Question about SimpleTech (SP-U25/120G) 120 GB USB Hard Drive
Driver for simple tech (SP-U25/120G)
For windows xp
4 Suggested Answers
suisboy
  • 175 Answers
SOURCE: simple tech problem
windows 2000 detects the driver for plug n play drives for it self and if it doesnt then try driverguide.com for drivers of the disk.
Posted on Nov 08, 2008
Ynnoj
  • 4 Answers
SOURCE: Simple Tech SP U25/60 external hard drive
Almost nothing is supported on Win 2000 because it had shuch a short life span. most new tech made in the last 2-3 years only runs onXP or Vista. Every once in a while some will work back to 98.
p.s. did it say it was compatable with 2000? look on the box
Posted on Feb 25, 2009
bronk50
  • 27725 Answers
SOURCE: I coonect it to my
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Posted on Jun 04, 2011
We have Mustek Paragon 1200 SP flatbed scanner . We have driver for windows 98 . Now we need driver for Windows XP.
window 98 driver will work with windows xp. install the driver file right click and click install. using the setup file. or go to the windows devices. double click on the scanner in menu go to up date driver. in next box use the install driver from local file and make the file to the drivers you have it will install the files it needs. may say are you sure you want to install the driver as it has no certificate click yes., driver installed now.
Oct 05, 2013 | Mustek PARAGON 1200 SP Flatbed Scanner
Is my simple tech 60GB compatable with windows 7 the disk said for windows 2000 and xp
Most portable hard drives work with any operating system
Plug and Play is a simple Windows controller that enables your Windows computer to recognize and adjust to hardware changes and devices plugged on your computer such as hard drives, memory cards and USB and Firewire-powered devices with little or no input from a user. If your system is not recognizing plugged-in hardware, the plug-and-play device may be disabled and may cause instability on your system. Enabling this feature is simple.
Click "Start" on your computer screen and then click "Run." Type in services.msc on the run window and hit "Enter." Scroll down the services window and right-click "Plug and Play." Click "Properties" on the pop-up menu. Select "Automatic" under start-up type if it is disabled. Click "OK" to save the changes. Click "Start" on your screen and click "Control Panel." Double-click "System" and click the "Hardware" tab. Click the "Device Manager" button and then right-click the plug-and-play device you want to enable, then click "Enable." Close the device manager. Hope this helps.
Dec 23, 2012 | SimpleTech SP-U25/60S 60 GB USB 2.0 Hard...
Recently I have formatted my PC Lenovo Thinkcentre A51 (Type No. 8122KQG), and installed Window XP 2002 Professional SP 3. Since then I am not able to install any of the drivers. Sound, Audio, Video, PCI...
the xp proffesional cd doesint include the drivers the driver cd comes along with the motherboard after installing windows you have install the drivers which came with the motherboard insert the driver cd it autoruns and tick all the drivers you want to load it load automaticlly if the driver cd is not working you can downoad the drivers from the net
Jul 03, 2011 | Lenovo ThinkCentre® A51 PC Desktop
I have sp 606. i connect to sp606 via usb cable to pc in window xp.but icannot connect in window 7,how i can conecct in window 7
Hi.
As the sp 606 is an older machine, it was designed for xp compatibility.
You can try to run it in compatibility mode, but there are no guarantees that this will work.
There may be a windows 7 driver on the internet for this device, but I have searched and have been unable to find one as of yet.
I did however find a vista driver on the Roland website, it might work for you, as alot of devices that get connected to win7 machines use vista drivers to make them work.
here is a link to the download page for it, maybe it will work for you.
http://www.roland.com/products/en/_support/dld.cfm?PRODUCT=SP-606&iRcId=1812391&dsp=1
I hope that this helps you out, and have a good day.
May 25, 2011 | Roland Sp-606 Sampling Workstation System
Free download drivers for my pc desktop win xp sp2
You can free download Windows XP SP-3 drivers from " http://windowsxpdownload.blogspot.com/", " http://www.tipsdr.com/windows-xp-drivers.html". Check these web links to find your suitable drivers.
May 06, 2011 | Computers & Internet
I use WINDOWS XP SP 2...mainboard MSI N1996,
It is fault in Ur Windows firstly repair Ur windows then install driver but recommended restore backup must.
Feb 15, 2010 | Computers & Internet
I downloaded windows xp pro sp 2 and i have to start the internet by starting dhcp client. Road runner tech said that I need an nic driver and I haven't been able to find it.
in the device manager check proper drivers installed, if not any exclamatory mark indiactes, update for the driver needed, update specific lan card drivers, it will works
Mar 23, 2009 | Computers & Internet
Feb 24, 2009 | SimpleTech Pininfarina 80GB External USB...
Ethernet controller driver
i need an ethernet controller driver for my dell dimension 4600 the operating system is windows xp home edition
Sep 02, 2007 | Dell Dimension 4600 PC Desktop
Open Questions:
SimpleTech (SP-U25/120G) 120 GB USB Hard Drive Logo
44 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
