Question about Yamaha RXV671
Zone 2 will not play, says check sp wires - Yamaha RXV671
3 Suggested Answers
marsrover
  • 682 Answers
SOURCE: Check SP wires
if you checked wire carefully in high ohm reading and confirm no internal short circuit.-please follow me:-1-disconnect all speakers cables from receiver and check if it is fine-try to connect your speakers one by one until you find the bad one.if it is still shut down you will have a problem inside receiver itself and needs service center to fix.
-it maybe speaker check it also one by one with good known cable.
Posted on Jul 16, 2008
AJIN G
  • 6694 Answers
SOURCE: Our 2nd zone won't work, we get the error saying
U cant get an amplified out put form ur av receiver for zone 2. speaker a A and B is the same out put of frond left and right. it is not ZONE 2 output. U can get only a pre output for zone to from this receiver. U nee a separate stereo amplifier for using zone 2 .put an amplifier in the other room, connect the zone 2 pre out to it. And do the following setup in ur av receiver .
The receiver shows check speaker cable because its amplifier minimum impedance is 8 ohms . when u connect other speaker in speaker the total impedance will come under 4 ohms. Speaker b is not ZONE 2 in this amplifier
1. press the input selector button A or B to select the source component you want to setup.
2. press and hold LEARN (on remote) button about 3 seconds by using a boll pen or similar object ( SETUP and the selected component name appear alternately in the display window.)
3. press up or down arrow to select "zone2"
4. press LEARN to complete the Zone 2 setup.
5. press source select up arrow to display Zone2 in the window.
6. press an input selector button to select input source u want to listen to in the second room
7. u can control the component by using the component control area button
ok
Posted on Dec 26, 2010
We wired our new home to have outdoor speakers and also speakers to our pool room. Before putting the receiver back into place after wiring the back, we quickly touched a speaker's wires to the wires...
It's not really clear if all of this is Zone 2 or not, or if you intend a second program to play in Zone 2.
If your Zone 2 is to a powered amplifier and its speakers the Zone 2 output would be FIXED (not variable from the host TX-SR705), that is, at a level that the receiving amplifier would control.
Page 99 deals with it.
Having just passive speakers in Zone 2 requires you to set Zone 2 to "ACT(ive)".
Mar 27, 2011 | Onkyo TX-SR705 Receiver
Our 2nd zone won't work, we get the error saying check SP wires. The wires seem connected correctly. We also can't change the volume on zone 2. The Yamaha unit is working otherwise.
ok
Dec 26, 2010 | Yamaha RX-V2200 Receiver
Yamaha RX- V 663 - unable to change volume on Zone 2
Page 111:
PROBLEM: Zone 2 speaker settings are not available in "SET MENU".
CAUSE: "EXTRA SP ASSIGN" is set to a setting other than "ZONE2".
REMEDY: Set "EXTRA SP ASSIGN" to "ZONE2".
See Page 85
Mar 13, 2010 | Yamaha RX-V663 Receiver
Denon AVR-2309C1 will not play sound through
Turn off zone 2 then turn your receiver on the main zone on Radio, tune in a station and check for audio. Post a comment and let me know if audio works that way. If you don't have any audio, list your other equipment makes and models as well as how they are interconnected to your receiver (cable type) and I will help you troubleshoot
Jun 28, 2009 | Denon AVR588 Receiver
Unit turns itself off after diplaying code "check SP wire"
My guess, guess, check CLOSELY the SPeaker wires - "Check SP wire" make sure all of the bare portion of the wire is into the terminal. No bare wire touching another bare wire both at the receiver and at the speakers. Also, if the wiring is not continuous, check all connections of speaker wire. Disconnect all but one, play it like that. If no problem, label that as good, disconnect another for several days, when one shuts Rec. off, check wires closely for that speaker.
Jan 23, 2009 | Yamaha HTR-5650 Receiver
Denon AVR-2105
If the Cd is wired digitally, it will only play through the main zone, because the Denon cannot convert down to RCA to cater for the zone 2. If you plug RCAs from Cd to Denon, Main zone will STILL play from digital, and RCA connection will allow zone 2 to play Cd from RCA input....same with dvd, Satellite Blah blah... no stress, any nasty RCA will do if you want to try before you splash out on really costly cables...perhaps you can help me...want to run AVR 2105 with 2 speakers in zone 2, manual says cant do it - only ably to surround back or biamp...dont want either, dont have stereo yet to try it out...did you have any trouble with that?
May 26, 2008 | Denon AVR-2105 Receiver
Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
May 24, 2008 | Denon AVR-1803 Receiver
How to play XM Radio on zone 1 and zone 2 in sync
Examine the operator's manual for the page explaining the video delay adjustment. Also examine the speaker wire line ends for proper shielding, continunity and polarity placement.
Dec 31, 2007 | Onkyo TX-SR803 Receiver
Yamaha RXV671 Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
