Question about Maytag Dryers
Maytag gas dryer
When operating the dryer makes a loud rumbling sound
Can I fix this myself or this it time for a new dryer? Also can I use it until it quits running or is there a safety risk.
Posted on Apr 26, 2009
  • 979 Answers
The spindle or shaft turning the drum may be bad. The motor as well could be slowly but surely grinding to a halt.
Posted on Jan 25, 2009
I get a rather loud rumbling sound when I first start up the dryer the drum is turning but still getting the rumbling sound but not as loud.
Sounds like you need rear rollers or you have a bad blower wheel. If you turn the dryer off and still hear the rumble for a few seconds its the blower wheel. If the rumbling stops instantly then you have bad rear rollers. Hope this helps.
_MJ_
Dec 14, 2010 | Maytag Dryers
MaytaG MODEL # MDG4000BWW. Rumbles and sweels as
check the rollers,the pulley and if it shakes as bad as it sounds the blower wheel is probably damaged
Jul 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Makes a horrible noise. Seems to dry fine but before its done it sound like it going to explode.
The blower wheel may be stripped out or broken.
This will cause a loud rumble noise while operating.
Jan 16, 2010 | Maytag PYE2300AY Electric Dryer
My Maytag Dryer makes a very loud grinding sound
drum main bearging is gone time to get another dryer or have that one repaired for about twice what it is worth... cheaper to buy a used one and go with that till???
Nov 18, 2009 | Maytag Dryers
Loud rumble sound, Vent hose vibration
That model of neptune dryer had a problem with the blower housings cracking. When the housing cracks, it binds forward into the blower wheel making a loud "rumble" noise and vibration. If you open the door and manually turn the drum and you hear a rubbing noise and feel alot of resistance, then you have a cracked blower housing and need to replace it. It is not an easy job to replace, so if your not familiar with dryers, you should have a technician replace it. Let me know if you have any further questions. shane
Oct 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
MayTag Neptune MDE6800AYW dryer drum making rumbling knocking noise
Have someone change the bearing, it sounds like it has busted on ya. The rumbling sounds like the ball bearings in the bearing have failed.
Jul 09, 2009 | Maytag Neptune MDE6800 Electric Dryer
Very Loud Dryer
squeeling hi pitch is usually the drum support roller above the heater. if you take the machine apart and turn all moving parts by hand you should be able to find the problem...if its a rumbling noise then it may be the blower wheel. UNPLUG FIRST..good luck :)
Jun 13, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
Loud Noise when drying....
hi thanks for the question tome iot sounds like the blower a rumbling noise and the dryer takes too long to dry so i would check that thanks the appliance doc
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
82 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
