Question about Carrier XQA123D Air Conditioner
My Carrier XQA-123-D Window Heat pump compresser won't run.
3 Suggested Answers
vanni7
  • 163 Answers
SOURCE: 3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Posted on Jan 04, 2009
  • 415 Answers
SOURCE: Carrier heat pump (basic model) runs at 0 or below
A basic model heat pump with an air handler with electric strip heat generally will continue to run with a call for heat regardless of the outdoor air temperature unless there was an outdoor thermostat (an accessory) installed. There is still heat in the outdoor even at temperatures of zero and below. Generally, there is a balance point of approx 30-35degF that allows the heat pump to heat your house to 68degF without the need for the electric heaters. Below that, the heat pump can still extract heat from outside and "pump" it into your house; however, it will need help from the electric heaters. In temperatures below the balance point, the heat pump will run non-stop. As the temperature in the house falls approx 1 - 2 degF below the setpoint, the electric heaters will energize. So it is not uncommon for the system to run non-stop with the temperature falling a few degrees below setpoint. The colder the outside temperature, the more often the strip heaters will cycle on/off. If your system is well-maintained and operating at proper performance, it is still cheaper to run your heat pump than it is to run on straight electric heat. If you live in a climate where below zero temperatures are normal during the winter months, you might want to research heat pump options that offer higher COP's and increased performance in colder temperature than the basic contractor's model. Start with initiating communication with a local contractor. You will need to consider initial cost and the pay-back period based on your local energy costs and your specific demands you want your system to meet.
Hope this helps!
Posted on Feb 14, 2010
Is there any danger in running my Carrier HVAC in "Emergency Heat" mode all the time?
No theirs no danger in running the Emergency Heat all the time, Emergency Heat is your backup heat mode. when the Heat Pump is not working do to a malfunction or Defrost, the Emergency Heat kicks in. The Emergency Heat is usually electric heaters so your electric bill will be much higher.
Nov 07, 2016 | Carrier Heating & Cooling
Carrier heat pump
Expansion valve is sticking shut
Jun 13, 2013 | Carrier 5 Ton Complete Split System Heat...
Carrier Furnace won't start up
Sequence of events: call for heat at T-stat, inducer motor turns on, negative pressure created in heat exchanger closes pressure switch, pressure switch control wire runs through all safety's (these must all be in closed/safe position) if ok then glow plug lights. Time delay then gas valve opens, flame verified by "flame rod" t-stat = :)
Apr 22, 2013 | Heating & Cooling
Hot tub won't get hot
Check your filters and make sure they are clean.
Check to see if the heat indicator light is on when the tub is running.
Make sure the gate valves are open on either side of the pump and control box.
Are there any error codes in the little window on the topside?
Rod Kidman
www.uspartscenter.com
Nov 25, 2012 | Home
Carrier infinity 80 won't heat
does your burner flame up and then go put two or three times if so
all you have to do is take out the burner and clean all the soot out of it and then wipe off the sensor
Oct 09, 2012 | Carrier Infinity Series Variable Speed...
Compressor motor runs but does not make compessed air
Some of the things for you to check are for any leaks anywhere, the valve plate assembly, the piston and cylinder assembly and the con-rod. If you have any leaks that let air out as fast as the piston is trying to pump it in you won't get any compressed air. Check the drain valve on the bottom of the tank and the air line from the pump to the tank. If any of the reeds on the valve plate assembly are bent or broken they won't seal the way they need to in order to compress air. If the cylinder is badly scored or the piston rings are scored or broken the piston won't pump compressed air into the tank. If the con-rod is broke the piston won't work at all.
Jul 25, 2012 | Makita Mac5200 138a 3 Hp 5 Gal Wheeled Air...
Hope this helps!
Feb 14, 2010 | Carrier 38CKC036 Air Conditioner
Carrier XQA123D Air Conditioner Logo
37 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
