Question about Saniflo & Saniplus& Macerator Pump
Saniflo delay after flush - Saniflo & Saniplus& Macerator Pump
2 Suggested Answers
  • 82 Answers
SOURCE: NOISY SANIFLO
Always an issue, guessing it is on a tiled floor? or up against a tiled wall?
I put some thin foam / Bubble wrap underneath and behind mine to dampen the vibrations. It also helps if you box the unit in and use foam to quieten the noise (on top and around the unit). Depending upon how long you have had it, it may also need a clean out or possibly even the motor bearings are getting a bit worn, creating some noise with the excess movement.
Good Luck
Posted on Jan 17, 2010
Can the flush mechanism be moved to an external site
Well now, that depends on your ingenuity.
If you can exactly duplicate the action of the flush handle, of course you can move it anywhere you please.
I am at a railroad museum, and railroads could move track switch lever mechanisms several hundred feet away from the switch, it just takes imagination and precision.
Saniflo will not be able to help you, but an inventor might be delighted to do so.
God bless your efforts.
Dec 15, 2015 | Saniflo Home
I have a Sanipro,it sounds like it pumps real weak and goes off quickly instead of emptying out everything. then it will come on again after aseveral seconds . Could it be the Condenser on the motor?
  1. Saniflo & Saniplus&... Repair Questions - Fixya
    www.fixya.com/.../p1064016-saniflo_saniplus_macerator_pump_002 Saniflo & Saniplus& Macerator Pump - Recent Questions, Troubleshooting & Support ... My saniflo does not flush properly always leaves the toilet paper behind.
Jul 20, 2015 | Saniflo SANIPRO Macerating Pump
I have had a saniflo operating fine behind my ensuite toilet for 2 years. The saniflo drains into the waste pipe after the AAV and before the bathroom sink. Recently when we flush the toilet and the...
may need a backflow preventer in the waste line under the sink..it is basically a ball on a spring..designed to make the water go only one way..I am guessing the wasteline was opened up with a plumbing snake..that pump may have too much backpressure from the head line..
Jan 25, 2014 | Plumbing
Saniflo compact part flushes when being used
Of course you should , the MAKER should make it right
May 22, 2017 | Home
Must flush saniflo multiple times to get rid of all waste.
loosen chain to plug in the back of the toilet it is too low so not much water is needed to flush
Jun 03, 2010 | Saniflo Sanibest Grinder Pump Only 013
My Saniflo sanicompact does not flush away, when i press the flush botton it does not work, the toilet buzzes all the time. when the water gets to a level it use to pump away but has stoped doing this.
saniflo buzzing all the time means that the motor is trying to run but cannot. indicates that something is blocking the pump impeller from rotating. unit needs to be removed, cleared and tested. if fault contiues you may blow the fuse (if you are lucky) otherwise the motor will eventually burn out. get this checked soon.
Apr 12, 2010 | Saniflo Sanicompact Elite - One Piece...
Describe your Saniflo &
your p-trap is dry . the guy who did it probably didn't vent it properly, and it's being syphined. call him back to fix it.
Sep 15, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo ejector experiencing shaking when flushed
I have included the installation instructions. It also includes an expanded veiw of the toilet. The troubleshooting area can give you ideas. From what I read, it is possible that something has feel into the grill. Hopefully this helps.
http://www.saniflo.com/pdf/install/PLUS_US.pdf
Apr 18, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
Saniflo pump has a delay, kicks in 15 mins after flushed.
Either the rubber membrane or the microswitch is at fault.
Feb 24, 2009 | Saniflo Sanibest Grinder Pump Only 013
My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Nov 15, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo & Saniplus& Macerator Pump  Logo
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
