches the light on. There is no battery.
Dec 27, 2012 | Kenmore Freezers
Light doesn't work
First check the lamp; make sure it isn't loose in the holder,check the filament is still complete. Next check the light switch has power and is closing with the door opening. If no power, check wiring/ connection. If power in and out can only be the lamp!
Jun 11, 2012 | Frigidaire Freezers
Samsung side by side refregerator door left open for some time, the door warning chime does not come on
Check the switch just inside the door. If it's not chiming, it may not be switching the fan either.
May 03, 2012 | Samsung RSH1NEPE 554L SIDE BY SIDE...
Freezer is Frozen shut
Try unplugging the freezer and leave the door open for about 30 to 45 minutes. Don't forget the door is open and plug the freezer back in. Set a timer in the kitchen so you don't forget. Once you can open the drawers look inside the freezer sides to find the controller. Most models have turn dial inside.
Mar 07, 2012 | Siemens Freezers
MY FREZER HAS FROST AROUND THE DOOR AND MOLD IS GROWING AROUND IT
You need to replace the door gasket. It's leaking air causing the frost.
May 04, 2011 | Whirlpool Freezers
For the second time in the 4 or 5 years that I have owned my Kenmore 16.7 upright it quit cooling altogether again -- the first time I cooled the compressor with a damp (to wet) towel and a fan, being...
If the compressor is overheating I would check the condensor fan and make sure it's turning. Sounds like you wouldn't have noticed this already though. Also, if the compressor is turning on for 5 or 10 seconds and then clicking off then your start relay is probably bad. Pull the relay off the compressor and shake it. If something is loose inside then it's bad. That is, if it's a whirlpool made kenmore. Kenmore doesn't make appliances they only brand them. The refrigerator could have been made by Whirlpool, Frigidaire, GE, LG, Maytag, Amana, or other. So, it's depenant on who made it.
Nov 24, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Servis fridgefreezer light
IT COULD BE A BAD LIGHT SWITCH, SOCKET OR BULB.
IF THE CONTROL IS ELECTRONIC, SOME REFRIGERATORS WILL SHUT DOWN THE LIGHTS IF THE DOOR IS LEFT OPEN TOO LONG.
BE SURE THE BULB IS SCREWED IN ALL THE WAY. SOMETIMES, THEY WILL WORK LOOSE.
Apr 02, 2008 | Freezers
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
76 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
