Question about Whirlpool Refrigerators
I have an older model whirlpool refrigerator model et18akxm . What would cause a chirping sound to come from the freezer?
watugot
  • 290 Answers
SOURCE: whirlpool profile refrigerator
Unplug it and see if noise stops. Leave it unplugged for at least 10 min. This will tell you if it is the fridge. Be sure and check your batteries in smoke alarms if you have any. I have made several calls for noisy appliances that ended up being smoke alarm battery warnings.
Posted on Oct 06, 2007
mikedurland
  • 481 Answers
SOURCE: My whirlpool refrigerator (Model ET18DK)
check for:
  •  any ice or frost buildup in the freezer (defrost problem)
  • airflow restrictions, like dirty coils or if the refrigerator is on carpet.
  • it could also be a weak compressor.
let me know Mike
Posted on Aug 08, 2008
  • 409 Answers
SOURCE: Side by Side Refrigerator not getting cold
hi there,
is it just the fridge or the freezer as well?
Posted on Sep 16, 2008
SOURCE: Chirping noise from Freezer and Refrig
Simple fix. Unplug refrigerator, locate fan, wipe clean from collected dirt etc. and spray a little WD-40 on the shaft. Spin the fan. Plug in and voila, chirp is gone.
Permanent fix, replace motor.
Posted on Dec 15, 2008
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
What year was my ET18AKXM made?
We require serial number to determine year made
Jan 16, 2014 | Whirlpool Refrigerators
REFRIGERATOR FREEZER IS MAKING A NOISE
Noise inside the Freezer
If your freezer is making a squealing or a little chirping sound, your condenser or evaporator fan is the cause. Open up the freezer door, and the noise usually gets louder. The location of the fan depends on your model freezer. Usually, the fan is located on the rear wall of the freezer. The fan can lose lubrication or become rusty over time. You cannot repair the fan. You must purchase a new one.
Have a nice day : )
Sep 05, 2011 | Refrigerators
Freezer way too cold, refrigerator side too warm on side by side.
This can be caused by lots of faults first inspect the evaporator in the back of the freezer for ice build up if this is the case the defrost system has a fault, if not the unit that opens between the wall of the freezer and the fridge may be faulty check for the grills opening and closing
May 29, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Loud chirping noise from freezer control .. Model ETT 17GK Whirlpool Refrigerator
Loud chirping noise is often a bad electrolitic capacitor, test and eventually replace the control board.
May 05, 2009 | Whirlpool Refrigerators
Nov 21, 2008 | Refrigerators
Fan motor ???
ef452b7.jpg I will send another figure then instructions
Nov 19, 2008 | Whirlpool Refrigerators
Exterior Moisture
sounds like you have warm air getting into the machine, id check to make sure the doors are closing tightly around all sides with no gaps
Oct 26, 2008 | Whirlpool Refrigerators
We have an older model whirlpool and cannot find the freezer control dial. But, we easily found the fridge control dial. Could you help me with this? the model is ET8W/TK/ET/8WTM
if it is not in the center of the back of the freezer then it may not have a control for the freezer. the control for the freezer is just a flap that allows more or less air into the refrigerator side. so the only thermostat in a refrigerator is the one in the refrigerator side.
Jun 28, 2008 | Whirlpool Refrigerators
Whirlpool GD5RHAXNQ SIDE BY SIDE, CHIRPING NOISE WHEN LIGHT IS PLUGGED IN
short in the control panel. or the ground in the control panel is loose.
Dec 26, 2007 | Whirlpool ED0GTQXMQ Side by Side...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
