Question about Brother Sewing Machines
Nesting thread on under side of material
Using same thread, same material, same settings, As I start sewing it looks great for about 12 inches then the thread breaks and when I turn the fabric over theres a thread nest. I have a VX-1120 and I have rethreaded it atleast 30 times. Is there hope or should I just throw it in the lake and buy a singer??????
  • Janet Conrad Jun 07, 2013
    The same happens to me only just before it does the thread on the spool zings around. I have been happily sewing for a couple of days, ran out of bobbin thread, rewound the bobbin and now I have this issue. I've changed out the bobbin, even put it in backwards (out of frustration) but every time it sews perfectly, then zing and jam with nest of thread on the underside of fabric.
  • 66 Answers
Hello frank it sounds like you might have a bobbin case problem I would try changeing it out
Posted on Jan 25, 2009
The thread balls up on the bottom side, it looks like the foot is not moving the material
Frequently, the top thread is not seated in the top tension disk and it is causing thread nesting (or bird nesting).
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Re-test your machine.
It may help to install a brand needle.
Also, avoid old or bargain bin thread.
If the mess is under the fabric, the issue is the top thread.
Jul 27, 2017 | Sewing Machines
Have lots of thread on the under side of fabric
Thread nesting or bird nesting resulting usually from: mis-threading, upper thread not seated completely in the tension disk, upper thread tension too loose. HINT: ALWAYS raise the presser foot when threading the upper thread.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Jan 05, 2017 | Sewing Machines
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
Dec 22, 2016 | Singer Sewing Machines
Fashion Mate 248. The top stitch is fine but will gather too much under the material. Wraps around the bobbin holder and tangle up into the bobbin thread. Does anybody know whats going on?
That is what is referred to as bird nesting or thread nesting. It usually results from mis-threading, the thread not being fully seated in the tension disk, or the tension set too loose. (I have a machine that does this frequently because the thread "jumps" out of the take up lever when sewing fast--instant thread mess.)
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Make sure the thread path is correct. Set the upper tension to the midway point between high & low number. (You will probably need to tweak the upper tension because every machine differs over time, but the midway point is the factory standard setting.)
While you are at it, check to make sure the bobbin is loaded and threaded correctly in the bobbin case.
If you continue to have issues, you may need to take it for service.
Dec 10, 2016 | Sewing Machines
What am I doing wrong when the stitching on top of the material is ok and straight and the backside is knotting?
wrong bobbin tension , but amazingly its actually easier to adjust the top threads tension to compensate for it , use your tension knob to slowly adjust , try an inch , slowly adjust try an inch , and so on to get a top and bottom thread tension to match , this will need to be adjusted for each major change in fabric (aka , knits to woven )
Aug 17, 2016 | Sewing Machines
Bobbin thread bunches up under material
make sure that the bobbin carrier is fixed in properly
make the needle thread tension a lot tighter
Jun 23, 2016 | Sewing Machines
Why is it bird nesting from top thread?
by bird nesting do you mean the thread is bunching up under the material
comment with your reply
Dec 14, 2015 | Sewing Machines
Tread bunches up under the material what is the fix
Sounds like what you are experiencing is bird nesting or thread nesting.
First, install a brand new needle. (Most frequent cause of sewing problems.)
Remove all the thread and rethread from the beginning BUT be sure to RAISE the presser foot BEFORE threading. This allows the thread to seat firmly in the tension disks.
Set the upper tension at the midpoint (this is the standard factory setting).
Test your stitching. If the thread is still globbing under the fabric, tighten the upper tension and test again. Keep testing until the upper thread and bobbin thread meet in the middle of the fabric.
Here's a suggestion to help avoid thread nests at the beginning of sewing:
How and Why to Bring up the Bobbin Thread
Oct 15, 2015 | Sewing Machines
My minghui is sawing just top and bottom is just mess can u help me???
Thanks for the question.
If your machine is not sewing on the bottom or making stacks of thread called (bird nesting) there are several simple fixes for this and some not so simple.
First you need to make sure that you are threading the bobbin into the holder correctly, Insure that you pull the end of the thread through the little slit on the side of the bobbin and that the thread is somewhat snug but not hard to pull.
Once you have done this replace the bobbin in the bobbin holder and thread the feed thread over the top from the spool or thread. making sure that you run it through the auto tensioner.
Set the auto thread tension to +1 to start, go ahead and thread the main feed through the bobbin feed so that you have both strings on the sewing deck.
Now with a piece of used material, pull both bobbin feed and Main thread behind the machine, insert your test material, drop the material tension foot onto material and start to sew a 1 inch spot.
After about one inch check to see if your machine is still nesting thread, if it is you need to add more tention to the main thread by moving the auto tensioner to +2. Now test sew again a short distance and recheck. If you still have a issue move the tension up until the nesting of string stops.
If you reach the stop. than it\'s likely that the bobbin holder needs to be adjusted.
The bobbin holder has two small screws in it generally that allow a very small screwdriver to adjust the bi metal pensioner on the bobbin holder. This is the area where you slide the string through the little slot in the bobbin holder.
You can tighten those screws until the string is harder to pull out of the bobbin holder. You may have to repeat this step several times until you get the tensions just right.
but make sure that you reset the main Thread tension to 0 before you start adjusting the bobbin tension.
If after all this work fails you may have to replace the bobbin holder to correct this issue.
There is one other fix that you can try before replacing the bobbin holder and that is to purchase more expensive thread. The reason behind this is that the more expensive thread is thicker and causes more friction in the bobbin holder..
I hope that this has helped you, I know what it\'s like not to have a working sewing machine.
Best of luck and thanks for using Fixya.com
Oct 16, 2013 | Sewing Machines
Sewing Machines Logo
215 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
